__________________________________________________
| VDSL2Tool 3.0 | © Arno Raps | http://hierzo.net/ |
\__________________________________________________/
downstream upstream
Line: 40192 kbps 6064 kbps
Max: 46432 kbps 9728 kbps
Profile: 17a
Distance: 777 m
Training: 13,1 dB
Attenuation: 17,3 dB
Ook de Belgacom lijntest duidt een 20/2 profiel aan.
De output van het "vdsl pstatex" commando in de shell geeft de volgende output:
Extended Port Status
Bme: 1 Port: 1
Downstream line rate: 46176 kbps
Upstream line rate: 8064 kbps
Bearer0 Downstream payload rate: 0 kbps
Bearer1 Downstream payload rate: 40192 kbps
Bearer0 Upstream payload rate: 0 kbps
Bearer1 Upstream payload rate: 6064 kbps
Downstream attainable payload rate: 56552 kbps
Downstream attainable line rate: 70096 kbps
Downstream Training Margin: 13.1 dB
Downstream Line Protection (Bearer1 Path): 1.0 DMT Symbols
Upstream Line Protection (Bearer1 Path): 1.0 DMT Symbols
Near-end ITU Vendor Id: 0xb500494b4e530200
Far-end ITU Vendor Id: 0xb5004244434da45f
Downstream delay: 7.5 ms
Upstream delay: 4.0 ms
Tx total power -1.4 dbm
FE Tx total power 13.6 dbm
VDSL Estimated Loop Length : 1305 ft
G.Hs Estimated Near End Loop Length : 6343 ft
G.Hs Estimated Far End Loop Length :0 ft
Current framing mode: 0x10
Bandplan Type...........: 0
No. of Upstream Bands...: 2
No. of Downstream Bands.: 3
Line Type: 0x04000000#
