systeminfo /FO CSV /NHzonder parameters doet hij het dus perfect, maar met parameters geeft hij gewoon al output het command zelf
Ook Shell() heeft geen soelaas gebracht.
Heeft iemand ervaring met uitvoering van (DOS) commands?
Private Sub MenuItem5_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MenuItem5.Click
TextBox1.Text = ExecuteApp("systeminfo")
FileOpen(1, "c:\output.txt", OpenMode.Output)
PrintLine(1, TextBox1.Text)
FileClose(1)
End Sub
Public Function ExecuteApp(ByVal cmd As String) As String
Dim output As String
Dim errors As String
'create a tempfilecollection for output and error messages
Dim tf As New System.CodeDom.Compiler.TempFileCollection()
'execute the command
System.CodeDom.Compiler.Executor.ExecWaitWithCapture(cmd, tf, output, errors)
'read the file with the output of the command and return its content
Dim sr As System.IO.StreamReader = System.IO.File.OpenText(output)
ExecuteApp = sr.ReadToEnd
sr.Close()
'Delete the temporary files
System.IO.File.Delete(output)
System.IO.File.Delete(errors)
End Function
