Moederbord : MSI C847MS-E33
Voeding : Corsair HX650 (ms vervangen door een 430)
Extra sata controller 1 : HighPoint Rocket 640L - Storage controller (RAID) - 4 Kanaal - SATA 6Gb/s low profile - 600 MBps - RAID 0, 1, JBOD - PCIe 2.0 x4
Extra sata controller 2 : ? vanonder het stof gehaald.
OS : Openmediavault (debian)
HDs :
3x hotswap in de case.
7x Hotswap icy box ib-170sk-b
Probleem :
Schijven gaan offline.
[ 1255.169349] sd 7:0:0:0: [sdd] CDB: Read(16): 88 00 00 00 00 01 5d 50 a3 88 00 00 00 08 00 00
[ 1255.169366] end_request: I/O error, dev sdd, sector 5860533128
[ 1255.169445] __ratelimit: 40 callbacks suppressed
[ 1255.169449] Buffer I/O error on device sdd, logical block 732566641
[ 1255.171078] sd 7:0:0:0: [sdd] Unhandled error code
[ 1255.171083] sd 7:0:0:0: [sdd] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.171088] sd 7:0:0:0: [sdd] CDB: Read(10): 28 00 00 00 09 00 00 00 08 00
[ 1255.171101] end_request: I/O error, dev sdd, sector 2304
[ 1255.171177] Buffer I/O error on device sdd, logical block 288
[ 1255.171343] sd 7:0:0:0: [sdd] Unhandled error code
[ 1255.171346] sd 7:0:0:0: [sdd] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.171351] sd 7:0:0:0: [sdd] CDB: Read(10): 28 00 00 00 08 40 00 00 08 00
[ 1255.171361] end_request: I/O error, dev sdd, sector 2112
[ 1255.171435] Buffer I/O error on device sdd, logical block 264
[ 1255.171615] sd 7:0:0:0: [sdd] Unhandled error code
[ 1255.171618] sd 7:0:0:0: [sdd] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.171622] sd 7:0:0:0: [sdd] CDB: Read(10): 28 00 00 00 08 10 00 00 08 00
[ 1255.171633] end_request: I/O error, dev sdd, sector 2064
[ 1255.171707] Buffer I/O error on device sdd, logical block 258
[ 1255.171813] sd 7:0:0:0: [sdd] Unhandled error code
[ 1255.171816] sd 7:0:0:0: [sdd] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.171821] sd 7:0:0:0: [sdd] CDB: Read(10): 28 00 00 00 08 10 00 00 08 00
[ 1255.171831] end_request: I/O error, dev sdd, sector 2064
[ 1255.171904] Buffer I/O error on device sdd, logical block 258
[ 1255.172007] sd 7:0:0:0: [sdd] Unhandled error code
[ 1255.172009] sd 7:0:0:0: [sdd] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.172014] sd 7:0:0:0: [sdd] CDB: Read(10): 28 00 00 00 08 10 00 00 08 00
[ 1255.172024] end_request: I/O error, dev sdd, sector 2064
[ 1255.172097] Buffer I/O error on device sdd, logical block 258
[ 1255.172198] sd 7:0:0:0: [sdd] Unhandled error code
[ 1255.172201] sd 7:0:0:0: [sdd] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.172205] sd 7:0:0:0: [sdd] CDB: Read(10): 28 00 00 00 08 10 00 00 08 00
[ 1255.172215] end_request: I/O error, dev sdd, sector 2064
[ 1255.172288] Buffer I/O error on device sdd, logical block 258
[ 1255.179808] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.179814] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.179819] sd 6:0:0:0: [sdc] CDB: Read(16): 88 00 00 00 00 01 d1 c0 be 88 00 00 00 08 00 00
[ 1255.179836] end_request: I/O error, dev sdc, sector 7814037128
[ 1255.179915] Buffer I/O error on device sdc, logical block 976754641
[ 1255.180269] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.180273] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.180277] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 09 00 00 00 08 00
[ 1255.180289] end_request: I/O error, dev sdc, sector 2304
[ 1255.180363] Buffer I/O error on device sdc, logical block 288
[ 1255.181090] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.181094] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.181099] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 08 40 00 00 08 00
[ 1255.181111] end_request: I/O error, dev sdc, sector 2112
[ 1255.181186] Buffer I/O error on device sdc, logical block 264
[ 1255.182239] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.182244] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.182248] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 0a 00 00 00 08 00
[ 1255.182260] end_request: I/O error, dev sdc, sector 2560
[ 1255.191530] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.191536] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.191542] sd 6:0:0:0: [sdc] CDB: Read(16): 88 00 00 00 00 01 d1 c0 be 00 00 00 00 08 00 00
[ 1255.191559] end_request: I/O error, dev sdc, sector 7814036992
[ 1255.191701] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.191706] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.191711] sd 6:0:0:0: [sdc] CDB: Read(16): 88 00 00 00 00 01 d1 c0 bd a8 00 00 00 08 00 00
[ 1255.191728] end_request: I/O error, dev sdc, sector 7814036904
[ 1255.191838] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.191841] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.191846] sd 6:0:0:0: [sdc] CDB: Read(16): 88 00 00 00 00 01 d1 c0 be 70 00 00 00 08 00 00
[ 1255.191861] end_request: I/O error, dev sdc, sector 7814037104
[ 1255.191984] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.191987] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.191992] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[ 1255.192002] end_request: I/O error, dev sdc, sector 56
[ 1255.192098] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192101] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192105] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[ 1255.192115] end_request: I/O error, dev sdc, sector 56
[ 1255.192208] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192210] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192215] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[ 1255.192225] end_request: I/O error, dev sdc, sector 56
[ 1255.192317] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192320] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192324] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[ 1255.192334] end_request: I/O error, dev sdc, sector 56
[ 1255.192427] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192430] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192434] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[ 1255.192444] end_request: I/O error, dev sdc, sector 120
[ 1255.192536] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192539] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192543] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[ 1255.192554] end_request: I/O error, dev sdc, sector 120
[ 1255.192647] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192650] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192654] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[ 1255.192664] end_request: I/O error, dev sdc, sector 120
[ 1255.192758] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192761] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192765] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[ 1255.192775] end_request: I/O error, dev sdc, sector 120
[ 1255.192893] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.192896] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.192900] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[ 1255.192911] end_request: I/O error, dev sdc, sector 56
[ 1255.193003] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.193006] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.193010] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 38 00 00 08 00
[ 1255.193021] end_request: I/O error, dev sdc, sector 56
[ 1255.193112] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.193115] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.193119] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[ 1255.193129] end_request: I/O error, dev sdc, sector 120
[ 1255.193652] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.193655] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.193660] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 78 00 00 08 00
[ 1255.193670] end_request: I/O error, dev sdc, sector 120
[ 1255.193772] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.193775] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.193779] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.193789] end_request: I/O error, dev sdc, sector 64
[ 1255.193880] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.193883] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.193887] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.193897] end_request: I/O error, dev sdc, sector 64
[ 1255.193988] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.193991] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.193995] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194005] end_request: I/O error, dev sdc, sector 64
[ 1255.194094] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.194097] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.194101] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194111] end_request: I/O error, dev sdc, sector 64
[ 1255.194202] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.194204] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.194210] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194221] end_request: I/O error, dev sdc, sector 64
[ 1255.194470] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.194474] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.194478] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194488] end_request: I/O error, dev sdc, sector 64
[ 1255.194580] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.194583] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.194587] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194597] end_request: I/O error, dev sdc, sector 64
[ 1255.194687] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.194690] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.194694] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194704] end_request: I/O error, dev sdc, sector 64
[ 1255.194794] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.194797] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.194801] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194811] end_request: I/O error, dev sdc, sector 64
[ 1255.194900] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.194903] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.194907] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 00 40 00 00 08 00
[ 1255.194918] end_request: I/O error, dev sdc, sector 64
[ 1255.195008] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195010] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195015] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 01 00 00 00 08 00
[ 1255.195025] end_request: I/O error, dev sdc, sector 256
[ 1255.195115] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195118] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195122] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 01 00 00 00 08 00
[ 1255.195132] end_request: I/O error, dev sdc, sector 256
[ 1255.195222] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195225] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195229] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 01 08 00 00 08 00
[ 1255.195240] end_request: I/O error, dev sdc, sector 264
[ 1255.195329] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195332] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195336] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 01 08 00 00 08 00
[ 1255.195347] end_request: I/O error, dev sdc, sector 264
[ 1255.195436] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195439] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195444] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 01 10 00 00 08 00
[ 1255.195454] end_request: I/O error, dev sdc, sector 272
[ 1255.195543] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195546] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195551] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 01 10 00 00 08 00
[ 1255.195561] end_request: I/O error, dev sdc, sector 272
[ 1255.195652] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195655] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195659] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 03 00 00 00 08 00
[ 1255.195669] end_request: I/O error, dev sdc, sector 768
[ 1255.195760] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195763] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195767] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 03 00 00 00 08 00
[ 1255.195777] end_request: I/O error, dev sdc, sector 768
[ 1255.195867] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195870] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195874] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 03 08 00 00 08 00
[ 1255.195884] end_request: I/O error, dev sdc, sector 776
[ 1255.195974] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.195977] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.195981] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 03 08 00 00 08 00
[ 1255.195991] end_request: I/O error, dev sdc, sector 776
[ 1255.196082] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.196084] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.196089] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 03 10 00 00 08 00
[ 1255.196099] end_request: I/O error, dev sdc, sector 784
[ 1255.196189] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.196191] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.196196] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 03 10 00 00 08 00
[ 1255.196206] end_request: I/O error, dev sdc, sector 784
[ 1255.196309] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.196312] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.196316] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 02 00 00 00 08 00
[ 1255.196326] end_request: I/O error, dev sdc, sector 512
[ 1255.196426] sd 6:0:0:0: [sdc] Unhandled error code
[ 1255.196429] sd 6:0:0:0: [sdc] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 1255.196433] sd 6:0:0:0: [sdc] CDB: Read(10): 28 00 00 00 10 00 00 00 08 00
[ 1255.196443] end_request: I/O error, dev sdc, sector 4096Toen dacht ik dat het aan de icyboxes zou gelegen hebben (stroomschommelingen ofzo). Is getest, kan niet.
Nu denk ik dat het aan de sata controller ligt.
onboard(sataII) -> pci-e(sataIII) = miserie. <- kan ook omgekeerde volgorde zijn.
onboard(sataII) -> onboard(sataII) = succes.
pci-e(sataIII) -> pci-e(sataIII) = volgende test.
Zal dus eens naar de firmware/drivers van die kaart moeten kijken.
http://www.highpoint-tech.com/USA_new/s ... wnload.htm
Native linux support. Driver piste dus uitgesloten.
Sta open voor tips
