New with version 74.05.23:
DSL: New DSL-Version with active G.INP and Interop-fixes (Broadcom)
Internet: New - Access your FRITZ!Box from anywhere in the world with MyFRITZ!
Internet: New - possiblity to modify DNS-Server for IPv4 and IPv6
Internet: New - configure automatic fallback to 3G if ADSL is not working
Internet: New - settings to use other IPv6 routers in your networkg
Internet: New - DynDNS-support for IPv6 via dyndns.org and namemaster.de
Internet: New - IPv6-Support for uPnP, uPnP/Av and TR-064
Internet: New - support for exposed host and ping6 in IPv6 settings
Internet: New - NetBIOS-Filter can be deaktivated if necessay
Internet: setup of Internet-access remade
Internet: improved performance for Internet via LAN
Internet: completed DNSSEC support
Internet: improved error-handling for DynDNS
Internet: improved internet page loading with activated child-protection
Internet: robustness of IPv6-firewall improvied
Internet: leading zeros in Interface-Identifier of IPv6 firewall rules accepted again
Internet: improved 3G-stability
Internet: fix for inactivity timeout
Internet: LUA-error when deleting a user with actived child-protection fixed
Internet: traceroute and ping from two local clients to one remote server fixed
WLAN: New - possiblity to give feedback for every Wifi-devices added
WLAN: WLAN stability improved
WLAN: configure display of WLAN dis-/connections in systemlog
WLAN: added message if 5Ghz channel is used by radar
WLAN: spaced before and after he Wifi-key are filtered to improve Windows compatibility
Telephony: New - prioritise voip-packets when using FRITZ!App Fon
Telephony: IMS-support for "implicit registration"
Telephony: improved telephone book import
Telephony: display own telephone-number on IP-telephones
Telephony: display new message on answering-machine on IP-telephones (MWI)
Telephony: Email-setup for integrated fax reception simplified
Telephony/DECT: disconnects of DECT-calls with activated "busy on busy" fixed
DECT/FRITZ!Fon: New - background with date and time added
DECT/FRITZ!Fon: New - new start-screen
DECT/FRITZ!Fon: New - use Internetradio for alarm
DECT/FRTIZ!Fon: New - signalling of incoming calls with bigger font size
DECT/FRITZ!Fon: New - new midi-ringtones
DECT/FRITZ!Fon: New - assign ringtones to specific telephone-book entries
DECT/FRITZ!Fon: performance increased for podcasts and internetradio
DECT/FRITZ!Fon: general interop with DECT handsets improved
Home Network: NEW - custom FRITZ!Box name for the Home Network, Mediaserver, DECT-Base-Station and WLAN-SSID
Home Network: NEW - Internetzugang for guests on LAN 4, securely seperated from the home network
Home Network: NEW - display of guest devices in the network overview (WLAN and LAN)
Home Network: NEW - grouping of network devices (active, guests and unused)
Home Network: NEW - in the network overview, devices reachable over http are now clickable
Home Network: NEW - automatic Wake on LAN from the Internet (supporting IPv6)
Home Network: NEW - display of FRITZ!Powerline devices in the network overview and on the FRITZ!Box main page
Home Network: NEW - details for network devices is showing additional properties, including IPv6 adresses
System: NEW - display name of your FRITZ!Box and FRITZ!OS version on fritz.box
System: NEW - new Online-help with search and navigation
System: NEW - simplified setup of usernames (passwords shown in plain text during setup)
System: NEW - simplified change between Standard- and advanced pages
System: NEW - new page myfritz.box: Caller Lists and answering machine
System: NEW - mobile versions of fritz.box and myfritz.box for Smartphones
System: NEW - Push-Mail contains current IP-address
System: NEW - Push-Mail contains detailed DSL-information
System: DNS-server of FRITZ!Box improved (DNS über TCP)
System: UPnP-sharing for port 49200 restricted to the homenetwork
System: IPv6-firewall-settings for VoIP added
System: removed repeating password-challenge on FTPS access
USB: All-in-One printer only need activation of the type "printer" for the USB remote access
USB: performance improvements for USB-drives.Performance-Verbesserungen bei der Nutzung des USB-Speichers
USB: Stabilität beim Abziehen von USB-Speichern erhöht
NAS: NEW - configurable workgroup name
NAS: faster indexing of the drive for the internet share
NAS: improved handling when USB-drives are removed while indexing is running
NAS: new content for the internal storage memory [write protected]
NAS: improved interoperability with Internet Explorer 9
NAS: new smb version for improved security
NAS: Notification in the user interface for USB devices with excess power requirements
Mediaserver: NEW Playlist support added (alphabetically)
Mediaserver: improved interoperability (Sony TV, Kathrein-Receiver, Xbox..)
Mediaserver: performance optimizations
Mediaserver: better handling of special characters, i.e in MP3-Album covers and JPG files.
Mediaserver: Mediaserver-drive will now be indexed first
Mediaserver: UPnP-search for containers within a container fixed
Mediaserver: Problem fixed where MP3-album-covers and scaled JPG-files could not be accessed reliably with an active share
Mediaserver: sorting in the view "Files" alphabetically (file name)
Mediaserver: sorting in the view "Album" by ID3 - field "Track-Number"
Mediaserver: sorting in all other views by ID3- "Title"
UMTS: fixed problem while establishing a UMTS-connection
UMTS: improved support of some UMTS-sticks with CSV support
UMTS: improved Modem-interoperability (i.e. ZTE K4505-Z, Sierra USB 309, 4G Systems XS Stick P14)
UMTS: display of the current active connection type (HSPA, UMTS, GPRS etc.) in the user interface.
UMTS: displays "no service" when there is no connection to the mobile network
UMTS: improved reliability for establishing an internet connection after pulling and plugging an UMTS-stick
