PHP : Loop in een multidimensional associative array
helmuteke
Bedankt: 27 keer
Doordat ik geen vragen meer mag stellen in stackoverflow , is er mss hier iemand die me kan helpen.
Heb al veel doorgelezen maar het lukt me niet om een Foreach te doen voor onderstaande array
Dit is de dump van de array :
 Array ( [0] => Array ( [datum] => 20-03-2017 [soort] => unavailability [reden] => Vakantie [gepstart] => 09:00:00 [gepstop] => 16:36:00 [actstart] => 09:00:00 [actstop] => 16:36:00 ) [1] => Array ( [datum] => 21-03-2017 [soort] => shift [reden] => [gepstart] => 09:00:00 [gepstop] => 17:00:00 [actstart] => 09:00:00 [actstop] => 16:30:00 ) [2] => Array ( [datum] => 21-03-2017 [soort] => break [reden] => [gepstart] => 12:30:00 [gepstop] => 13:00:00 [actstart] => 12:30:00 [actstop] => 13:00:00 ) [3] => Array ( [datum] => 22-03-2017 [soort] => shift [reden] => [gepstart] => 08:30:00 [gepstop] => 16:30:00 [actstart] => 08:30:00 [actstop] => 17:30:00 ) [4] => Array ( [datum] => 22-03-2017 [soort] => break [reden] => [gepstart] => 12:30:00 [gepstop] => 13:00:00 [actstart] => 12:30:00 [actstop] => 13:00:00 ) [5] => Array ( [datum] => 23-03-2017 [soort] => shift [reden] => [gepstart] => 08:00:00 [gepstop] => 16:30:00 [actstart] => 08:00:00 [actstop] => 16:30:00 ) [6] => Array ( [datum] => 23-03-2017 [soort] => break [reden] => [gepstart] => 12:30:00 [gepstop] => 13:00:00 [actstart] => 12:30:00 [actstop] => 13:00:00 ) [7] => Array ( [datum] => 24-03-2017 [soort] => shift [reden] => [gepstart] => 09:30:00 [gepstop] => 17:00:00 [actstart] => 09:00:00 [actstop] => 17:00:00 ) [8] => Array ( [datum] => 24-03-2017 [soort] => break [reden] => [gepstart] => 12:30:00 [gepstop] => 13:00:00 [actstart] => 12:30:00 [actstop] => 13:00:00 ) [9] => Array ( [datum] => 25-03-2017 [soort] => unavailability [reden] => Thuis [gepstart] => 07:00:00 [gepstop] => 07:00:00 [actstart] => [actstop] => ) [10] => Array ( [datum] => 26-03-2017 [soort] => unavailability [reden] => Thuis [gepstart] => 07:00:00 [gepstop] => 07:00:00 [actstart] => [actstop] => ) )
Nu zou ik een foreach loop willen van deze array waarin ik telkens dan een volledige print maakt van de elementen
vb 0 - datum - soort -. . . . .
1 - datum - soort - . . . . .
nu de print kan ik wel zelf coderen maar die foreach lukt echt niet
Alvast bedankt
http://php.net/manual/en/control-structures.foreach.php
Wat je zoekt is het stukje... Unpacking nested arrays with list().
Bedankt: 1975 keer
Gaat dat zo ook niet:
foreach ($mijnarray as $element => $data) {
    echo $element . " - " . $data['datum'] . " - " . $data['soort'] . " - " . $data['reden'] . " - " . $data['gepstart'] . " - " . $data['gepstop'] . " - " . $data['actstart'] . " - " . $data['actstop'] . "\r\n";
helmuteke
Bedankt: 27 keer
raf1 schreef:Gaat dat zo ook niet:
Dit deed het . Nu toch eens zoeken waar ik fout zat.
Nu is de volgende stap om deze array te hergroeperen.
ipv
0 - 20-03-2017 - unavailability - Vakantie - 09:00:00 - 16:36:00 - 09:00:00 - 16:36:00
1 - 21-03-2017 - shift - - 09:00:00 - 17:00:00 - 09:00:00 - 16:30:00
2 - 21-03-2017 - break - - 12:30:00 - 13:00:00 - 12:30:00 - 13:00:00
3 - 22-03-2017 - shift - - 08:30:00 - 16:30:00 - 08:30:00 - 17:30:00
4 - 22-03-2017 - break - - 12:30:00 - 13:00:00 - 12:30:00 - 13:00:00
5 - 23-03-2017 - shift - - 08:00:00 - 16:30:00 - 08:00:00 - 16:30:00
zou ik deze wensen
20-03-2017	- 0 - unavailability - Vakantie - 09:00:00 - 16:36:00 - 09:00:00 - 16:36:00
21-03-2017	- 0 - shift - - 09:00:00 - 17:00:00 - 09:00:00 - 16:30:00
			- 1 - break - - 12:30:00 - 13:00:00 - 12:30:00 - 13:00:00
22-03-2017  - 0 - shift - - 08:30:00 - 16:30:00 - 08:30:00 - 17:30:00
nu moet dit lukken met een soort van usort , dus effe zoeken
of lui als ik ben weten jullie mss dit ook . . .
EDIT : of zoals dit een beetje :
Of gewoon een nested foreach ?
foreach ($mijnarray as $element => $mijndata) {
  echo $element;
  foreach ($mijndata as $data) {
    echo " - " . $data ;
  echo "\r\n";
Terug naar “Development”
