Fritzbox 7390 and new firmware
bombus
I have a fritz box 7390 , new firmware , if I want to increase the stability ,or inp , (e.g) , rthe Belgacom line is out (the stabililty is also awful) Do you have such problems.
Thanks in advance
bombus
Back to old firmware everything ok !
fryelectro
Bedankt: 177 keer
I don't have stability issues (I do see some Errors (ES)at the "DSL Telephone switch" which I've never seen before) with the new firmware BUT since I applied it, a few hours later I was forced back to my provisiong profile of 30/6 instead of 70/6... It is not sure that the firmware upgrade has something to do with it, but in the three years I am connected to VDSL2, I was never set on a lower profile....
Orange Go Extreme
bombus
For my own part the profile in snr was doing "yoyo" . In order to stabilise I did what I always did and then no connxion at all . As a result two interventions of a technician and two ports out , so I go back to the old firmware and no problem anymore
So I think there is a problem !
Bedankt: 3939 keer
Recent bedankt: 19 keer
If you really want some help from the Forum community, you should give a few more details of your xDSL subscription, e.g.
  • - are you ADSL2+ or VDSL2 ?
    - what is your modem sync speed?
    - line values (attenuation, snr)?
    - last but not least: how does your internal wiring look like (starting from the Belgacom wallplate, splitter/filter, etc ..)
I don't believe your problems are related to the fritzBox firmware!
bombus
So
I am in VDS2, distance from the ROP followin g Hierzo : 354 m , followin Belgacom 498 m
You'll find here after all my data
Sorry but my Nederlands is niet goed
The problems came when I did the upgrade and I want to stabilise my line
Thank you for your help
PS no problem (physical problem on my line) but a "perturbating neighbour" normally SNR equal to to 20 dB but I have this problem.
All the data are very good except this
(106.92 KiB) 1637 keer gedownload
snakeboots
Here also with the new firmware two VDSL ports out of service by playing with the increase the stability function. Now I'm using my b-box2 in bridge mode and all works smoothly.
