Telemeter problems?
Shnoob
Well I dont know whats going on but everytime I check the telemeter everyday my usage is on 0. Now thats good if I knew it really was :) Ive been dling everyday so this makes no sence. Is the telemeter counting my traffic and not reporting it to me or is it just not working all together. I dont want to dl 15gigs and then go on small band you know ;) Anybody else have this problem?
thx
(43.97 KiB) 76 keer gedownload
ubremoved_983
Bedankt: 46 keer
I work with telenet, it's possible that your Telemeter isn't counting ! If you send me your login in private i can check it for you ! Just be aware ... mostly after you reset your modem your telemeter will start counting !
Atm there are no problems with telemeter (as in major outage)
It seems it's f.cked up for your account... keep it a secret and enjoy it 8)
spacekiek
Bedankt: 17 keer
I would suggest ... shut up about it and LEAVE it that way!!! :-D
Damn you're so lucky ... if it stays like this, I would use it to my advantage :-D
But your luck may run out when Telenet installs a new 'Telemeter' in the summer of 2005... that glitch will probably be gone by then ...
Shnoob
cool :-D
thx for the replies
