Test
Wil je gewoon eens testen of je klaar bent om te posten? Doe dit dan hier.
JoskeVermeulen
Bedankt: 131 keer
:troosten:
Bedankt: 3934 keer
Recent bedankt: 15 keer
wow (test gelukt?) :-)
Moonboy
Bedankt: 42 keer
Orbital position 192:
19.2E Astra 1KR/1L/1M/1N, Low Band, V:
Tested 1 transponders
1 (100 %) transponders succeeded
0 (0 %) transponders failed
Successfully tuned transponders' previous planes:
No transponder tuned ==> 19.2E Astra 1KR/1L/1M/1N, Low Band, V
complete transponderlist:
(10758.0, 22000.0, 1, 2, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_state': 'LOCKED', 'tuner_locked': 1, 'tuner_synced': 1, 'tuner_bit_error_rate': 0, 'tuner_signal_quality': 46652, 'tuner_signal_power': 1949}
19.2E Astra 1KR/1L/1M/1N, Low Band, H:
19.2E Astra 1KR/1L/1M/1N, Low Band, V ==> 19.2E Astra 1KR/1L/1M/1N, Low Band, H
(10773.0, 22000.0, 0, 3, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_state': 'LOCKED', 'tuner_locked': 1, 'tuner_synced': 1, 'tuner_bit_error_rate': 0, 'tuner_signal_quality': 40877, 'tuner_signal_power': 2604}
19.2E Astra 1KR/1L/1M/1N, High Band, V:
19.2E Astra 1KR/1L/1M/1N, Low Band, H ==> 19.2E Astra 1KR/1L/1M/1N, High Band, V
(11739.0, 27500.0, 1, 3, 2, 192, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_state': 'LOCKED', 'tuner_locked': 1, 'tuner_synced': 1, 'tuner_bit_error_rate': 0, 'tuner_signal_quality': 45997, 'tuner_signal_power': 1949}
19.2E Astra 1KR/1L/1M/1N, High Band, H:
19.2E Astra 1KR/1L/1M/1N, High Band, V ==> 19.2E Astra 1KR/1L/1M/1N, High Band, H
(11758.0, 27500.0, 0, 9, 2, 192, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_state': 'LOCKED', 'tuner_locked': 1, 'tuner_synced': 1, 'tuner_bit_error_rate': 0, 'tuner_signal_quality': 41860, 'tuner_signal_power': 65520}
Orbital position 235:
23.5E Astra 3B/3C, High Band, H:
19.2E Astra 1KR/1L/1M/1N, High Band, H ==> 23.5E Astra 3B/3C, High Band, H
(11720.0, 30000.0, 0, 3, 2, 235, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_state': 'LOCKED', 'tuner_locked': 1, 'tuner_synced': 1, 'tuner_bit_error_rate': 0, 'tuner_signal_quality': 47758, 'tuner_signal_power': 1949}
23.5E Astra 3B/3C, High Band, V:
23.5E Astra 3B/3C, High Band, H ==> 23.5E Astra 3B/3C, High Band, V
(11739.0, 29900.0, 1, 3, 2, 235, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_state': 'LOCKED', 'tuner_locked': 1, 'tuner_synced': 1, 'tuner_bit_error_rate': 0, 'tuner_signal_quality': 43785, 'tuner_signal_power': 639}
Orbital position 282:
28.2E Astra 2E/2F/2G, Low Band, H:
23.5E Astra 3B/3C, High Band, V ==> 28.2E Astra 2E/2F/2G, Low Band, H
(10714.0, 22000.0, 0, 4, 2, 282, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_state': 'LOCKED', 'tuner_locked': 1, 'tuner_synced': 1, 'tuner_bit_error_rate': 0, 'tuner_signal_quality': 65535, 'tuner_signal_power': 3915}
28.2E Astra 2E/2F/2G, Low Band, V:
28.2E Astra 2E/2F/2G, Low Band, H ==> 28.2E Astra 2E/2F/2G, Low Band, V
(10788.0, 23000.0, 1, 3, 2, 282, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_state': 'LOCKED', 'tuner_locked': 1, 'tuner_synced': 1, 'tuner_bit_error_rate': 0, 'tuner_signal_quality': 56196, 'tuner_signal_power': 3260}
28.2E Astra 2E/2F/2G, High Band, H:
28.2E Astra 2E/2F/2G, Low Band, V ==> 28.2E Astra 2E/2F/2G, High Band, H
(11758.0, 27500.0, 0, 2, 2, 282, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_state': 'LOCKED', 'tuner_locked': 1, 'tuner_synced': 1, 'tuner_bit_error_rate': 0, 'tuner_signal_quality': 59391, 'tuner_signal_power': 1949}
28.2E Astra 2E/2F/2G, High Band, V:
28.2E Astra 2E/2F/2G, High Band, H ==> 28.2E Astra 2E/2F/2G, High Band, V
(11778.0, 27500.0, 1, 2, 2, 282, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_state': 'LOCKED', 'tuner_locked': 1, 'tuner_synced': 1, 'tuner_bit_error_rate': 0, 'tuner_signal_quality': 60824, 'tuner_signal_power': 639}
Tested and approved by Ultimo 4K
Flippi
Bedankt: 117 keer
philippe_d schreef: 22 okt 2024, 18:28
Even testen als een reply met full quote van een tabel ook de test doorstaat.
Terug naar “Test”
