Mobile Vikings 3G - 25 Maart
Hier kan je alles kwijt over Mobile vikings of Jim mobile (wat een product is van mobile vikings)
ChelloExtremer
Bedankt: 30 keer
Quote van Mobile Vikings:
Some of you have been impatiently waiting to test our 3G service. Starting 25/03/2010 (with 95% certainty, you never know), all Mobile Vikings will be able to use the 3G network. This blog post explains how the introduction will happen.
You do not need to do anything to switch to 3G. Most mobile phones will detect the 3G signal where it is available. If your phone is on “automatic”, it will choose 3G where appropriate and switch to EDGE when needed. In some locations there is a 3G signal, but your phone does not switch to it. It is not advised to configure your phone to manually force a 3G connection in these locations. The connection will be made, but no data will be transported over the connection. Your phone will indicate it is connected, but your web browser will not work. We are writing this explanation in the hope to avoid unnecessary helpdesk calls. If you see people complaining online about the above situation, you can always reply with a link back to this blog post.
If you want to test the connection speed, you will notice it will not exceed 500 Kbps. This is not a limitation of the technology. During the first phase, all connections are restricted to 500Kbps to gradually increase the load on the network. We don’t know yet when this capping will be removed.
As most of you will know, 3G coverage is not available everywhere. We are using the 3G network of KPN Belgium (Base), which is under continuous expansion. Where there is no 3G coverage yet, you can fall back on the reliable EDGE network. For more information regarding network coverage and expansion we refer to the communication of Base.
We hope this information will help us make a nice transition to 3G. We are convinced that the 3G network of Base will soon be up to par. The 2G network is already better than the network of Mobistar and Proximus, as reported by this independent report on network quality: http://mobilevikings.com/media/download ... 09_sam.pdf
silencer
Bedankt: 103 keer
Nu nog wachten op een reactie bij wire-less (volgens de site gaan ze deze maand iets laten weten) en anderen.
gregmans
Uitgedeelde bedankjes: 4 keer
Bedankt: 3 keer
En inderdaad, 3G is er!
Met het binnenrijden in Antwerpen met de trein al van voor Berchem station 3g ontvangst. Deze viel echter terug weg
in de buurt van het Centraal Station.
Maar voor de rest wel perfect 3G ontvangst @ 0,47/0,47 Mbps. :-D
FunkStar
Bedankt: 95 keer
In Roeselare atm nog geen 3G ontvangst terwijl ik weet dat ze gewerkt hebben aan de masten hier voor 3G
BMaster
Bedankt: 46 keer
Sint-katelijne-waver ook (nog?) niets...
www.3gcoverage.net ;-) In Merelbeke (Gent) volop 3G ontvangst, vorige week in Knokke ook al!
Special_K
Mortsel (Antwerpen) 3G sinds deze morgen, wel ff PDA moeten aan en uitschakelen.
AnD
Uitgedeelde bedankjes: 444 keer
Bedankt: 117 keer
Hier in Hasselt nog niet (toch niet met mijn toestel).
texarcanaa
Bedankt: 7 keer
In Brussel (Evere) ook volop 3G ontvangst :-)
Merelbeke-Flora ontvangst binnenhuis (1 streepje)
flt
Bedankt: 4 keer
Ook Merelbeke
flt, van waar in merelbeke ben jij dan?
flt
Bedankt: 4 keer
Ben van Deinze maar passeer nogal veel langs Merelbeke ;)
Speedtest is gedaan op de N60 in Zwijnaarde
Mobile Viking
Bedankt: 7 keer
Hier in de regio Brugge-Kust nog nergens 3G kunnen gebruiken.
Aan het Casino te Knokke heb ik het kunnen gebruiken.
q-tec
Bedankt: 103 keer
flt schreef:Ben van Deinze maar passeer nogal veel langs Merelbeke ;)
hmm in deinze nog niks? ik zit op edge en een kennis zit op 3g (base) en we stonden naast elkaar
(markt)
Belgacom Vdsl 16.5/2
Galys2 + Mobile vikings
flt
Bedankt: 4 keer
(markt)
Nope :(
Niet dat ik het verwacht had in deze wereldstad ( :mrgreen: ) maar raar dat Base wél 3G heeft en MV niet :?
Terug naar “Mobile Vikings, Jim mobile”
