In perfect werkende staat en verzending is inbegrepen in de prijs (via Homerr)
Bieden vanaf 125 & meeneemprijs = 140
Staat ook op tweakers/beyondgaming/2dehands te koop
7,3TB written data
S.M.A.R.T. test resultaat:
Model Name, Samsung SSD 990 PRO 2TB
Serial Number, *******7983P
Drive Type, NVMe
Result,Byte End,Byte Start,Description,Raw Data,Status
,0,0,Critical Warning,0,OK
,2,1,Temperature (K),303,OK
,3,3,Available Spare,100,OK
,4,4,Available Spare Threshold,10,OK
,5,5,Percentage Used,0,OK
,47,32,Data Units Read,4176850,OK
,63,48,Data Units Written,15644430,OK
,79,64,Host Read Commands,95594166,OK
,95,80,Host Write Commands,94565243,OK
,111,96,Controller Busy Time,67,OK
,127,112,Power Cycles,403,OK
,143,128,Power On Hours,7974,OK
,159,144,Unsafe Shutdowns,142,OK
,175,160,Media Errors,0,OK
,191,176,Number of Error Information Log Entries,1,OK
,195,192,Warning Composite Temperature Time,0,OK
,199,196,Critical Composite Temperature Time,0,OK
,201,200,Temperature Sensor 1,303,OK
,203,202,Temperature Sensor 2,308,OK
,205,204,Temperature Sensor 3,0,OK
,207,206,Temperature Sensor 4,0,OK
,209,208,Temperature Sensor 5,0,OK
,211,210,Temperature Sensor 6,0,OK
,213,212,Temperature Sensor 7,0,OK
,215,214,Temperature Sensor 8,0,OK
Toegevoegd na 2 uren 13 minuten 54 seconden:
verkocht via tweakers mag op slot
[Te koop] Samsung 990 Pro (zonder heatsink) 2TB
- RandomUsername4
- Bedankt: 1 keer
i used to sleep at night
