Autoforward of mails
Mickal
Hi,
I will soon end my SurfADSL subscription - from surfadsl.net I can't set up an autoforward of my mails... Is there anyway to set it up, so I can forward my @surfadslmail to my gmail, when my subscription ends?
Thanks
MaRtO
Google is my best friend!
PowerSoft
Bedankt: 3 keer
MaRtO schreef:Google is my best friend!
you idiot, help or sfu
well if it was up to me, I would not use my e-mail of surfadsl after subscription, if you cancel your subscription you also cancel your e-mail
from previous experencies with scarlet they could claim that you cancelled your subscription but kept using it
I'm currently cancelling my subscription with Scarlet and I will make sure not a single scarlet service is used after the expiration date (or however you call it, my english s****, that I must admit :) )
Mickal
Thanks for the input PowerSoft.
It was not to continue the use the @surfadsl mail - but rather to pick up those mails from people, that might have forgot to change the emailaddress.
I had no problem understanding your english :-D - you should see how it is her (close to Liège :eek: )
Sub Zero
Bedankt: 121 keer
I would suggest you start mailing people that you mail address has been changed and that they shoudl you your gmail account in the future.
Forwarding the mail from your surfadsl mail is the same as using it normally...
Robbe
El Robre
El Robre
Twitter: infocaris
Sub Zero schreef:I would suggest you start mailing people that you mail address has been changed and that they shoudl you your gmail account in the future.
That would be the best thing to do, since you won't be able to forward @surfadsl mails after your account has been closed down.
Since your email account will disappear at the same moment your account closes.
I would advise you to start using your Gmail account instead of the ones you'll get from your ISP (present and future).
