[Te Koop] Humax HDCI-2000 HDtv Sat Receiver
Ken
Bedankt: 113 keer
Toestel die werd gebruikt als demo in een showroom, werkt perfect en is praktisch nieuw inclusief alle originele accessoires.
1 jaar garantie, bieden vanaf 80 EUR. Bieden kan tot maandag 16/03/2009 18:00.
Afhaling mogelijk te Oostende. Verzending 15,00 EUR.
System Resources
- CPU/MPU/Mainchip CX24175-7nM
- Coprocessor CX24182
- Flash memory 4MB
- DDR RAM 64MB+32MB
- EEPROM 8KB
- HDD storage None
Tuner and Channel
- No of tuners: 1
- RF loopthrough connector: F-type, IEC 169-24, female
- Input frequency range: 950 to 2150 MHz
- Signal level: -25 to -75 dBm
- Modulation: DVB-S2 (QPSK & 8PSK)
- Bandwidth: upto 36MHz
- LNB Power & Polarisation: Vertical: +13.5V
Horisontal: +18V
Max current: 500 mA with overload protection
- 22 KHz tone Frequency: 22 +/-4KHz Amplitude: 0.6 +/-0.2 V
- DiSEqC: 1.0, 1.2, USALS compatible
Video & Audio:
- Transport stream: ISO/IEC 13818-1 (MPEG-2 system)
- Video decoding: ISO/IEC 13818-2 (MPEG-2 video) MP@HL, ISO/IEC 14496-10 MPEG-4 AVC/H.264 HP@L4
- Video formats 4:3(default), 16:9 Letterbox
- Video output HDMI/HDCP, CVBS (default), RCA
- Video resolution 1080i, 720p, 576p, 576i, 480p, 480i
- Audio decoding ISO/IEC 13818-3 (MPEG-2 audio / MUSICAM), Dolby AC-3, Dolby Digital+
- Audio mode single / dual mono / stereo / joint stereo
Conditional Access System
- Embedded CAS: None
- Smart card: 0
- Common interface: 2
A/V output
- Digital output: HDMI/HDCP
SPDIF (optical)
- TV SCART: Video output (CVBS, RGB, S-Video) Audio output (resolution: 20 bits DAC, Max. 2Vrms)
- VCR SCART: Video input (CVBS, RGB)
Vidieo output (CVBS)
- Video RCA: 1 output
- Audio RCA: 2 output (left and right)
- Digital audio: 1 optical S/PDIF
Data Port
- RS-232C 9 pin
Front Panel Interface
- Smart card slot: None
- Common interface slot: 2
- Buttons: 8 (Standby/on, TV/Radio, CH-, CH+, Vol-, Vol+)
- Display: VFD display with channel name
Rear Panel Interface
- Main power cable: Fixed tpe on the body
- Tuner and LNB: 1 input with 1 loop through
- RCA: 1 video output, 2 audio output (left and right)
- Data port: 1 RS-232C (9-pin type)
- Digital output: 1 HDMI/HDCP
- S/PDIF: 1 optical output
Power Supply
- Input voltage: AC 90~250, 50/60Hz
- Type: Switching Mode Power Supply (SMPS)
- Power consumption: TBD
- Protection: Separate internal fuse & lightning protection
Physical Specifications
- Size (W x H x D): 380 x 78 x 281 mm
- Weight (net): TBD
- Accessaries: RCU, User's manual, 2 batteries, HDMI-to-HDMI cable
Links ter referentie:
http://www.interactieve-digitale-tv.be/ ... php?p=8080
http://shop.euro1080.tv/product.php?lan ... ticleno=24
http://www.cardwriter-forum.nl/hdtv-ges ... t-1727.htm
Sub Zero
Bedankt: 121 keer
Gesloten op aanvraag van TS. Hij zet ze op ebay.
