Collisions - dunno where they came from:
|T-J|
for about half a year i have my own firewall pc running with devil-linux and in the beginning all went fine.
but then, i started having problems without having changed any of the settings done by configuring.
I never got away with the problem and now my 1mbit cable is slower then a 56k because of collisions.
the firewall works with 2 nic's
eth0 : i-net comes in, recieves IP from DHCP from ISP
eth1 : this is the router of the firewall, and passes out the internal IP's to the rest of machines.
now the odd thing is that the card having collisions is eth0 and that s**** tbh.
eht0 = realtek NIC
eht1 = 3com NIC
I have also tried changing the nics from PCI-slots which hasn't helped me much.
hereby comes another odd but verry annoying problem, IRQ problems.
since I'm a fan of the rtl chipset on NIC's I have 3 realtek nic's but the problem is that when I insert 2 RTL nic's in the firewall he has a problems with IRQ.
it seems to me that the computer gives the 2 pci's NIC's the same IRQ which isn't correct cause with sharing IRQ's my firewall software doesn' tknow which one is eth1 or eht0 and so the firewall doesn't work.
my guestion is,
1) how do I get rid of the collisions?
2) how do I get my computer to give a non-sharing IRQ to my 2nd RTL nic
Next odd thing is that apparently no matter how much collisions I get, when only 2 computers are connected the speed doesn't suffer under it.
but from the moment a third pc gets his IP from the firewall, speed goes down the drain with it.
P.S: het is in het engels omdat ik deze topic copy-paste naar nog andere forums voor oplossingen te vinden en deze zijn niet nederlands-talig.
trobbelke
ik vermoed een kapotte netwerkkaart...
|T-J|
trobbelke schreef:ik vermoed een kapotte netwerkkaart...
denk niet dat het dit is omdat als ik de nic's verander van plaats en dus bv. de 3com eht0 maak en de RTL eht1 maak, de 3com dan de collisions heeft ipv de RTL die er dan geen meer heeft.
de collisions gebeuren dus van de modem naar de nic op de firewall, gelijkwelke deze is.
kan het zijn dat mijn (inmiddels 2.5 jaar oude) UTP kabel wat aan de slechte hand is en dit problemen geeft?
Sensei Zeon
dat is altijd mogelijk
heb je doe zelf gemaakt? of gekocht? als hij gekocht is: hebben ze hem in de winkel gemaat (dus de plugskes erop geknepen)?
want zo het een zelfgemaakte/in de winkel zelfgemaakte kabel is, is het zeker mogelijk, toch als er niet heel voorzichtig met omgegaan is
|T-J|
de kabel is in orde.
heb dus nog altijd geen gedacht wat de collisions doet voorkomen.
het probleem met de IRQ's is opgelost, geen problemen meer daarmee.
trobbelke
al eens een andere modem geprobeerd?
|T-J|
trobbelke schreef:al eens een andere modem geprobeerd?
atm zit ik met een telenetmodem, dus ik kan die niet zomaar vervangen :s
trobbelke
bij zulke collisions moet ge aan defecte hardware denken, aabgezien het niet aan uw netwerkkaart ligt, moet ge uw kabelmodem controleren, die dingen kunnen ook kapot gaan. Ge zult 'em moeten laten controleren door Telenet...
