De Vista van mijn schoonfamilie wil niet updaten. Hij geeft steeds fout: Er kan niet naar nieuwe updates gezocht worden. Fout: C80003F3. Door windows update is een onbekende fout geconstateerd.
Hieronder de updatelog.
Heeft iemand dit al voorgehad? En enig idee wat ermee moet gebeuren?2008-11-08 14:53:21:910 1104 c20 Misc WARNING: Send failed with hr = 80072ee7.
2008-11-08 14:53:21:910 1104 c20 Misc WARNING: SendRequest failed with hr = 80072ee7. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2008-11-08 14:53:21:910 1104 c20 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsu ... uredir.cab>. error 0x8024402c
2008-11-08 14:53:21:910 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x8024402c
2008-11-08 14:53:21:910 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x8024402c
2008-11-08 14:53:21:910 1104 c20 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x8024402c
2008-11-08 14:53:24:478 1104 c20 Misc WARNING: Send failed with hr = 80072ee7.
2008-11-08 14:53:24:479 1104 c20 Misc WARNING: SendRequest failed with hr = 80072ee7. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2008-11-08 14:53:24:479 1104 c20 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsu ... uredir.cab>. error 0x8024402c
2008-11-08 14:53:24:479 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x8024402c
2008-11-08 14:53:24:479 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x8024402c
2008-11-08 14:53:24:479 1104 c20 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x8024402c
2008-11-08 14:53:27:055 1104 c20 Misc WARNING: Send failed with hr = 80072ee7.
2008-11-08 14:53:27:056 1104 c20 Misc WARNING: SendRequest failed with hr = 80072ee7. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2008-11-08 14:53:27:056 1104 c20 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsu ... uredir.cab>. error 0x8024402c
2008-11-08 14:53:27:056 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x8024402c
2008-11-08 14:53:27:056 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x8024402c
2008-11-08 14:53:27:056 1104 c20 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x8024402c
2008-11-08 14:53:29:631 1104 c20 Misc WARNING: Send failed with hr = 80072ee7.
2008-11-08 14:53:29:631 1104 c20 Misc WARNING: SendRequest failed with hr = 80072ee7. Proxy List used: <(null)> Bypass List used : <(null)> Auth Schemes used : <>
2008-11-08 14:53:29:632 1104 c20 Misc WARNING: WinHttp: SendRequestUsingProxy failed for <http://update.microsoft.com/v8/windowsu ... uredir.cab>. error 0x8024402c
2008-11-08 14:53:29:632 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation MakeRequest failed. error 0x8024402c
2008-11-08 14:53:29:632 1104 c20 Misc WARNING: WinHttp: SendRequestToServerForFileInformation failed with 0x8024402c
2008-11-08 14:53:29:632 1104 c20 Misc WARNING: WinHttp: ShouldFileBeDownloaded failed with 0x8024402c
2008-11-08 14:53:29:632 1104 c20 Misc WARNING: DownloadFileInternal failed for http://update.microsoft.com/v8/windowsu ... uredir.cab: error 0x8024402c
2008-11-08 14:53:29:633 1104 c20 Setup WARNING: SelfUpdate check failed to download package information, error = 0x8024402C
2008-11-08 14:53:29:633 1104 c20 Setup FATAL: SelfUpdate check failed, err = 0x8024402C
2008-11-08 14:53:29:633 1104 c20 Agent * WARNING: Skipping scan, self-update check returned 0x8024402C
2008-11-08 14:53:29:634 1104 c20 DtaStor FATAL: Failed to initialize datastore, error = 0xC80003F3
2008-11-08 14:53:29:634 1104 c20 Agent * WARNING: Exit code = 0x8024402C
2008-11-08 14:53:29:634 1104 c20 Agent *********
2008-11-08 14:53:29:634 1104 c20 Agent ** END ** Agent: Finding updates [CallerId = AutomaticUpdates]
2008-11-08 14:53:29:634 1104 c20 Agent *************
2008-11-08 14:53:29:634 1104 c20 Agent WARNING: WU client failed Searching for update with error 0x8024402c
2008-11-08 14:53:29:635 1104 214 AU >>## RESUMED ## AU: Search for updates [CallId = {E4640662-E445-47EF-BDDA-34C34D389D53}]
2008-11-08 14:53:29:635 1104 214 AU # WARNING: Search callback failed, result = 0x8024402C
2008-11-08 14:53:29:635 1104 214 AU # WARNING: Failed to find updates with error code 8024402C
2008-11-08 14:53:29:635 1104 214 AU #########
2008-11-08 14:53:29:635 1104 214 AU ## END ## AU: Search for updates [CallId = {E4640662-E445-47EF-BDDA-34C34D389D53}]
2008-11-08 14:53:29:635 1104 214 AU #############
2008-11-08 14:53:29:635 1104 214 AU Need to show Unable to Detect notification
2008-11-08 14:53:29:636 1104 214 AU AU setting next detection timeout to 2008-11-08 18:53:29
2008-11-08 14:53:29:636 1104 214 AU Setting AU scheduled install time to 2008-11-09 02:00:00
2008-11-08 14:53:29:688 1104 214 DtaStor FATAL: Failed to initialize datastore, error = 0xC80003F3
2008-11-08 14:53:29:688 1104 214 AU FATAL: Failed to get session from datastore, error = 0xC80003F3
Reeds geprobeerd: windows firewall afgezet, virusscanner afgezet. Die kb's van MS, bieden geen duidelijke oplossing aan :s
Het is een genuine Vista.
Alvast bedankt!!
