EDPNET geen internet
Geplaatst: 20 maa 2010, 11:01
#sh dsl int atm0/0
Alcatel 20150 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT)
ITU STD NUM: 0x01 0x1
Vendor ID: 'ALCB' 'ALCB'
Vendor Specific: 0x0000 0x0000
Vendor Country: 0x00 0x0F
Capacity Used: 69% 69%
Noise Margin: 15.0 dB 16.0 dB
Output Power: 20.0 dBm 12.0 dBm
Attenuation: 32.5 dB 17.0 dB
Defect Status: None None
Last Fail Code: None
Selftest Result: 0x00
Subfunction: 0x15
Interrupts: 6981 (0 spurious)
PHY Access Err: 0
Activations: 1
Init FW: embedded
Operation FW: embedded
SW Version: 3.8131
FW Version: 0x1A04
Interleave Fast Interleave Fast
Speed (kbps): 0 6144 0 640
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 0 0 0
Header Errors: 0 0 0 0
Bit Errors: 0 0
BER Valid sec: 0 0
BER Invalid sec: 0 0
DMT Bits Per Bin
00: 0 0 0 0 0 0 0 4 4 5 7 8 9 9 9 9
10: A A A 9 9 9 9 9 9 8 7 7 7 7 0 0
20: 0 0 0 0 0 0 2 2 3 4 5 5 6 6 6 7
30: 7 8 8 9 9 9 A A A A B B B B B 9
40: 8 B B B B B B B B B B 2 B B B B
50: B B B B A 7 A A B B B B B B B B
60: B B A A A A A A A A 7 A A A A A
70: A A A A A A A A A A A A A A A 7
80: 9 A 9 9 9 9 9 9 9 9 9 9 9 9 9 9
90: 7 9 9 9 8 8 8 8 8 8 8 8 8 8 8 8
A0: 8 8 8 8 8 8 8 8 8 8 8 8 8 7 7 7
B0: 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7
C0: 7 7 7 7 6 6 6 6 6 6 6 6 6 6 6 6
D0: 6 6 6 6 6 6 6 4 6 5 5 5 5 5 5 5
E0: 5 5 5 4 4 5 5 5 5 5 5 5 5 5 5 4
F0: 4 4 4 4 4 3 2 2 0 2 0 0 0 0 0 0
Log file of training sequence:
** HS DL notify state *** enter : -1431655766
Sachem device 0 succesfully initialized !
disable Receive Soc channel.
AME:HsDetector::stopDetection
** HS DL notify state *** enter : 0
Configure Downstream Channel
fw version: 1.1.1
Installing initial TEQ coefficients
AFE:2dB boost
setMaskMain on interruptDispatcher
Nominal TX gain ...
AFE:2dB boost
RMS line single = 411.059
PeerModemDetector: new gain = 1155 /100
PeerModemDetector: new gain = 1855 /100
Hs:doing power measurement on C-TONES
AME:HsDetector::startDetection
dyn threshold: -160.000
......Code: Selecteer alles
#sh ip int brief
Interface IP-Address OK? Method Status Protocol
ATM0/0 unassigned YES NVRAM up up
Ethernet0/0 212.71.19.x YES NVRAM up up
Serial0/1 unassigned YES NVRAM administratively down down
Virtual-Access1 unassigned YES unset up up
Virtual-Access2 unassigned YES unset up up
Dialer0 213.219.170.x YES IPCP up up
Tunnel2002 unassigned YES NVRAM up up
