Re: Sagem F@ST 3464 Firmware
Geplaatst: 13 mei 2013, 08:33
				Waarschijnlijk verwacht Sagem ook OPION 3 (router/default gateway), voeg dat eerst toe.
[LISTEN_ON]
192.168.5.1
[LOGGING]
LogLevel=all
[RANGE_SET]
DHCPRange=192.168.5.2-192.168.5.10
SubnetMask=255.255.255.0
DomainServer=192.168.5.1
Router=192.168.5.1
AddressTime=360
[LISTEN_ON]
192.168.5.1
[LOGGING]
LogLevel=all
[RANGE_SET]
1=255.255.255.0
3=192.168.5.1
[05/13/2013 15:59:13] DHCP Server is terminating (ignore error messages that follow)
[05/13/2013 15:59:13] recvfrom returns with error 10038
[05/13/2013 15:59:13] DHCP Server terminated
[05/13/2013 15:59:13] DHCP Server V2.4.0 started as Application
[05/13/2013 15:59:13] DHCP Server V2.4.0 started as Service
[05/13/2013 15:59:13] NetworkAdapter Initialization returns 0
[05/13/2013 15:59:13] Adapter 0 with IP address 127.0.0.1 found but not used
[05/13/2013 15:59:22] DHCP Server is terminating (ignore error messages that follow)
[05/13/2013 15:59:22] DHCP Server terminated
[05/13/2013 15:59:22] DHCP Server V2.4.0 started as Service
[05/13/2013 15:59:22] DHCP Server V2.4.0 started as Application
[05/13/2013 15:59:23] NetworkAdapter Initialization returns 0
[05/13/2013 15:59:23] Adapter 0 with IP address 192.168.5.1 found (pAdap=0x00aa3e60)
[05/13/2013 15:59:24] Adapter 0 has recognized an incoming DHCP request
[05/13/2013 15:59:24] DHCP message = DHCPDISCOVER
[05/13/2013 15:59:24]    requested options: 1 3
[05/13/2013 15:59:24] client identifier (option 61) is not recognized
[05/13/2013 15:59:24] Lookup client data for physical address "00-23-48-2E-D6-0C" / client_id "00-23-48-2E-D6-0C"
[05/13/2013 15:59:24] Client 00-23-48-2E-D6-0C is not configured
[05/13/2013 15:59:24] Perform auto configuration
[05/13/2013 15:59:24] IPPOOL_1: 192.168.5.1-254
[05/13/2013 15:59:24] Auto configuration succeeded: IP-Addr = 192.168.5.2
[05/13/2013 15:59:24] Response: offer the configured IP address (lease time = 86400)
[05/13/2013 15:59:24] Sending a broadcast response to the client
[05/13/2013 15:59:24] Connection 0: sending top queue packet
[05/13/2013 15:59:25] Adapter 1 has recognized an incoming TFTP request
[05/13/2013 15:59:25] TFTP RRQ started on port_index=0: C:\DHCPServer\wwwroot\0205A8C0.img
[05/13/2013 15:59:25] NetworkAdapter Initialization returns 0
[05/13/2013 15:59:25] Adapter 0 with IP address 192.168.5.1 found (pAdap=0x00922880)
[05/13/2013 15:59:49] DHCP Server is terminating (ignore error messages that follow)
[05/13/2013 15:59:49] recvfrom returns with error 10038
[05/13/2013 15:59:49] DHCP Server terminated
[05/13/2013 15:59:49] DHCP Server V2.4.0 started as Service
[05/13/2013 15:59:49] DHCP Server V2.4.0 started as Application
[05/13/2013 15:59:49] NetworkAdapter Initialization returns 0
[05/13/2013 15:59:49] Adapter 0 with IP address 127.0.0.1 found but not used
[05/13/2013 16:00:12] DHCP Server is terminating (ignore error messages that follow)
[05/13/2013 16:00:12] DHCP Server terminated
[05/13/2013 16:00:12] DHCP Server V2.4.0 started as Application
[05/13/2013 16:00:12] DHCP Server V2.4.0 started as Service
[05/13/2013 16:00:12] NetworkAdapter Initialization returns 0
[05/13/2013 16:00:12] Adapter 0 with IP address 192.168.5.1 found (pAdap=0x00922880)
[05/13/2013 16:00:14] NetworkAdapter Initialization returns 0
[05/13/2013 16:00:14] Adapter 0 with IP address 192.168.5.1 found (pAdap=0x00aa3e60)
[SETTINGS]
IPPOOL_1=192.168.5.1-254
IPBIND_1=192.168.5.1
AssociateBindsToPools=1
Trace=1
DeleteOnRelease=0
ExpiredLeaseTimeout=3600
[GENERAL]
LEASETIME=86400
NODETYPE=8
SUBNETMASK=255.255.255.0
NEXTSERVER=192.168.5.1
DNS_0=192.168.5.1
ROUTER_0=0.0.0.0
[DNS-SETTINGS]
EnableDNS=0
FORWARD=192.168.5.1
[TFTP-SETTINGS]
EnableTFTP=1
ROOT=C:\DHCPServer\wwwroot
WritePermission=0
[HTTP-SETTINGS]
EnableHTTP=0
 ), kan ik eindelijk terug inloggen op de web interface!!!
VDSL Version Firmware-VTU-R:9.3.2.5.ENGIK105012 Time Feb 9 2012, 19:30:50
VDSL line status SHOWTIME
Downstream Training Margin : 20.0 dB
Downstream line rate 30176 kbps
Upstream line rate 2048 kbps
TX total power -19.2 dbm
Downstream delay 7.5 ms
Upstream delay 5.4 ms
