12 in 1 docking station (USB 3.1, 2 DP 1.4, USB-C, PD 100W, ethernet 1000 Mbps,...) 59,49 € ALL-IN (PROMO)
Hierin kan je goede deals melden aan je mede-userbase leden
Bedankt: 412 keer
https://www.amazon.de/dp/B0BCDFFY7V?psc ... ct_details
Toch echt goede specs voor zijn prijs. Geen betere voor die prijs gevonden op Ali.
  • 12-in-1 USB C Docking Station: Higher specs, more stable performance. 4K USB C Hub has 2 higher specification displayports and 1 HDMI, 1 RJ45, 10Gbps USB C and USB A 3.1, 1 SD and TF 4.0, 1 PD charging port, 3.5mm Mic/audio and 2 USB 2.0. Please make sure your laptop's USB C port is Thunderbolt 3/4 or supports DisplayPort mode, if you are not sure you can check with us.
  • Triple Monitor Visual Experience: Under the DP 1.4 source, 4K@60Hz is supported when connecting ONE monitor via dual DP docking station. DP 1.2 supports 4K@30Hz only. Please note: macOS does not support extended mode.
  • 10G Fast Data Transfer Dock: This USB C Docking Station comes with USB A 3.1 and USB C 3.1 with a max speed of 10Gbps to transfer large files and games in few second. There are also two USB 2.0 ports where you can connect a wireless mouse or keyboard. Please note: This USB C Adapter is not compatible with Logitech wireless devices.
  • USB C to SD 4.0 and Gigabit Ethernet ports: This Dual DisplayPort USB C Hub has higher specification SD/TF card reader slots with reading speed up to 250Mb/s, transferring your photos more conveniently and both card slots can be read at the same time. Dongle also has stable network ports supports 10/100/ 1000BASE-T Lan networks, no need to worry about the instability of WiFi.
  • 100W PD Charging and 3.5mm Mic/Audio Port: When Triple Display USB C Dock is connected to multiple devices, please connect the power supply to ensure enough power to work. PD port is compatible with up to 100W input and 87W (Safty) to charge your computer. Plug your headphones into the 3.5mm Mic/Audio Port and enjoy lossless music quality.
  • What You Get: 1 * USB C Docking Station, 1 * manual. 24-hour service, 30 days free-use and 18 months technical-support. Please note: The DP port cannot be connected to other ports via the converter! For example HDMI or VGA!
gunmaster
Bedankt: 64 keer
De vraag is natuurlijk hoe goed dat zou werken...
Ik heb er van I-TEC, €140 en daarmee een minderheid van een deftige Dell dock.
Alleen continue problemen met de scherm resolutie. Allemaal heel jammer...
Bedankt: 623 keer
je screenshot toont 2x hdmi & 1x DP, maar de link spreekt over 2x DP en 1x hdmi ?
ben zelf wel benieuwd, want ik werk hier met een dock (ook i-tec als ik me niet vergis), en heb soms wel problemen dat de laptop zoiets heeft van "mwoah, ik ga even het dock niet detecteren"....
na 10x uitpluggen en terug inpluggen werkt het dan weer wel, en eigenlijk volledig probleemloos... maar toch,
als er een beter dock is.. :)
Abusimbal
Bedankt: 121 keer
Prijs is gunstig maar onbekend merk. Is opletten met garantie en inderdaad werking/compatibiliteit.
Dan zou ik toch iets bijleggen en voor een Anker gaan.
https://www.amazon.de/Anker-Datenports- ... 81&sr=1-22
Ik heb zelf ook goede ervaringen met Ugreen USB docks/hubs en opladers (GaN)
Anker heeft nu ook monitorstand met ingebouwde USB hub en Qi lader. Wel duur.
https://www.amazon.de/Anker-Anschl%C3%B ... C79&sr=1-2
Samsung Galaxy S25 Ultra
Ubiquiti UDM Pro
Synology DS1821+
Nvidia Shield TV console
Microsoft Surface Pro 8
Garmin Venu3
Nexus1980
Bedankt: 39 keer
Laat je weten satsurfer hoe je het product ervaart? Ik ben namelijk ook geinteresseerd.
Dima_2005
Bedankt: 264 keer
Er zijn veel goede hubs op amazon. En heel waarschijnlijk is deze ook gewoonweg goed... En als het niet in orde is, stuur je gewoon terug.
Heb persoonlijk deze voor 30 euro gekocht en heel tevreden
USB C Hub HDMI Adapter, Dockplug 5-in-1 Dock USB C Adapter to 3 USB 3.0, 4K 60Hz HDMI, 100W PD, for MacBook Pro/Air M1/M2, iPad Pro, iPad Mini 6, Surface Pro, Steam Deck Docking Station DD. 0008 https://amzn.eu/d/g3rHnEx
Voor mij persoonlijk was belangrijkste 4k 60hz en 100w pd. En dat was niet zo simpel te vinden.... Maar ja, vraag is wat wil je hebben, deze dock heb ik altijd mee, zo een grote zou ik eerder niet meenemen.
Terug naar “Goede deals”
