Loop probleem bij edpnet?
Loeri
Bedankt: 25 keer
Zo te zien kan k me thuis server niet meer bereiken maar wel de router als ik vanaf hier een traceroute doe ziet het eruit alsof er een router (of wat het ook is :roll: ) in een loop zit bij Edpnet?
Traceroute:
 1   <1 ms   <1 ms   <1 ms  192.168.0.1
  2    56 ms    16 ms    17 ms  10.75.63.17
  3     *       19 ms    18 ms  lag-101-1000.epemar2.isp.belgacom.be [91.183.246.153]
  4    18 ms    25 ms    19 ms  lag-29-1000.iprmar1.isp.belgacom.be [91.183.246.152]
  5    18 ms    18 ms    18 ms  lag-26-1000.ibrmar2.isp.belgacom.be [91.183.246.141]
  6    19 ms    18 ms    19 ms  edpnet.bnix.net [194.53.172.89]
  7    22 ms    21 ms    21 ms  85.234.208.54.static.edpnet.net [85.234.208.54]
  8    23 ms    23 ms    22 ms  85.234.208.53.wls.msr04lge3.adsl.dyn.edpnet.net [85.234.208.53]
  9    25 ms    25 ms    25 ms  85.234.208.54.static.edpnet.net [85.234.208.54]
 10    26 ms    26 ms    26 ms  85.234.208.53.wls.msr04lge3.adsl.dyn.edpnet.net [85.234.208.53]
 11    29 ms    28 ms    29 ms  85.234.208.54.static.edpnet.net [85.234.208.54]
 12    30 ms    29 ms    30 ms  85.234.208.53.wls.msr04lge3.adsl.dyn.edpnet.net [85.234.208.53]
 13    32 ms    32 ms    32 ms  85.234.208.54.static.edpnet.net [85.234.208.54]
 14    34 ms    33 ms    33 ms  85.234.208.53.wls.msr04lge3.adsl.dyn.edpnet.net [85.234.208.53]
 15    36 ms    36 ms    36 ms  85.234.208.54.static.edpnet.net [85.234.208.54]
 16    37 ms    37 ms    37 ms  85.234.208.53.wls.msr04lge3.adsl.dyn.edpnet.net [85.234.208.53]
 17    39 ms    39 ms    40 ms  85.234.208.54.static.edpnet.net [85.234.208.54]
 18    40 ms    41 ms    41 ms  85.234.208.53.wls.msr04lge3.adsl.dyn.edpnet.net [85.234.208.53]
 19    43 ms    43 ms    43 ms  85.234.208.54.static.edpnet.net [85.234.208.54]
 20    44 ms    44 ms    44 ms  85.234.208.53.wls.msr04lge3.adsl.dyn.edpnet.net [85.234.208.53]
 21    47 ms    47 ms    47 ms  85.234.208.54.static.edpnet.net [85.234.208.54]
 22    48 ms    47 ms    48 ms  85.234.208.53.wls.msr04lge3.adsl.dyn.edpnet.net [85.234.208.53]
 23    51 ms    50 ms    52 ms  85.234.208.54.static.edpnet.net [85.234.208.54]
 24    59 ms    51 ms    52 ms  85.234.208.53.wls.msr04lge3.adsl.dyn.edpnet.net [85.234.208.53]
 25    54 ms    54 ms    54 ms  85.234.208.54.static.edpnet.net [85.234.208.54]
 26    55 ms    55 ms    55 ms  85.234.208.53.wls.msr04lge3.adsl.dyn.edpnet.net [85.234.208.53]
 27    58 ms    58 ms    58 ms  85.234.208.54.static.edpnet.net [85.234.208.54]
 28    59 ms    58 ms    59 ms  85.234.208.53.wls.msr04lge3.adsl.dyn.edpnet.net [85.234.208.53]
 29    61 ms    61 ms    62 ms  85.234.208.54.static.edpnet.net [85.234.208.54]
 30    62 ms    63 ms    62 ms  85.234.208.53.wls.msr04lge3.adsl.dyn.edpnet.net [85.234.208.53]
gunmaster
Bedankt: 74 keer
Als jij een statisch ip hebt lijkt dat jou router zelf te zijn..
Van mijn telenet naar mijn edpnet (static)
Traceren van de route naar ip.wapclan.net [85.234.198.49]
via maximaal 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.2
2 8 ms 4 ms 5 ms d54C5D001.access.telenet.be [84.197.208.1]
3 8 ms 6 ms 8 ms dD5E0C561.access.telenet.be [213.224.197.97]
4 7 ms 7 ms 7 ms dD5E0F619.access.telenet.be [213.224.246.25]
5 9 ms 8 ms 7 ms dD5E0FD11.access.telenet.be [213.224.253.17]
6 10 ms 9 ms 8 ms edpnet.bnix.net [194.53.172.89]
7 10 ms 14 ms 10 ms router01.sn.edpnet.net [212.71.1.61]
8 8 ms 9 ms 18 ms 212.71.17.2.res.static.edpnet.net [212.71.17.2]
9 31 ms 31 ms 31 ms 85.234.198.49.static.edpnet.net [85.234.198.49]
De trace is voltooid.
C:\Users\lars>
Probeer anders eens andere gebruikers met een static IP bij EDPnet uit? Hier heb je er alvast een paar...
Mijn router : edpnet.gw.be.it2go.eu
Mijn /26 iprange : gw.be.it2go.eu
En probeer eens www.nexa.be te pingen?
Loeri
Bedankt: 25 keer
Ik heb geen static ip maar een dynamisch ip van Edpnet.
Wat wel weer raar is, is dat mijn ipv4 adres op de xDsl pagina van Edpnet weeral verdwenen is zoals een paar weken geleden.
Pingen en traceroutes vanop een andere plaats leveren net hetzelfde op.
Edit: Blijkt nu wel weer te werken :beerchug:
Terug naar “EDPnet (LaTribu)”
