Hier is de log:
Jan 1 12:12:45> Firewall rules flushed
Jan 1 12:12:45> Deleting Interface
Jan 1 12:12:45> Bridge Interface Removed:
Jan 1 12:12:46> Firewall rules flushed
Jan 1 12:12:56> modulation(1)
Jan 1 12:13:12> modulation(1)
Jan 1 12:14:09> DSL Carrier is up
Jan 1 12:14:09> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:14:11> pppd 2.4.1 started by root, uid 0
Jan 1 12:14:11> Got connection: e5e
Jan 1 12:14:11> Saved Session ID: 0
Jan 1 12:14:11> Connecting PPPoE socket: 00:02:3b:02:68:4b 0e5e nas1 0x1000d388
Jan 1 12:14:11> Connect: ppp0 {--} nas1
Jan 1 12:14:12> default route ioctl(SIOCADDRT): Network is unreachable(128)Jan 1 12:15:09> DSL Carrier is down
Jan 1 12:15:49> DSL Carrier is up
Jan 1 12:15:50> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:15:51> PPPD Terminated Through Signal
Jan 1 12:15:51> Connection terminated.
Jan 1 12:15:51> Doing disconnect
Jan 1 12:15:51> pppd 2.4.1 started by root, uid 0
Jan 1 12:15:51> Got connection: 1a63
Jan 1 12:15:51> Connecting PPPoE socket: 00:02:3b:02:68:4b 1a63 nas1 0x1000d388
Jan 1 12:15:51> Connect: ppp0 {--} nas1
Jan 1 12:15:52> default route ioctl(SIOCADDRT): Network is unreachable(128)
Jan 1 12:15:52> WAN IP address 80.200.41.219
Jan 1 12:15:52> PPPoE Connect with IP Address 80.200.41.219
Jan 1 12:15:53> PPPoE Connection Successfully Established
Jan 1 12:15:53> PPPoE Connect with Gateway IP Address: 80.200.41.1
Jan 1 12:15:53> WAN gateway 80.200.41.1
Jan 1 12:15:53> primary DNS address 195.238.2.21
Jan 1 12:15:53> secondary DNS address 195.238.2.22
Jan 1 12:16:19> DSL Carrier is down
Jan 1 12:16:39> DSL Carrier is up
Jan 1 12:16:40> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:16:46> PPPD Terminated Through Signalac
Jan 1 12:16:46> Connection terminated.
Jan 1 12:16:46> Doing disconnect
Jan 1 12:17:09> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:17:11> pppd 2.4.1 started by root, uid 0
Jan 1 12:17:11> Got connection: a67
Jan 1 12:17:11> Saved Session ID: 0
Jan 1 12:17:11> Connecting PPPoE socket: 00:02:3b:02:68:4b 0a67 nas1 0x1000d388
Jan 1 12:17:11> Connect: ppp0 {--} nas1
Jan 1 12:17:12> default route ioctl(SIOCADDRT): Network is unreachable(128)
Jan 1 12:17:12> WAN IP address 87.64.75.202
Jan 1 12:17:12> PPPoE Connect with IP Address 87.64.75.202
Jan 1 12:17:12> PPPoE Connection Successfully Established
Jan 1 12:17:12> PPPoE Connect with Gateway IP Address: 87.64.75.1
Jan 1 12:17:12> WAN gateway 87.64.75.1
Jan 1 12:17:12> primary DNS address 195.238.2.21
Jan 1 12:17:12> secondary DNS address 195.238.2.22
Jan 1 12:17:29> DSL Carrier is down
Jan 1 12:17:49> DSL Carrier is up
Jan 1 12:17:50> PPPD Terminated Through Signal
Jan 1 12:17:50> Connection terminated.
Jan 1 12:17:50> Doing disconnect
Jan 1 12:17:50> pppd 2.4.1 started by root, uid 0
Jan 1 12:17:50> Got connection: 1769
Jan 1 12:17:50> Saved Session ID: 0
Jan 1 12:17:50> Connecting PPPoE socket: 00:02:3b:02:68:4b 1769 nas1 0x1000d388
Jan 1 12:17:50> Connect: ppp0 {--} nas1
Jan 1 12:17:59> DSL Carrier is down
Jan 1 12:18:19> DSL Carrier is up
Jan 1 12:18:19> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:18:19> pppd 2.4.1 started by root, uid 0
Jan 1 12:18:39> DSL Carrier is down
Jan 1 12:18:49> DSL Carrier is up
Jan 1 12:18:49> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:18:49> pppd 2.4.1 started by root, uid 0
Jan 1 12:18:49> Connect: ppp0 {--} nas1
Jan 1 12:18:50> default route ioctl(SIOCADDRT): Network is unreachable(128)
Jan 1 12:18:51> WAN IP address 87.64.67.86
Jan 1 12:18:51> WAN gateway 87.64.67.1
Jan 1 12:18:51> PPPoE Connect with IP Address 87.64.67.86
Jan 1 12:18:51> PPPoE Connection Successfully Established
Jan 1 12:18:51> PPPoE Connect with Gateway IP Address: 87.64.67.1
Jan 1 12:18:51> primary DNS address 195.238.2.21
Jan 1 12:19:09> DSL Carrier is down
Jan 1 12:19:29> DSL Carrier is up
Jan 1 12:19:29> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:19:30> PPPD Terminated Through Signal
Jan 1 12:19:31> Connection terminated.
Jan 1 12:19:31> Doing disconnect
Jan 1 12:19:31> pppd 2.4.1 started by root, uid 0
Jan 1 12:19:31> Got connection: 376e
Jan 1 12:19:31> Saved Session ID: 0
Jan 1 12:19:31> Connecting PPPoE socket: 00:02:3b:02:68:4b 376e nas1 0x1000d388
Jan 1 12:19:31> Connect: ppp0 {--} nas1
Jan 1 12:19:39> DSL Carrier is down
Jan 1 12:19:59> DSL Carrier is up
Jan 1 12:19:59> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:19:59> pppd 2.4.1 started by root, uid 0
Jan 1 12:20:19> DSL Carrier is down
Jan 1 12:20:40> Got connection: b571
Jan 1 12:20:40> Saved Session ID: 0
Jan 1 12:20:40> Connecting PPPoE socket: 00:02:3b:02:68:4b b571 nas1 0x1000d388
Jan 1 12:20:40> Connect: ppp0 {--} nas1
Jan 1 12:20:49> DSL Carrier is down
Jan 1 12:21:09> DSL Carrier is up
Jan 1 12:21:09> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:21:09> pppd 2.4.1 started by root, uid 0
Jan 1 12:21:39> DSL Carrier is up
Jan 1 12:21:40> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:21:40> pppd 2.4.1 started by root, uid 0
Jan 1 12:21:59> DSL Carrier is down
Jan 1 12:22:19> DSL Carrier is up
Jan 1 12:22:20> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:22:20> pppd 2.4.1 started by root, uid 0
Jan 1 12:22:20> Got connection: c876
Jan 1 12:22:20> Saved Session ID: 0
Jan 1 12:22:20> Connecting PPPoE socket: 00:02:3b:02:68:4b c876 nas1 0x1000d388
Jan 1 12:22:20> Connect: ppp0 {--} nas1
Jan 1 12:22:29> DSL Carrier is down
Jan 1 12:22:49> DSL Carrier is up
Jan 1 12:22:50> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:22:50> pppd 2.4.1 started by root, uid 0
Jan 1 12:23:09> DSL Carrier is down
Jan 1 12:23:29> pppd 2.4.1 started by root, uid 0
Jan 1 12:23:39> DSL Carrier is down
Jan 1 12:23:59> DSL Carrier is up
Jan 1 12:23:59> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:23:59> pppd 2.4.1 started by root, uid 0
Jan 1 12:24:19> DSL Carrier is down
Jan 1 12:24:29> DSL Carrier is up
Jan 1 12:24:29> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:24:49> DSL Carrier is down
Jan 1 12:25:09> DSL Carrier is up
Jan 1 12:25:10> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:25:10> pppd 2.4.1 started by root, uid 0
Jan 1 12:25:19> DSL Carrier is down
Jan 1 12:25:39> DSL Carrier is up
Jan 1 12:25:40> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:25:40> pppd 2.4.1 started by root, uid 0
Jan 1 12:28:59> DSL Carrier is up
Jan 1 12:29:00> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:29:00> pppd 2.4.1 started by root, uid 0
Jan 1 12:29:00> Got connection: be8c
Jan 1 12:29:00> Saved Session ID: 0
Jan 1 12:29:00> Connecting PPPoE socket: 00:02:3b:02:68:4b be8c nas1 0x1000d388
Jan 1 12:29:00> Connect: ppp0 {--} nas1
Jan 1 12:29:01> default route ioctl(SIOCADDRT): Network is unreachable(128)
Jan 1 12:29:01> WAN IP address 87.64.66.94
Jan 1 12:29:01> PPPoE Connect with IP Address 87.64.66.94
Jan 1 12:29:01> PPPoE Connection Successfully Established
Jan 1 12:29:01> PPPoE Connect with Gateway IP Address: 87.64.66.1
Jan 1 12:29:01> WAN gateway 87.64.66.1
Jan 1 12:29:01> primary DNS address 195.238.2.21
Jan 1 12:29:01> secondary DNS address 195.238.2.22
Jan 1 12:29:12> sar_set keytype(1)(1), key(oamType)
Jan 1 12:29:12> sar settings
Jan 1 12:29:12> sar_set keytype(1)(1), key(connID)
Jan 1 12:29:12> sar_set keytype(1)(1), key(pvc)
Jan 1 12:29:19> DSL Carrier is down
Jan 1 12:29:19> sar_set keytype(1)(1), key(oamType)
Jan 1 12:29:19> sar settings
Jan 1 12:29:19> sar_set keytype(1)(1), key(pvc)
Jan 1 12:29:39> DSL Carrier is up
Jan 1 12:29:40> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:29:41> PPPD Terminated Through Signal
Jan 1 12:29:41> Connection terminated.
Jan 1 12:29:41> Doing disconnect
Jan 1 12:29:41> pppd 2.4.1 started by root, uid 0
Jan 1 12:29:41> Got connection: dd8e
Jan 1 12:29:41> Saved Session ID: 0
Jan 1 12:29:41> Connecting PPPoE socket: 00:02:3b:02:68:4b dd8e nas1 0x1000d388
Jan 1 12:29:41> Connect: ppp0 {--} nas1
Jan 1 12:29:59> DSL Carrier is down
Jan 1 12:30:09> DSL Carrier is up
Jan 1 12:30:09> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:30:49> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:30:49> pppd 2.4.1 started by root, uid 0
Jan 1 12:30:59> DSL Carrier is down
Jan 1 12:31:19> DSL Carrier is up
Jan 1 12:31:19> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:31:19> pppd 2.4.1 started by root, uid 0
Jan 1 12:31:39> DSL Carrier is down
Jan 1 12:31:49> DSL Carrier is up
Jan 1 12:31:49> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:31:49> pppd 2.4.1 started by root, uid 0
Jan 1 12:32:09> DSL Carrier is down
Jan 1 12:32:29> DSL Carrier is up
Jan 1 12:32:30> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:32:30> pppd 2.4.1 started by root, uid 0
Jan 1 12:32:30> Got connection: 9497
Jan 1 12:32:30> Saved Session ID: 0
Jan 1 12:32:30> Connect: ppp0 {--} nas1
Jan 1 12:32:31> default route ioctl(SIOCADDRT): Network is unreachable(128)
Jan 1 12:32:31> WAN IP address 217.136.125.232
Jan 1 12:32:31> PPPoE Connect with IP Address 217.136.125.232
Jan 1 12:32:31> PPPoE Connection Successfully Established
Jan 1 12:32:31> PPPoE Connect with Gateway IP Address: 217.136.125.1
Jan 1 12:32:31> WAN gateway 217.136.125.1
Jan 1 12:32:31> primary DNS address 195.238.2.21
Jan 1 12:32:31> secondary DNS address 195.238.2.22
Jan 1 12:32:39> DSL Carrier is training
Jan 1 12:32:49> DSL Carrier is down
Jan 1 12:32:59> DSL Carrier is up
Jan 1 12:33:00> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:33:01> PPPD Terminated Through Signal
Jan 1 12:33:01> Connection terminated.
Jan 1 12:33:01> Doing disconnect
Jan 1 12:33:03> WAN gateway 80.201.7.1
Jan 1 12:33:03> primary DNS address 195.238.2.21
Jan 1 12:33:03> secondary DNS address 195.238.2.22
Jan 1 12:33:19> DSL Carrier is down
Jan 1 12:33:39> DSL Carrier is up
Jan 1 12:33:39> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:33:42> PPPD Terminated Through Signal
Jan 1 12:33:42> Connection terminated.
Jan 1 12:33:42> pppd 2.4.1 started by root, uid 0
Jan 1 12:33:59> DSL Carrier is down
Jan 1 12:34:19> DSL Carrier is up
Jan 1 12:34:19> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:34:19> pppd 2.4.1 started by root, uid 0
Jan 1 12:34:29> DSL Carrier is down
Jan 1 12:34:49> DSL Carrier is up
Jan 1 12:34:49> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:34:49> pppd 2.4.1 started by root, uid 0
Jan 1 12:34:49> Got connection: b49e
Jan 1 12:34:49> Saved Session ID: 0
Jan 1 12:34:49> Connecting PPPoE socket: 00:02:3b:02:68:4b b49e nas1 0x1000d388
Jan 1 12:34:49> Connect: ppp0 {--} nas1
Jan 1 12:34:50> default route ioctl(SIOCADDRT): Network is unreachable(128)
Jan 1 12:34:50> WAN IP address 80.201.202.153
Jan 1 12:34:50> PPPoE Connect with IP Address 80.201.202.153
Jan 1 12:34:51> primary DNS address 195.238.2.21
Jan 1 12:34:51> secondary DNS address 195.238.2.22
Jan 1 12:35:09> DSL Carrier is down
Jan 1 12:35:29> DSL Carrier is up
Jan 1 12:35:29> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:35:30> PPPD Terminated Through Signal
Jan 1 12:35:30> Connection terminated.
Jan 1 12:35:30> Doing disconnect
Jan 1 12:35:30> pppd 2.4.1 started by root, uid 0
Jan 1 12:35:31> Got connection: bda0
Jan 1 12:35:31> Saved Session ID: 0
Jan 1 12:35:31> Connecting PPPoE socket: 00:02:3b:02:68:4b bda0 nas1 0x1000d388
Jan 1 12:35:31> Connect: ppp0 {--} nas1
Jan 1 12:35:39> DSL Carrier is down
Jan 1 12:35:59> DSL Carrier is up
Jan 1 12:35:59> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:36:19> DSL Carrier is down
Jan 1 12:36:29> DSL Carrier is up
Jan 1 12:36:29> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:36:29> pppd 2.4.1 started by root, uid 0
Jan 1 12:36:29> Got connection: b1a3
Jan 1 12:36:29> Saved Session ID: 0
Jan 1 12:36:29> Connecting PPPoE socket: 00:02:3b:02:68:4b b1a3 nas1 0x1000d388
Jan 1 12:36:29> Connect: ppp0 {--} nas1
Jan 1 12:37:11> Got connection: c3a5
Jan 1 12:37:11> Saved Session ID: 0
Jan 1 12:37:11> Connecting PPPoE socket: 00:02:3b:02:68:4b c3a5 nas1 0x1000d388
Jan 1 12:37:11> Connect: ppp0 {--} nas1
Jan 1 12:37:19> DSL Carrier is down
Jan 1 12:37:39> DSL Carrier is up
Jan 1 12:37:39> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:37:39> pppd 2.4.1 started by root, uid 0
Jan 1 12:38:09> DSL Carrier is up
Jan 1 12:38:09> sar read trained mode (1)(ADSL_G.dmt)
Jan 1 12:38:09> pppd 2.4.1 started by root, uid 0
Jan 1 12:38:10> Got connection: aaa8
Jan 1 12:38:10> Saved Session ID: 0
Jan 1 12:38:10> Connecting PPPoE socket: 00:02:3b:02:68:4b aaa8 nas1 0x1000d388
Jan 1 12:38:10> Connect: ppp0 {--} nas1
Jan 1 12:38:11> default route ioctl(SIOCADDRT): Network is unreachable(128)
Jan 1 12:38:50> Connection terminated.
Jan 1 12:38:50> Doing disconnect
Jan 1 12:38:51> pppd 2.4.1 started by root, uid 0
Jan 1 12:38:51> Got connection: bbaa
Jan 1 12:38:51> Saved Session ID: 0
Jan 1 12:38:51> Connecting PPPoE socket: 00:02:3b:02:68:4b bbaa nas1 0x1000d388
Jan 1 12:38:51> Connect: ppp0 {--} nas1
Jan 1 12:38:59> DSL Carrier is down
Hartelijk dank bij voorbaat,
Verbeeren Roy
