b-box 2: IPTV and internet out through a single Homeplug?
raymallon
Hello all
First post here. Scot living in Belgium, so apologies for the post in English.
I've been a belgacom customer for 3 or so years, and have recently moved into a house. The layout means that cabling between the b-box 2 and the TV decoder isn't an option, so I've been looking into Homeplugs as a solution.
The floors are concrete, so wifi reception upstairs is nonexistent in places, so I've been looking at Homeplugs with wifi for that too.
To avoid having to have two separate Homeplug sets in operation, I was wondering if it's possible to get the IPTV and internet signals out of the router via a single port? I see that certain Homeplugs (e.g. those made by Billion) are able to carry more than one source.
Thanks very much in advance for any help/views.
Bedankt: 3918 keer
Recent bedankt: 20 keer
The default set-up with the B-box2 is that Internet and IPTV are separated networks. Internet on LAN1 + 2, IPTV on LAN 3 + 4.
In this case you need 2 sets of homeplugs. This is called "briged mode" (as IPTV is "bridged" to the TV VLAN30).
However, there is an option to set-up your B-box2 in operating mode "fully routed"
In this set-up, you can connect all Belgacom TV decoders to your home network. The settopboxes will receive an IP adress in the home network (192.168.1.64, 192.168.1.65, etc), and will be "routed" tot the TV VLAN
In this case, you only need 1 set of homeplugs (and a switch if you need more devices connected to the homeplug).
Please note that some customers have reported issues with a b-box2 in fully routed mode (nPVR not working properly)
A more suitable (and stable) solution is to use a b-box3, as the default set-up for a b-box3 is "IPTV fully routed".
I'm surprised that you did not receive a b-box3, which should nowadays be the standard modem for new subscriptions.
jackho
Bedankt: 279 keer
I'm not surprised, many new subscribers report that they still get a B-Box2 and also an old decoder V3 for IPTV !!!!!!
raymallon
Thank you, Philippe, for the swift reply.
I simply did a home move with Belgacom, keeping existing number and equipment. A b-box 3 would have been good though.
Would the FritzBox be another solution? Or are tv and Internet still on separate networks there as well?
When you speak about a switch, where would that fit in the wiring setup? Would it be: WAN > b-box 2 > Switch > Homeplug 1 // Homeplug 2 > TV decoder // Homeplug 3 (wifi enabled) > PC ?
Thanks again
Raymond
ubremoved_15739
Bedankt: 532 keer
jackho schreef:I'm not surprised, many new subscribers report that they still get a B-Box2 and also an old decoder V3 for IPTV !!!!!!
Natuurlijk: De uier van de Belgacom-koe is leeggemolken.
Raymond: ik ga die hele tekst wel niet voor u vertalen hé. :wink:
Na drie jaar in België te wonen zal je wel alles al verstaan, veronderstel ik. 8)
raymallon
Geen probleem. They'd rather put the money towards salaries / perks for the management and dividends for the "shareholders" than put it towards b-box 3s for loyal customers forking out funny money per month for the services.
Bedankt: 3918 keer
raymallon schreef:Would the FritzBox be another solution? Or are tv and Internet still on separate networks there as well?
Not really.
The FritzBox is simulating the B-box2 setup with separate networks.
raymallon schreef:When you speak about a switch, where would that fit in the wiring setup? Would it be: WAN > b-box 2 > Switch > Homeplug 1 // Homeplug 2 > TV decoder // Homeplug 3 (wifi enabled) > PC ?
Switch is not needed in above setup - just if you need more than 1 PC wired behind Homeplug 3.
jackho
Bedankt: 279 keer
there are also homeplugs with more than one UTP connector output e.g. devolo-dlan-500-av-(wireless)
