Fritzbox 7590/7530/6890 LTE whitelisting + Supervectoring 35b
Bedankt: 412 keer
Taal: Meertalig
Version: 07.39-94458
Datum: 09.02.2022
Bedankt: 412 keer
07.39-94623
meertalig
17/2/2022
a114me
Hello.
According to edpnet page:
https://www.edpnet.be/en/support/orderi ... dpnet.html
FRITZ!Box 7530 AX German version (MPN: 20002930 / EAN: 4023125029301) is not supported.
Could please somebody confirm, that this is a valid statement?
Do I need to have global only version of this modem in order to use with edpnet VDSL ?
Uitgedeelde bedankjes: 1026 keer
Bedankt: 3825 keer
Recent bedankt: 11 keer
This statement is obsolete now. There are no differences any more between German and international versions, both hardware and Firmware are identical.
Also the statement that "German versions don’t have edpnet configuration preset and you will need to select Other Internet Provider and manually enable VLAN10 in order to successfully configure the device" is not correct.
As soon as you change the country settings to Belgium, and reboot the Fritz!Box, the "Belgian" provider dropdown list with the Edpnet configuration will be available.
Most important is the DSL driver, which needs to be whitelisted. In some cases you may need to select "previous driver" in order to avoid a "fall back" profile (capped to 7 Mbps).
Bedankt: 412 keer
de DSL/telefoon stekker in de fritzbox 7590 stoppen (DE versie) is toch niet simpel. In de bbox 3V+ glijdt hij erin.....
Verschil met de internat. box?
7590
DSL-versie: 1.180.131.98
Meertalig
Version: 07.39-94931
Datum: 03.03.2022
Vorige week is s'nachts een update gebeurd (vergeten autom. updaten uit te schakelen). s'morgens gaat alles zo traag bij thuiswerken. Doe een speedtest, zat op FB profiel 5/0.5 :-( . Edpnet gebeld, binnen de min. binnen, en 2 minuten later terug 50 DL.
Dus 'previous dsl driver aanzetten' + updates UITSCHAKELEN!
Nu terug manueel nieuwe driver ingeschakeld om op FB profiel te vallen. Nadien Bbox 3V+, en dan kan ik aan 35 Mbps profiel raken ipv 30 Mbps (fritzbox). :-)
Bedankt: 202 keer
De DSL stekker voor in een Fritzbox heeft een RJ45 body met de 2 middelste pinnen in gebruik.
Op en Bbox-3 is dit een RJ11.
Normaal dat deze RJ11 moeilijk erin gaat :-D
Bij de Fritzbox is toch een grijs DSL kabeltje bijgeleverd ?
https://assets.avm.de/files/docs/fritzb ... _nl_BE.pdf
pagina 41
Bedankt: 3825 keer
satsurfer schreef:de DSL/telefoon stekker in de fritzbox 7590 stoppen (DE versie) is toch niet simpel. In de bbox 3V+ glijdt hij erin.....
Er is geen verschil tussen een Duitse of internationale FB.
Let wel op: een RJ11 stekker steken in een RJ45 bus kan deze laatste beschadigen.
lacer schreef: Normaal dat deze RJ11 moeilijk erin gaat :-D
Bij de Fritzbox is toch een grijs DSL kabeltje bijgeleverd?
Bij een internationale FB wordt een kabeltje geleverd met aan de ene kant een RJ45 stekker, en aan de andere kant een RJ11 stekker.
Ofwel een Y-kabel met de nodige adapters.
Bedankt: 412 keer
DSL-versie: 1.180.129.93 (previous)
Meertalig
Version: 07.39-95462
Datum: 25.03.2022
New features:
- Talking caller ID – FRITZ!Fon learns to speak: New features for FRITZ!Fon
- WireGuard support for simple setup of VPN connections
- Mesh Wi-Fi – more performance for the FRITZ!Box as a Mesh Repeater
- More operating convenience in the FRITZ!Box user interface
Bedankt: 412 keer
Meertalig
Version:07.39-95780 (Beta)
Datum: 08.04.2022
Laatst gewijzigd door satsurfer 26 apr 2022, 18:24, in totaal 2 gewijzigd.
Bedankt: 412 keer
Meertalig
Version: 07.39-96137 (Labor)
Datum: 26.04.2022
alloja
Bedankt: 51 keer
Op Bel-Com is er een gebruiker van 7590 AX die zonder fallback werkt!
GLiNet Flint 3 • Proximus Flex+ Ultra Fiber • Voo DVB-C
Vu+ Duo 4K SE (DVB-C + DVB-T2) • V7c (Pickx Mix FR) • Apple TV 4K
Bedankt: 412 keer
"Malheureusement mon profil a changé ce matin (7mbs)... et j'ai du remettre une BBox3+... étrange. Pourquoi après 12 jours?..."
rtl
Bedankt: 36 keer
Zo te zien werkt de 7590 ax weldegelijk met firmware 7.31
De persoon in kwestie viel terug op een repair profiel met v7.30, na upgrade naar 7.31 werkt het opnieuw stabiel op hoge snelheid (tot nu toe)
Er werd dus een verhoging doorgevoerd en hij is terug van het repair profiel vanaf
De gebruiker op bel-com.be viel wellicht terug op repair door gebruik van 7.39 beta?
Bedankt: 3825 keer
a114me schreef:According to edpnet page:
Yes indeed.
Contrary to all previous Fritz!Boxes, where there was no hardware difference between German and international versions (apart form the German TAE phone port, and the language on the box), this is different with the 7530AX
German version will not work (other DSL chipset I suppose). Therfore mandatory to use the international 7530AX
Bedankt: 3825 keer
rtl schreef:Zo te zien werkt de 7590 ax weldegelijk met firmware 7.31
Noch AVM, noch EDPNet hebben stappen gezet tot de goedkeuring van de 7590AX door Proximus.
Er is ook geen "read-accross" mogelijk tussen de 7530AX en de 7590AX gezien deze verschillende DSL chipsets hebben.
Misschien zijn er testen aan de gang die door een andere ISP geïnitieerd werden, of door Proximus zelf (voorlopig grey-listed?).
Ik zou er dus voorlopig niet van uitgaan dat de 7590AX door PX goedgekeurd is.
Tenzij iemand meer weet ??
rtl
Bedankt: 36 keer
Nog vergeten vermelden, de persoon van het screenshot zit bij Proximus. Niet bij Edpnet.
qless
Bedankt: 160 keer
Dat maakt niet uit, dsl goedkeuring is voor het hele netwerk ongeacht provider.
Bedankt: 412 keer
https://avm.de/fritz-labor/frisch-aus-d ... twicklung/
7590
Taal: Meertalig
Versie: 07.39-99710
Datum: 09.09.2022
Bedankt: 412 keer
Ik lees op ander forum:
"Met de komst van MV dat nu ook internet aanbiedt (via glasvezel) hebben ze er toch een zware low cost concurrent bij. Recent heeft edpnet hun snelheid wel omhoog gedaan (ze kwamen van 100mbps en zijn nu 150mbps) en dat was echt wel nodig om toch een voordeel te hebben tov MV (die amper €2 duurder is en waar de modem wel inbegrepen zit)."
=> Hier TBF nodig? Of een bbox 3?
Met nieuwe dsl driver <200 m. van straatkast. (Niet gecertifieerd)
> (Oude DSL driver: 1.180.129.93): 209 m.
Laatst gewijzigd door satsurfer 20 nov 2022, 21:50, in totaal 1 gewijzigd.
Bedankt: 3825 keer
TBF ???
Jouw quote gaat over EDPNet "Fiber XS" (150/50), bij Fiber is een TBF of een DSl driver compleet irrelevant...
Bedankt: 412 keer
"dat was echt wel nodig om toch een voordeel te hebben tov MV (die amper €2 duurder is en waar de modem wel inbegrepen zit)."
38€ MV
36€ Edpnet
Dus ik dacht VDSL, waar ze al lang over bezig zijn.
Maar gaat over Fiber dus.
TBF: kan evt. zo op hoger lijnprofiel raken als dit voorzien is natuurlijk (op uw lijn)
Bedankt: 3825 keer
De VDSL2 profielen zijn vastgelegd door Proximus, daar kan EDPNet noch MV iets aan wijzigen...
PS. Als je iets quote uit een ander Forum, kan je beter ook de link posten :wink:
Glowtape
AVM released 7.50, at least for the 7590. Anyone installed it yet? What's the version of the previous DSL driver in this release?
Bedankt: 3825 keer
Yes.
- new DSL driver: 1.180.131.99
- previous driver: 1.180.129.93 (Proximus whitelisted).
Download link: http://ftp.avm.de/fritzbox/fritzbox-759 ... /fritz.os/
Belgische gebruikers die nu nog op OS 07.28/07.29 zitten, of de Beta 07.39, zullen de nieuwe update niet aangeboden krijgen.
Manueel updaten kan wel, maar dan wel onmiddelijk nà update de optie "Vorige DSL-versie gebruiken" aanvinken.
Bedankt: 202 keer
- FRITZ!OS 7.50 - with over 150 new functions and useful improvements
Ja, dat is de moeite, benieuwd of deze update ook voor de Belgische gebruikers zal worden aangeboden.
buthead
Bedankt: 132 keer
Ik ga nog even afwachten , ken er nog niet te veel van.
Terug gaan naar vorige versie gaat veronderstel ik? ( frimware)
Internet = Hey Telecom
Telefonie/GSM = PX Mobiel
TV = PX pickx + Streaming
Bedankt: 3825 keer
Terug gaan naar vorige versie (downgrade) gaat, op voorwaarde dat je de settings bewaard hebt.
Want bij een downgrade ga je terug naar fabrieksinstellingen...
Glowtape
lacer schreef: 01 dec 2022, 21:02 Ja, dat is de moeite, benieuwd of deze update ook voor de Belgische gebruikers zal worden aangeboden.
On the FTP server, the Belgian firmware image is still 7.29.
I'm mostly interested for the Wireguard stuff.
Glowtape
Bah, Wireguard is only usable when you successfully set up DynDNS in the firmware. I have my NAS take care of that, so I had to pretend sign-up to Fritz' DynDNS to be able to configure it. And it doesn't route IPv6 either, only IPv4.
broke23
Bedankt: 25 keer
What are you exactly complaining about? My synology is reachable with WireGuard through the 7590 here
Glowtape
It doesn't allow you to configure Wireguard unless you set up DynDNS on the Fritzbox. That's a weird decision, in case you know your ISP gives you a fixed IP, or you have another device doing that duty. My NAS does update my domain at Gandi, I don't need the Fritzbox to do that (nor is it able to, anyway).
And the Wireguard connection on the Fritzbox doesn't route IPv6. I have my devices on the network running IPv6-only when possible.
vverbeke
Bedankt: 94 keer
Wat is de recentste firmwareversie voor de 7590 die bruikbaar is met VDSL, al dan niet met previous driver aanvinken?
Bedankt: 1980 keer
7.50, werkt misschien met de nieuwste driver. Het proberen waard. (Hou een Bbox-3 klaar, voor als je toch op fall-back profiel belandt.)
GeertD
Bedankt: 6 keer
Heeft dat in feite nog belang indien je fiber hebt?
De fiber modem doet de connectie of niet en de fritz enkel als router?
wilde dat eens weten of dat wel klopt wat ik nu zeg.
Bedankt: 1980 keer
Ik had het over de DSL-driver. Dit heeft alleen belang voor VDSL vanzelfsprekend.
Bij fiber sluit je de Fritz!Box als router aan op de ONT/glasvezelmodem.
fiatuno49
raf1 schreef: 14 maa 2023, 10:06 7.50, werkt misschien met de nieuwste driver. Het proberen waard. (Hou een Bbox-3 klaar, voor als je toch op fall-back profiel belandt.)
Gisteren update naar 7.50 gedaan zonder probleem tot nu.....bedankt Raf1
Bedankt: 1980 keer
Mijn vermoedens worden steeds vaker bevestigd dat vrije modemkeuze op het Proximus VDSL-netwerk een feit is.
Bedankt: 1231 keer
Vrij?
Of enkel de whitelist?
ahrand
Bedankt: 39 keer
fiatuno49 schreef: 26 maa 2023, 11:45
Hier vorige week ook een update gedaan naar 7.50 zonder 'previous driver'.
Geen onderbreking en werkt nog altijd.
Bedankt: 1980 keer
heist_175 schreef: 27 maa 2023, 13:59 Vrij?
Ik vermoed vrij.
Volgens de whitelist-regeling moet een alternatieve provider bij Proximus telkens een certificatieprocedure aanvragen om een nieuwe DSL-driver/firmware aan de whitelist toe te voegen.
Dus als je vroeger je Fritz!Box updatete naar de nieuwste firmware, moest je opletten dat je previous DSL-driver aanvinkte, omdat de nieuwste DSL-driver mogelijks niet op de whitelist stond. Anders werd je na enkele uren onherroepelijk op fall-back profiel gezet.
Maar de laatste maanden lees ik dat mensen met nieuwe, zelfs béta-firmware met nieuwe DSL-drivers nooit meer op fall-back geraken.
Dus vraag ik me af welke alternatieve provider die allernieuwste DSL-drivers zo snel laten goedkeuren heeft?
Meest logische conclusie lijkt me dat Proximus niet meer met een whitelist werkt.
Terug naar “EDPnet (LaTribu)”
