Iemand een idee wat deze werken zullen inhouden? Momenteel heb ik dit profiel:
B-Box 3 Sagem Tool v0.12.0
Device: B-Box 3 Sagem
Downstream current bit rate: 99 999 kbps
Upstream current bit rate: 20 000 kbps
Downstream max bit rate: 139 940 kbps
Upstream max bit rate: 34 240 kbps
Downstream attenuation: 8,6 dB
Downstream noise margin: 18,8 dB
Upstream noise margin: 14,0 dB
Vectoring down: yes
Vectoring up: yes
Modem vectoring compatible: yes
ROP vectoring compatible: yes
DSL standard: VDSL2
DSL profile: 17a
Estimated distance: 149 m
Proximus profile name: 100/20
Proximus DLM profile: yes
Proximus repair profile: no
