Error 0xC80003F3; vista kan niet updaten
Geplaatst: 08 nov 2008, 19:13
door Dfrog
Hallo
De Vista van mijn schoonfamilie wil niet updaten. Hij geeft steeds fout: Er kan niet naar nieuwe updates gezocht worden. Fout: C80003F3. Door windows update is een onbekende fout geconstateerd.
Hieronder de updatelog.
2008-11-08 14:53:21:910 1104 c20 Misc WARNING: Send failed with hr = 80072ee7.
2008-11-08 14:53:21:910 1104 c20 Misc WARNING: SendRequest failed with hr = 80072ee7. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2008-11-08 14:53:21:910 1104 c20 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsu ... uredir.cab>. error 0x8024402c
2008-11-08 14:53:21:910 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x8024402c
2008-11-08 14:53:21:910 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x8024402c
2008-11-08 14:53:21:910 1104 c20 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x8024402c
2008-11-08 14:53:24:478 1104 c20 Misc WARNING: Send failed with hr = 80072ee7.
2008-11-08 14:53:24:479 1104 c20 Misc WARNING: SendRequest failed with hr = 80072ee7. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2008-11-08 14:53:24:479 1104 c20 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsu ... uredir.cab>. error 0x8024402c
2008-11-08 14:53:24:479 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x8024402c
2008-11-08 14:53:24:479 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x8024402c
2008-11-08 14:53:24:479 1104 c20 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x8024402c
2008-11-08 14:53:27:055 1104 c20 Misc WARNING: Send failed with hr = 80072ee7.
2008-11-08 14:53:27:056 1104 c20 Misc WARNING: SendRequest failed with hr = 80072ee7. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2008-11-08 14:53:27:056 1104 c20 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsu ... uredir.cab>. error 0x8024402c
2008-11-08 14:53:27:056 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x8024402c
2008-11-08 14:53:27:056 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x8024402c
2008-11-08 14:53:27:056 1104 c20 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x8024402c
2008-11-08 14:53:29:631 1104 c20 Misc WARNING: Send failed with hr = 80072ee7.
2008-11-08 14:53:29:631 1104 c20 Misc WARNING: SendRequest failed with hr = 80072ee7. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2008-11-08 14:53:29:632 1104 c20 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsu ... uredir.cab>. error 0x8024402c
2008-11-08 14:53:29:632 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x8024402c
2008-11-08 14:53:29:632 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x8024402c
2008-11-08 14:53:29:632 1104 c20 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x8024402c
2008-11-08 14:53:29:632 1104 c20 Misc WARNING: DownloadFileInternal failed for http://update.microsoft.com/v8/windowsu ... uredir.cab: error 0x8024402c
2008-11-08 14:53:29:633 1104 c20 Setup WARNING: SelfUpdate check failed to download package information, error = 0x8024402C
2008-11-08 14:53:29:633 1104 c20 Setup FATAL: SelfUpdate check failed, err = 0x8024402C
2008-11-08 14:53:29:633 1104 c20 Agent * WARNING: Skipping scan, self-update check returned 0x8024402C
2008-11-08 14:53:29:634 1104 c20 DtaStor FATAL: Failed to initialize datastore, error = 0xC80003F3
2008-11-08 14:53:29:634 1104 c20 Agent * WARNING: Exit code = 0x8024402C
2008-11-08 14:53:29:634 1104 c20 Agent *********
2008-11-08 14:53:29:634 1104 c20 Agent ** END ** Agent: Finding updates [CallerId = AutomaticUpdates]
2008-11-08 14:53:29:634 1104 c20 Agent *************
2008-11-08 14:53:29:634 1104 c20 Agent WARNING: WU client failed Searching for update with error 0x8024402c
2008-11-08 14:53:29:635 1104 214 AU >>## RESUMED ## AU: Search for updates [CallId = {E4640662-E445-47EF-BDDA-34C34D389D53}]
2008-11-08 14:53:29:635 1104 214 AU # WARNING: Search callback failed, result = 0x8024402C
2008-11-08 14:53:29:635 1104 214 AU # WARNING: Failed to find updates with error code 8024402C
2008-11-08 14:53:29:635 1104 214 AU #########
2008-11-08 14:53:29:635 1104 214 AU ## END ## AU: Search for updates [CallId = {E4640662-E445-47EF-BDDA-34C34D389D53}]
2008-11-08 14:53:29:635 1104 214 AU #############
2008-11-08 14:53:29:635 1104 214 AU Need to show Unable to Detect notification
2008-11-08 14:53:29:636 1104 214 AU AU setting next detection timeout to 2008-11-08 18:53:29
2008-11-08 14:53:29:636 1104 214 AU Setting AU scheduled install time to 2008-11-09 02:00:00
2008-11-08 14:53:29:688 1104 214 DtaStor FATAL: Failed to initialize datastore, error = 0xC80003F3
2008-11-08 14:53:29:688 1104 214 AU FATAL: Failed to get session from datastore, error = 0xC80003F3
Heeft iemand dit al voorgehad? En enig idee wat ermee moet gebeuren?
Reeds geprobeerd: windows firewall afgezet, virusscanner afgezet. Die kb's van MS, bieden geen duidelijke oplossing aan :s
Het is een genuine Vista.
Alvast bedankt!!
Geplaatst: 08 nov 2008, 19:16
door NickG
SP1 al handmatig geinstalleerd? Ik heb in het begin ook deze problemen gehad met Vista, maar na (handmatige download en) installatie van SP1 is dit probleem opgelost!
Geplaatst: 08 nov 2008, 19:36
door Dfrog
NickG schreef:SP1 al handmatig geinstalleerd? Ik heb in het begin ook deze problemen gehad met Vista, maar na (handmatige download en) installatie van SP1 is dit probleem opgelost!
Okey, thanx! Probleem opgelost!!
