Wat scheelt er ???
Het lijkt mij geen probleem aan mijn kant, want dan zou volgens mij er zoveel niet meer kunnen werken.
Zo zaken kunnen altijd plots optreden, iedereen denkt altijd omdat het zo gewerkt heeft dat het zo ook blijft, maar dat is niet altijd.Dave schreef: Misschien toch iets met mijn bekabeling, maar waarom zo ineens, ik heb niks gewijzigd ????
Known issues
Tuesday April 4 2006
The downtime was limited to a few seconds. Since 15:05 CET, the total capacity of our ADSL network in Flanders has multiplied.
Between 14:00 and 16:00 CET, ADSL customers in Flanders may experience a short outage. This interruption will only take a few minutes and will upgrade the network capacity.
This issue has been solved in the meantime.
Because of a capacity upgrade to the Broba II ADSL network, a number of users were switched to new distribution boxes. These appliances seemed to do their work properly after ample initial testing, but after taking them into service they still turned out to show stability issues.
That is why they have been taken out of use and the old situation has been restored. In case you still run into difficulties, we advise you to reboot your modem/router.
Friday March 31 2006
ADSL customers throughout Belgium, but especially the Limburg region, may encounter stability problems.
These can lead to low speeds, hardly being able to surf, corrupted data, ...
Belgacom is currently working on a solution. This solution is expected around the evening of Tuesday April 4.
