Bbox3 Sagem Tool
vivanco2020
Hello everybody,
who can change my profile?
I do not know where I can complain to Proximus.
Because I actually have to have more speed.
565 meters normal must be at least 50 Mbits
Laatst gewijzigd door philippe_d 16 apr 2020, 10:52, in totaal 1 gewijzigd.
Reden: url aangepast
Bedankt: 3934 keer
Recent bedankt: 15 keer
There is nothing to complain about :wink: .
Your profile is based on some strict rules (set by Proximus), and your line is monitored frequently to check whether an increase is possible, or a decrease is needed (DLM process) ...
Based on the distance, it looks like you are in “zone 2”
But unfortunately you are connected to a non-vectoring capable DSLAM (Ikanos) :-( .
As per table in this post:
  • - the non-vectoring base profile for your distance would be 20/6 Mbps.
    - DLM could further increase the profile up to a (theoretical) maximum of 50/10 Mbps.
    - however your line is not capable to support this maximum, hence you have been put on 30/8 Mbps.
Based on the SNR (10 dB up/down), a further increase would put you in a borderline area of instability ...
I would rather prefer a stable connection @ 30/8 above a 35/10 connection with many errors and disconnects :wink: .
Only hope for improvement is waiting until Proximus converts your line to a vectoring capable DSLAM (Broadcom)
vivanco2020
Englisch
Ich habe geschaut und festgestellt warum auf unsere strasse kein VDSL anschluss. Wo kann ich bescheid sagen ob auf unsere straße auch VDSL anschluss gebaut werden soll. siehe Foto
I looked and found out why there was no VDSL connection on our street. Where can I say whether VDSL connection should be built on our street. see photo
I can not understand why there is no DSLAM cabinet on our street.
Bedankt: 3934 keer
Sie können nicht alles verlangen: leben im schönsten Teil Belgiens und schnelles Internet haben :-D
Sie haben also VDSL2, aber keine Vektorisierung!
Ich denke, Ihr Internet kommt direkt von der Vermittlungsstelle oder "LEX" (Zentrale) 87RAE0, Burgstrasse 4730 Raeren.
Die im LEX enthaltenen DSLAMs unterstützen leider keine Vektorisierung :-( .
(vertaald)
Je kan niet alles hebben: in het mooiste stukje van België leven, en snel internet willen :-)
Hij heeft dus wel VDSL2, maar geen vectoring!
Waarschijnlijk krijgt hij zijn VDSL2 direct vanuit de LEX (87RAE0) in Raeren, en zoals we weten ondersteunen de DSLAM's in de LEX (nog) geen vectoring.
Bedankt: 797 keer
Wat een prachtig voorbeeld om visueel aan te geven tot wat voor technische problemen onze lintbebouwing leidt :lol:
M_016
Bedankt: 113 keer
It's certainly the case / gilt mit Sicherheit
jackho
Bedankt: 279 keer
Es gibt noch keine vektorisierten Straßengewächshäuser und einige Lex mit integriertem ROP
Bedankt: 3934 keer
Userbase goes multilingual :-D
jackho
Bedankt: 279 keer
wir schaffen das :-D
vivanco2020
Thanks for the answers.
So that means wait until we get Vectoring connection. I have lived since 2011 and my speed has never increased. I hope it will be soon.
bartman
Bedankt: 30 keer
Hierbij mijn waarden gemeten vanop een win10 laptop geconnecteerd via wifi met de bbox3 modem. De max bit rate is dat te halen met een netwerkkabel?Afbeelding
Verstuurd vanaf mijn SM-G973F met Tapatalk
pluim
Bedankt: 12 keer
bartman schreef:De max bit rate is dat te halen met een netwerkkabel?
Nee, de max bitrate is in principe 'de max' dat je lijn kan hebben (waarvan je meestal een stukje minder krijgt om stabiliteit te garanderen).
De current bitrate is waaraan je synct, 70/30 in jouw geval. Dat is dus de maximum dat je zal krijgen, tenzij je abonnement dit verder beperkt natuurlijk. Zelf met dit profiel heb je met Proximus Internet Start of Scarlet Trio bijvoorbeeld een lagere snelheid. De volle snelheid van je profiel haal je met een provider als EDPnet (met het XL-abonnement).
Ik denk wel dat jouw snelheid nog omhoogkan, maar merk ook dat de modem nog niet lang aan staat. In zo'n gevallen gaat het vanzelf omhoog wanneer er gedetecteerd wordt dat je lijn perfect stabiel blijft met een hogere snelheid - volgens hoe ik het begrijp. ;)
An easily-interested brunette who loves to explore the unfamiliar :curt:
alloja
Bedankt: 52 keer
@vivanco: Dann sind zwei Alternativen möglich:
- die 4G-Abdeckung korrekt ist und dann durchgehen (Mobilus 5G Unlimited bei Proximus, Flybox bei Orange oder Tadaam bei Telenet);
- oder noch einfacher: das Koaxialkabel über Voo oder Orange.
Proximus Ultra Fiber • Voo DVB-C • RTBF DVB-T2 • Vu+ Duo 4K • GL.iNet Flint 4
vivanco2020
Thank you. I'm still looking at half a year and then I look at which provider is better for me.
Kioxkabel is not with me.
bartman
Bedankt: 30 keer
de tool werkt (zowel via laptop (draadloos) als via desktop (bedraad) maar krijg wel deze melding. IK draai op beide toestellen de laatste win 10 home
payphoneuser
Bedankt: 64 keer
Uitvoeren als Administrator, dat lost het op
Sinna
Twitter: KrSi78
Uitgedeelde bedankjes: 374 keer
Bedankt: 260 keer
Adminrechten zijn m.i. niet nodig. Ik vermoed dat als je de tool vanuit een 'normale' folder lanceert (dus niet C:\Windows\System32) het wel zal lukken.
res
wat kan beter ?
Sinna
Twitter: KrSi78
Bedankt: 260 keer
Geduld oefenen al lijkt het maximum op de upload wel bereikt.
Sergewhotry
Bonjour,
Pour moi, avec le user et le mot de passe du modem, le même utilisé pour acceder aux options de ma Bbox 3, impossible de me connecter, je reçois toujours un message d'erreur.
D'avance merci.
alloja
Bedankt: 52 keer
Peut-être as-tu une b-box 3 Technicolor ? (C’est marqué sur la grande étiquette blanche à l’arrière de la b-box 3.) Si tel est le cas, le programme est alors incompatible…
Misschien heb je een b-box 3 Technicolor? (Het is gemarkeerd op het grote witte label op de achterkant van de b-box 3.) Als dat zo is, dan is het programma niet compatibel...
marethari
[code]
B-Box 3 Sagem Tool v0.13.0
Downstream current bit rate:   69,999 kbps
Upstream current bit rate:     30,434 kbps
Downstream max bit rate:       83,971 kbps
Upstream max bit rate:         36,369 kbps
Downstream attenuation:        14.6 dB
Downstream noise margin:       10.7 dB
Upstream noise margin:         9.3 dB
Vectoring down:                yes
Vectoring up:                  yes
Modem vectoring compatible:    yes
ROP vectoring compatible:      yes
DSL standard:                  VDSL2 Annex B
DSL profile:                   17a
Estimated distance:            344 m
Proximus profile name:         70/30
Proximus DLM profile:          no
Proximus repair profile:       no
[/code]
enige kans dat ik meer krijg dan dit?
alloja
Bedankt: 52 keer
In deze configuratie lijkt het moeilijk om over te schakelen naar een hoger profiel...
Garpenlov
Bedankt: 74 keer
Ik zal mijn lijnwaarde er ook maar eens opgooien dan zekers? :D
Ik heb een 100/40 abbo, ik hoop dat ik met de huidige lijnwaarde kans maak op 100/35.
Het is een kleine week geleden sinds de dlm em verhoogd heeft naar 85/35
Downstream current bit rate:   85,000 kbps
Upstream current bit rate:     35,000 kbps
Downstream max bit rate:       114,015 kbps
Upstream max bit rate:         40,565 kbps
Downstream attenuation:        16.4 dB
Downstream noise margin:       15.9 dB
Upstream noise margin:         9.1 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
Estimated distance:            414 m
Proximus profile name:         85/35
Proximus DLM profile:          yes
M_016
Bedankt: 113 keer
@Garpenlov die kans op 100/35 is reëel gezien de noise margin waarden (>10 dB) maar er is uiteraard geen garantie de DLM-wegen zijn soms nogal ondoorgrondelijk
jackho
Bedankt: 279 keer
Soms moet er ook een grondige opsporing gebeuren door Proximus waarom er zelfs met heel goede waarden geen verhoging mogelijk is!
Jelly
Bedankt: 18 keer
Na al die jaren Coax en wegens een verhuis toch maar eens de sprong gewaagd naar de VDSL technologie.
Valse start bij installatie, nieuwe kabel die de woning binnen kwam was beschadigd en moest hersteld worden door Proximus, al schrik voor teleurstellende lijnwaarden. Herstelling ziet er momenteel wel succesvol uit:
Device: B-Box 3 Sagem
Downstream current bit rate: 69 999 kbps
Upstream current bit rate: 29 999 kbps
Downstream max bit rate: 137 256 kbps
Upstream max bit rate: 42 782 kbps
Downstream attenuation: 7,5 dB
Downstream noise margin: 29,2 dB
Upstream noise margin: 14,4 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Estimated distance: 121 m
Op dit ogenblik ontvang ik van Proximus (speedtest en via MyProximus) een 60mbps down en 18 mbps up. Iemand een idee waarom er niet onmiddellijk 70/30 wordt aangeboden?
Ik ben Internet Maxi klant. Wanneer alles stabiel is volgt nog de overstap naar EDPnet. Gezien de huidige waarde vermoed ik wel dat een 100/35 mogelijk is.
Everything that has a beginning has an end.
Patje
Bedankt: 115 keer
Internet Maxi is 20 Mbps upload, dus meer zal je niet krijgen ondanks je synct op 30 of 35 :)
Je zit blijkbaar wel op een 70 down die kan verhogen naar 100
Hey vast Internet 150/15 Mbps. https://www.speedtest.net/result/19679718178
Jelly
Bedankt: 18 keer
Dat snap ik Patje
Vind het gewoon vreemd dat ik via my Proximus een snelheid krijg van 58 en 18up in plaats van huidige sync en abonnement 70 down 20 up.
Mvg
M_016
Bedankt: 113 keer
@jelly dit lijkt inderdaad vreemd vermits onderstaande uw lijnstartprofiel is (en blijkbaar niet gewijzigd werd)
-> even = een paar dagen aanzien en Proximus contacteren of eventueel 0800 22424 bellen met uw klantnr ter hand (= machine/applicatie)
de speedtest werd toch via utp-kabel uitgevoerd (en niet win WiFi 2.4)?
alloja
Bedankt: 52 keer
Een synchronisatie van 70 Mbps geeft meestal een maximale snelheid van 63 Mbps. Het is mij altijd uitgelegd dat je ±10% moet verwijderen tussen de synchronisatie en de werkelijke maximumsnelheid.
Dus, zoals M_016 zegt, afhankelijk van hoe de snelheidstest werd uitgevoerd, kan er een verlies van een paar Mbps zijn als het werd gedaan in Wi-Fi of met een tussenliggend apparaat tussen de b-box en de PC.
trical
Downstream current bit rate:   70.417 kbps
Upstream current bit rate:     19.999 kbps
Downstream max bit rate:       88.945 kbps
Upstream max bit rate:         22.864 kbps
Downstream attenuation:        19,4 dB
Downstream noise margin:       12,3 dB
Upstream noise margin:         7,1 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
Estimated distance:            516 m
Proximus profile name:         70/20
dit is op edpnet
dupondje
Bedankt: 55 keer
Werkt de BBOX tool eigenlijk op een BBOX 3v+?
Helaas niet te testen hier op een Linux PC, moet dringend eens kijken om de tool te porteren naar een andere taal :)
alloja
Bedankt: 52 keer
dupondje schreef:Werkt de BBOX tool eigenlijk op een BBOX 3v+?
Alle b-box 3v+ zijn Sagemcom modellen. Dus, geen zorgen.
GuntherDW
Bedankt: 78 keer
Dat het met mono niet werkt klopt, er zitten bepaalde dingen in die net iets anders werken.
Echter kan je met winetricks wel de "echte" .net installeren geloof ik welke deze tool gebruikt?
Desnoods in een andere wine root folder, of via playonlinux/lutris/... om je "echte" niet te "vervuilen"?
Heb dit zelf nog niet geprobeerd omdat ik de modems welke deze tool gebruikt niet heb maar heb wel al gechecked waarom het niet draait op linux.
hardyscript
Bedankt: 30 keer
Kan iemand van jullie mij vertellen of er verbetering mogelijk is op mijn lijn en welke stappen ik moet ondernemen?
Upstream current bit rate:     35 000 kbps
Downstream max bit rate:       109 138 kbps
Upstream max bit rate:         41 340 kbps
Downstream attenuation:        17,9 dB
Downstream noise margin:       19,4 dB
Upstream noise margin:         9,8 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
Estimated distance:            450 m
Proximus profile name:         70/35
EotT
Crew support
Crew support
Uitgedeelde bedankjes: 206 keer
Bedankt: 324 keer
DLM zal jouw lijn waarschijnlijk nog wel verhogen naar 85/35. Hiervoor moet je niks doen, gewoon geduld hebben. 100/35 zal waarschijnlijk niet lukken denk ik.
hardyscript
Bedankt: 30 keer
EotT schreef:DLM zal jouw lijn waarschijnlijk nog wel verhogen naar 85/35. Hiervoor moet je niks doen, gewoon geduld hebben. 100/35 zal waarschijnlijk niet lukken denk ik.
Ik stond vroeger op 85/35 maar sinds nieuwe buren ben ik gezakt naar 70 profiel. zou een lijntest iets uithalen?
M_016
Bedankt: 113 keer
Ik vermoed dat u best even geduld oefent. Uw lijn is mogelijk teruggevallen op zijn startdebiet 70/30 omwille van een technische interventie op de distributiekabel voor de aansluiting van uw nieuwe buren en ondertussen op een DLM-profiel 70/35 gebracht op basis van resultaten van automatisch lopende tests.
Vermits de noise margin down >> 10 dB is de kans op terug 85/35 mijns inziens inderdaad zeker reëel
Patje
Bedankt: 115 keer
Volgens mij is die start debiet niet 70 maar 50 als men in zone 2 zit (zijn afstand meting is 450m) , maar de lijn zou in principe wel moeten 85 Mbps aankunnen.
