EDPNET geen internet
Ofloo
Bedankt: 92 keer
#sh dsl int atm0/0
Alcatel 20150 chipset information
		ATU-R (DS)			ATU-C (US)
Modem Status:	 Showtime (DMTDSL_SHOWTIME)
DSL Mode:	 ITU G.992.1 (G.DMT)
ITU STD NUM: 	 0x01				 0x1
Vendor ID:	 'ALCB'				 'ALCB'
Vendor Specific: 0x0000				 0x0000
Vendor Country:	 0x00				 0x0F
Capacity Used:	 69%				 69%
Noise Margin:	 15.0 dB			 16.0 dB
Output Power:	 20.0 dBm			 12.0 dBm
Attenuation:	 32.5 dB			 17.0 dB
Defect Status:	 None                            None
Last Fail Code:	 None
Selftest Result: 0x00
Subfunction:	 0x15
Interrupts:	 6981 (0 spurious)
PHY Access Err:	 0
Activations:	 1
Init FW:	 embedded
Operation FW:	 embedded
SW Version:	 3.8131
FW Version:	 0x1A04
		 Interleave		Fast	Interleave		Fast
Speed (kbps):	          0	        6144	         0	         640
Reed-Solomon EC:          0	           0	         0	           0
CRC Errors:	          0	           0	         0	           0
Header Errors:	          0	           0	         0	           0
Bit Errors:	          0	           0
BER Valid sec:	          0	           0
BER Invalid sec:          0	           0
DMT Bits Per Bin
00: 0 0 0 0 0 0 0 4 4 5 7 8 9 9 9 9
10: A A A 9 9 9 9 9 9 8 7 7 7 7 0 0
20: 0 0 0 0 0 0 2 2 3 4 5 5 6 6 6 7
30: 7 8 8 9 9 9 A A A A B B B B B 9
40: 8 B B B B B B B B B B 2 B B B B
50: B B B B A 7 A A B B B B B B B B
60: B B A A A A A A A A 7 A A A A A
70: A A A A A A A A A A A A A A A 7
80: 9 A 9 9 9 9 9 9 9 9 9 9 9 9 9 9
90: 7 9 9 9 8 8 8 8 8 8 8 8 8 8 8 8
A0: 8 8 8 8 8 8 8 8 8 8 8 8 8 7 7 7
B0: 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7
C0: 7 7 7 7 6 6 6 6 6 6 6 6 6 6 6 6
D0: 6 6 6 6 6 6 6 4 6 5 5 5 5 5 5 5
E0: 5 5 5 4 4 5 5 5 5 5 5 5 5 5 5 4
F0: 4 4 4 4 4 3 2 2 0 2 0 0 0 0 0 0
Log file of training sequence:
** HS DL notify state *** enter : -1431655766
Sachem device 0 succesfully initialized !
disable Receive Soc channel.
AME:HsDetector::stopDetection
** HS DL notify state *** enter : 0
Configure Downstream Channel
fw version: 1.1.1
Installing initial TEQ coefficients
AFE:2dB boost
setMaskMain on interruptDispatcher
Nominal TX gain ...
AFE:2dB boost
 RMS line single = 411.059
PeerModemDetector: new gain = 1155 /100
PeerModemDetector: new gain = 1855 /100
Hs:doing power measurement on C-TONES
AME:HsDetector::startDetection
dyn threshold: -160.000
#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
ATM0/0                     unassigned      YES NVRAM  up                    up
Ethernet0/0                212.71.19.x    YES NVRAM  up                    up
Serial0/1                  unassigned      YES NVRAM  administratively down down
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access2            unassigned      YES unset  up                    up
Dialer0                    213.219.170.x YES IPCP   up                    up
Tunnel2002                 unassigned      YES NVRAM  up                    up
Het is alsof er geen routing is bij edpnet, .. er zijn geen firmware upgrades gedaan what so ever ik kom gisteren avond thuis en geen internet .. er wordt wel een ip toegewezen maar dat is het dan ook.
FlashBlue
Bedankt: 296 keer
Hier (limburg, maasland) niet direct iets van problemen geweest volgens router logs/graphs.
Wellicht dus een regiogebonden (of zelfs connectiegebonden) probleem, staat er niets op hun wiki ?
(moet wel opmerken dat ik al een heel tijdje ip's uit de 85.234.201.* range krijg - jij zit volgens je screenshot in de 212 ranges, kan dus zijn dat ze op bepaalde ranges routing issue's hebbe, en niet algemeen.)
Ofloo
Bedankt: 92 keer
nee ik heb al aan het kijken geweest, staat niks van op wel iets voor de toekomst maar niks voor van dit weekend.
Ofloo
Bedankt: 92 keer
FlashBlue schreef:Hier (limburg, maasland) niet direct iets van problemen geweest volgens router logs/graphs.
ik heb statische ip's, waarschijnlijk is dat de rede dat ik een andere range heb, ik was ook al aan routing aan het denken, .. omdat ze het aan het overzetten zijn naar BGC heb ik zo'n vermoeden, .. dat ze weer eens aan het prutsen zijn.
Ofloo
Bedankt: 92 keer
TraceRoute to 213.219.170.1x [213.219.170.1x.adsl.static.edpnet.net]
Hop	(ms)	(ms)	(ms)		IP Address	Host name
1	22	23	36		72.249.128.109	-
2	22	19	13		206.123.64.82	-
3	6	11	16		216.52.189.9	border4.te4-4.colo4dallas-5.ext1.dal.pnap.net
4	37	23	14		216.52.191.34	core3.tge5-1-bbnet1.ext1.dal.pnap.net
5	19	14	18		66.79.145.97	dal005-dalext1-846-cr1.dal005.internap.net
6	18	45	24		66.79.147.186	cr2-cr1.dal005.internap.net
7	34	51	38		66.79.147.189	acs007-dal005-841-cr2.acs007.internap.net
8	46	38	37		66.79.147.1	cr1-cr2.acs007.internap.net
9	50	46	45		66.79.147.198	acs007-wdc005-844-cr2.wdc005.internap.net
10	43	42	46		66.79.146.201	cr1-cr2.wdc005.internap.net
11	Timed out	Timed out	Timed out			-
12	176	170	203		212.71.1.13	router01.sn.be.edpnet.net
13	168	176	199		212.71.1.5	router02.bruix.be.edpnet.net
14	213	182	205		212.71.1.70	-
15	Timed out	Timed out	Timed out			-
16	Timed out	Timed out	Timed out			-
17	Timed out	Timed out	Timed out			-
18	Timed out	Timed out	Timed out			-
Trace aborted.
Gatway edpnet
TraceRoute to 213.219.170.1 [213.219.170.1.adsl.static.edpnet.net]
1	8	10	6		72.249.0.65	-
2	10	30	16		206.123.64.22	-
3	12	7	20		216.52.191.98	core3.tge5-2-bbnet2.ext1.dal.pnap.net
4	11	10	23		216.52.191.98	core3.tge5-2-bbnet2.ext1.dal.pnap.net
5	10	28	30		66.79.145.97	dal005-dalext1-846-cr1.dal005.internap.net
6	7	7	6		66.79.147.186	cr2-cr1.dal005.internap.net
7	28	29	38		66.79.147.1	cr1-cr2.acs007.internap.net
8	49	49	48		66.79.147.1	cr1-cr2.acs007.internap.net
9	169	199	48		66.79.147.198	acs007-wdc005-844-cr2.wdc005.internap.net
10	49	65	61		66.79.146.201	cr1-cr2.wdc005.internap.net
11	161	Timed out	Timed out		212.71.1.13	router01.sn.be.edpnet.net
12	160	157	170		212.71.1.5	router02.bruix.be.edpnet.net
13	152	143	159		212.71.1.5	router02.bruix.be.edpnet.net
14	144	146	143		212.71.1.70	-
15	152	143	144		213.219.170.1	213.219.170.1.adsl.static.edpnet.net
Trace complete
brommer
Ik heb 18 dagen zonder internet gezeten door de schuld van Belgacom (probleem met de DSLAM). In eerste fase legt Edpnet de schuld bij de klant en wordt gevraagd de binnenbekabeling te testen. Dan moet je een nieuwe router kopen, de wandcontactdoos en splitter vervangen en uiteindelijk zelfs de RJ11 kabel doorknippen en handmatig vastzetten (dan zit je al op level 2 van de helpdesk uiteraard).
Hoewel het ergens te begrijpen is dat ze willen vermijden dat gebruikers die zelf in de fout gaan meer dan 120€ moeten betalen voor een interventie, moet je als klant toch heel wat moeite doen vooraleer ze een mannetje van Belgacom sturen. Bij mij heeft die affaire inmiddels twee volle werkdagen en een gepeperde telefoonfactuur gekost.
Aansluitend bij de topicstarter en anderen die misschien een soortgelijk probleem zullen hebben in de toekomst, is mijn vraag wat ik als klant kan doen na heel die affaire. Ik kan me toch niet neerleggen bij meer dan een halve maand downtime en veel verspilde tijd en nodeloos gemaakte (telefoon)kosten? Na de eerste week problemen was ik in de verleiding om op te zeggen maar ik had schrik dat ze mij dan gingen verwijten dat ik de binnenbekabeling gesaboteerd heb om weg te kunnen of toch gingen vragen de resterende twee maanden te betalen. Nu ik witgewassen ben denk ik eraan om een maand gratis te vragen maar gezien de lange tijd die het geduurd heeft om dit op te lossen, denk ik nog altijd aan opzeggen. Wat is jullie advies?
FlashBlue
Bedankt: 296 keer
je *moet* niet akkoord gaan met andere modem en bekabeling testen, maar dan zal je wel akkoord moeten gaan dat alle techniekerkosten voor jouw rekening zijn als het daar toch aan blijkt te liggen.
En dat is maar normaal ook infeite, meewerken aan testen, of betalen als iemand het voor je komt doen.
Uitgedeelde bedankjes: 1682 keer
Bedankt: 1476 keer
@ brommer: bereken eens wat dat grapje je in totaal gekost heeft en beslis dan wat je binnen twee maand doet. Ik was ook ooit bij een alternatieve, en daar heb ik op één jaar tijd 120 € uitgespaard en toen ik weg wou uiteindelijk nog 100 € mogen extra betalen wegens problemen bij opzeg en totaal geen blijk van commerciële houding van deze alternatieve provider. Dus uiteindelijk is mijn besparing op dat jaar heel beperkt geweest en heeft het me veel tijd en moeite gekost (ombudsman en gans de bazar). Sindsdien terug bij BGC en heel stabiel, als er factuurproblemen of -vragen zijn altijd een degelijk antwoord. Het is allemaal een kwestie wat voor jou belangrijk is. Zoalng er niks misgaat kan je niet beter zitten dan bij een alternatieve provider...
Funfile
@Brommer : reken niet op ook maar enige tegemoetkoming van EDPnet. Heb helaas vorig jaar ongeveer hetzelfde als jou meegemaakt. Alleen excuses gekregen, verder niks. Gewoon jammer. En nu heb ik de boel opgezegd (na een vijftal jaar klant te zijn geweest).
Ga nu Scarlet nemen (goedkoper en bieden méér voor dat geld - in mijn geval toch).
Pluk de dag
OS : Windows 10, Linux Mint
Ofloo
Bedankt: 92 keer
bij mij was het een route probleem, .. was maandag na verschillende keren bellen opgelost.
brommer
Ik wil Edpnet nog het voordeel van de twijfel geven. Hun helpdesk heeft de zaak altijd heel professioneel afgehandeld. Uiteindelijk is ook gebleken dat het niet hun fout maar die van Belgacom was. Was ik Belgacomklant, het probleem was waarschijnlijk veel sneller opgelost, maar dat praat de overheid noch Belgacom. Dit voorval bewijst opnieuw wat iedere mens met gezond verstand vanop afstand ziet: de marktopening is volledig fout, je kan niet tegelijk operator en infrastructuurbeheerder zijn! Tijd dat ik Quickie daar nog eens mee lastigval!
Ik heb van Edpnet wel de toestemming gekregen voor een creditnota voor de periode zonder internet. Lijkt me de logische gang van zaken. Misschien kan je daar wat mee, Ofloo.
Funfile
@Brommer : Ben blij voor U dat ze U een creditnota hebben toegezegd. Volg het op en hou ze aan hun woord (en hou ons op de hoogte).
Pluk de dag
Terug naar “EDPnet (LaTribu)”
