ipcop en realdsl
BMaster
Bedankt: 45 keer
Ik heb al enkele weken problemen met mijn realdsl verbinding. Volgens realdsl support (karel dus) heeft belgacom de lijn nagekeken en is die perfect in orde. Ik gebruik ipcop en een speedtouch 530 modem (modem in bridged stand). Hieronder staat een stuk logging.. kan iemand mij helpen?
Jul 1 18:14:04 gateway ipcop: Dialling RealDSL.
Jul 1 18:14:04 gateway pppd[828]: pppd 2.4.2 started by root, uid 0
Jul 1 18:14:04 gateway pppd[828]: using channel 4
Jul 1 18:14:04 gateway pppd[828]: Using interface ppp0
Jul 1 18:14:04 gateway pppd[828]: Connect: ppp0 <--> /dev/pts/0
Jul 1 18:14:04 gateway pppoe[830]: PADS: Service-Name: ''
Jul 1 18:14:04 gateway pppoe[830]: PPP session is 17642
Jul 1 18:14:05 gateway pppd[828]: sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x5c6dd5b7>]
Jul 1 18:14:05 gateway pppd[828]: rcvd [LCP ConfAck id=0x1 <mru 1492> <magic 0x5c6dd5b7>]
Jul 1 18:14:06 gateway pppd[828]: rcvd [LCP ConfReq id=0x2 <mru 1492> <auth pap> <magic 0xbf1cd74a>]
Jul 1 18:14:06 gateway pppd[828]: sent [LCP ConfAck id=0x2 <mru 1492> <auth pap> <magic 0xbf1cd74a>]
Jul 1 18:14:06 gateway pppd[828]: sent [LCP EchoReq id=0x0 magic=0x5c6dd5b7]
Jul 1 18:14:06 gateway pppd[828]: sent [PAP AuthReq id=0x1 user="<hidden>" password=<hidden>]
Jul 1 18:14:06 gateway pppd[828]: rcvd [LCP EchoRep id=0x0 magic=0xbf1cd74a]
Jul 1 18:14:06 gateway pppd[828]: rcvd [PAP AuthAck id=0x1 ""]
Jul 1 18:14:06 gateway pppd[828]: PAP authentication succeeded
Jul 1 18:14:06 gateway pppd[828]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Jul 1 18:14:06 gateway pppd[828]: rcvd [IPCP ConfReq id=0x1 <addr 193.27.64.78>]
Jul 1 18:14:06 gateway pppd[828]: sent [IPCP ConfAck id=0x1 <addr 193.27.64.78>]
Jul 1 18:14:06 gateway pppd[828]: rcvd [IPCP ConfNak id=0x1 <addr 83.217.93.41> <ms-dns1 217.22.57.155> <ms-dns3 217.22.5
7.129>]
Jul 1 18:14:06 gateway pppd[828]: sent [IPCP ConfReq id=0x2 <addr 83.217.93.41> <ms-dns1 217.22.57.155> <ms-dns3 217.22.5
7.129>]
Jul 1 18:14:07 gateway pppd[828]: rcvd [LCP EchoReq id=0x1 magic=0xbf1cd74a d9 16 39 9b]
Jul 1 18:14:07 gateway pppd[828]: sent [LCP EchoRep id=0x1 magic=0x5c6dd5b7 d9 16 39 9b]
Jul 1 18:14:08 gateway pppd[828]: rcvd [IPCP ConfReq id=0x2 <addr 193.27.64.78>]
Jul 1 18:14:08 gateway pppd[828]: sent [IPCP ConfAck id=0x2 <addr 193.27.64.78>]
Jul 1 18:14:09 gateway pppd[828]: sent [IPCP ConfReq id=0x2 <addr 83.217.93.41> <ms-dns1 217.22.57.155> <ms-dns3 217.22.5
7.129>]
Jul 1 18:14:10 gateway pppd[828]: rcvd [IPCP ConfReq id=0x3 <addr 193.27.64.78>]
Jul 1 18:14:10 gateway pppd[828]: sent [IPCP ConfAck id=0x3 <addr 193.27.64.78>]
Jul 1 18:14:12 gateway pppd[828]: sent [IPCP ConfReq id=0x2 <addr 83.217.93.41> <ms-dns1 217.22.57.155> <ms-dns3 217.22.5
7.129>]
Jul 1 18:14:12 gateway pppd[828]: rcvd [IPCP ConfReq id=0x4 <addr 193.27.64.78>]
Jul 1 18:14:12 gateway pppd[828]: sent [IPCP ConfAck id=0x4 <addr 193.27.64.78>]
Jul 1 18:14:14 gateway pppd[828]: rcvd [IPCP ConfReq id=0x5 <addr 193.27.64.78>]
Jul 1 18:14:14 gateway pppd[828]: sent [IPCP ConfAck id=0x5 <addr 193.27.64.78>]
Jul 1 18:14:15 gateway pppd[828]: sent [IPCP ConfReq id=0x2 <addr 83.217.93.41> <ms-dns1 217.22.57.155> <ms-dns3 217.22.5
7.129>]
Jul 1 18:14:16 gateway pppd[828]: rcvd [IPCP ConfReq id=0x6 <addr 193.27.64.78>]
Jul 1 18:14:16 gateway pppd[828]: sent [IPCP ConfAck id=0x6 <addr 193.27.64.78>]
Jul 1 18:14:17 gateway pppd[828]: rcvd [LCP EchoReq id=0x2 magic=0xbf1cd74a d9 16 39 9b]
Jul 1 18:14:17 gateway pppd[828]: sent [LCP EchoRep id=0x2 magic=0x5c6dd5b7 d9 16 39 9b]
Jul 1 18:14:18 gateway pppd[828]: sent [IPCP ConfReq id=0x2 <addr 83.217.93.41> <ms-dns1 217.22.57.155> <ms-dns3 217.22.5
7.129>]
Jul 1 18:14:18 gateway pppd[828]: rcvd [IPCP ConfReq id=0x7 <addr 193.27.64.78>]
Jul 1 18:14:18 gateway pppd[828]: sent [IPCP ConfAck id=0x7 <addr 193.27.64.78>]
Jul 1 18:14:20 gateway pppd[828]: rcvd [IPCP ConfReq id=0x8 <addr 193.27.64.78>]
Jul 1 18:14:20 gateway pppd[828]: sent [IPCP ConfAck id=0x8 <addr 193.27.64.78>]
Jul 1 18:14:21 gateway pppd[828]: sent [IPCP ConfReq id=0x2 <addr 83.217.93.41> <ms-dns1 217.22.57.155> <ms-dns3 217.22.5
7.129>]
Jul 1 18:14:22 gateway pppd[828]: rcvd [IPCP ConfReq id=0x9 <addr 193.27.64.78>]
Jul 1 18:14:22 gateway pppd[828]: sent [IPCP ConfAck id=0x9 <addr 193.27.64.78>]
Jul 1 18:14:24 gateway pppd[828]: sent [IPCP ConfReq id=0x2 <addr 83.217.93.41> <ms-dns1 217.22.57.155> <ms-dns3 217.22.5
7.129>]
Jul 1 18:14:24 gateway pppd[828]: rcvd [IPCP ConfReq id=0xa <addr 193.27.64.78>]
Jul 1 18:14:24 gateway pppd[828]: sent [IPCP ConfAck id=0xa <addr 193.27.64.78>]
Jul 1 18:14:26 gateway pppd[828]: sent [LCP EchoReq id=0x1 magic=0x5c6dd5b7]
Jul 1 18:14:27 gateway pppd[828]: sent [IPCP ConfReq id=0x2 <addr 83.217.93.41> <ms-dns1 217.22.57.155> <ms-dns3 217.22.5
7.129>]
Jul 1 18:14:28 gateway pppd[828]: rcvd [LCP EchoReq id=0x3 magic=0xbf1cd74a d9 16 39 9b]
Jul 1 18:14:28 gateway pppd[828]: sent [LCP EchoRep id=0x3 magic=0x5c6dd5b7 d9 16 39 9b]
Jul 1 18:14:30 gateway pppd[828]: sent [IPCP ConfReq id=0x2 <addr 83.217.93.41> <ms-dns1 217.22.57.155> <ms-dns3 217.22.5
7.129>]
Jul 1 18:14:33 gateway pppd[828]: sent [IPCP ConfReq id=0x2 <addr 83.217.93.41> <ms-dns1 217.22.57.155> <ms-dns3 217.22.5
7.129>]
Jul 1 18:14:36 gateway pppd[828]: IPCP: timeout sending Config-Requests
Jul 1 18:14:36 gateway pppd[828]: sent [LCP TermReq id=0x2 "No network protocols running"]
Jul 1 18:14:38 gateway pppd[828]: rcvd [LCP EchoReq id=0x4 magic=0xbf1cd74a d9 16 39 9b]
Jul 1 18:14:39 gateway pppd[828]: sent [LCP TermReq id=0x3 "No network protocols running"]
Jul 1 18:14:42 gateway pppd[828]: Connection terminated.
Jul 1 18:14:42 gateway pppd[828]: Waiting for 1 child processes...
Jul 1 18:14:42 gateway pppd[828]: script /usr/sbin/pppoe -p /var/run/pppoe.pid -I eth2 -T 80 -U -m 1412, pid 830
Jul 1 18:14:42 gateway pppoe[830]: read (asyncReadFromPPP): Session 17642: Input/output error
Jul 1 18:14:42 gateway pppoe[830]: Sent PADT
Jul 1 18:14:42 gateway pppd[828]: Script /usr/sbin/pppoe -p /var/run/pppoe.pid -I eth2 -T 80 -U -m 1412 finished (pid 830
), status = 0x1
Jul 1 18:14:42 gateway pppd[828]: Exit.
asansi - werk
Enig idee wat het probleem is / was?
Ik heb sinds gisteren ook problemen met mijn realdsl verbinding. :(
Tot hiertoe wel al heel tevreden van geweest hoor, daar niet van.
Maar nu zijn het Adsl2fit achtige toestanden, nl ong 50% van de packets die gedropt worden. Pingtijden blijven wel mooi, maar op deze manier connecties leggen (laat staan gamen) is dus uitgesloten. (grote verschil is dat ik bij realroot wel antwoord krijg als ik bel :))
k heb ook al belgacom gebeld, maar daar wist men mij te zeggen dat het adsl signaal geen problemen vertoonde.
Mijn vraag is dus : zijn er sinds kort nog mensen die problemen met hun realdsl lijn ondervinden?
BMaster
Bedankt: 45 keer
Dat is dan toch nog een ander probleem dan bij mij. ALS ik verbinding heb is er geen packetloss voor zover ik weet. Maar het duurt soms uren vooralleer ik verbinding krijg. Belgacom heeft mijn lijn nagezien, en die is ok. Nu is Telenet Solutions het aan het bekijken. Ik moet hen terugbellen als de lijn nog eens down gaat.
Gast
BMaster schreef:Ik heb al enkele weken problemen met mijn realdsl verbinding. Volgens realdsl support (karel dus) heeft belgacom de lijn nagekeken en is die perfect in orde. Ik gebruik ipcop en een speedtouch 530 modem (modem in bridged stand).
Wat gebeurt er als je je Speedtouch op PPPoE zet i.p.v. bridge, en hem rechtstreeks aansluit op een standalone-pc, zonder router tussen de Speedtouch en de pc dus?
BMaster
Bedankt: 45 keer
hetzelfde: verbinding gedurende een aantal uren en dan plots niks meer, en ook niet meer binnen geraken (althans voor zover ik kan zien - veel logging geeft dat spel niet)
asansi - werk
Bij mij was het dus idd iets anders.. probleem is ondertussen al opgelost bij mij... Wat het was weet ik niet direct, maar k ben al blij dat ik weer stabiel kan internetten.
Voor u (bmaster) zal het dus idd iets anders zijn...
Anders moet je zelf ook nog eens naar belgacom bellen? Niet dat karel niet te vertrouwen is hoor, maar k heb eerder mijn twijfels bij de belgacom mensen. ook al verschillende keren voorgehad dat bij den ene technieker alles in orde was, toch blijven terugbellen en iemand anders aan de lijn krijgen, en die zien plots problemen.... lijkt mij vrij raar...
Enig idee hoever je van de centrale zit?
t'is dat je zegt dat het soms uren duurt eer je een verbinding krijgt... doet er mij aan denken dat het eerder met het adsl signaal zelf zit. (bv slechte patching op de belgacomcentrale ofzo, ook al meerdere keren voorgehad)
k vermoed dat je ook al eens een andere modem hebt geprobeerd om zeker te zijn dat het geen hardware issue is?
Ook al getest zonder de ipcop ertussen vermoed ik...
BMaster
Bedankt: 45 keer
Lijn zou in orde zijn, dat bevestigde de persoon van Telenet Solutions mij. En nee geen idee hoever ik zit.. ik woon in 't centrum van Lier, dus zover zal 't wel neit zijn :-)
Als het aan het adsl signaal ligt, zou ik dan niet zonder sync zitten op die momenten dat het niet werkt? Want de sync blijft wel mooi in orde..
en een andere modem zou ik graag proberen, maar niet iedereen heeft 2 adsl modems, en van iemand eentje lenen is niet evident want er is niemand die ik ken die een paar dagen zonder internet kan zitten :-/
en zonder ipcop geeft idd hetzelfde fenomeen. Ook als de modem zelf inbelt, en de pc dus niets doet, gebeurt hetzelfde..
Terug naar “RealDSL”
