Ik heb bind terug op een nieuwe debian onder Microsoft Virtual PC geïnstalleerd zodat ik van scratch kan starten (vertrouw vorige versie niet meer). Ik heb volgende configuratiefiles aangepast/aangemaakt:
/etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto eth0
iface eth0 inet dhcp
auto eth1
iface eth1 inet static
address 192.168.6.1
netmask 255.255.255.0
auto eth2
iface eth2 inet static
address 192.168.6.2
/etc/bind/named.conf.local
// Do any local configuration here
// Consider adding the 1918 zones here, if they are not used in your
// organization
//include "/etc/bind/zones.rfc1918";
zone "pih.local"{
type master;
file "/etc/bind/db.pih.local";
zone "6.168.192.in-addr.arpa"{
type master;
file "/etc/bind/db.6.168.192";
; BIND reverse data file for empty rfc1918 zone
$TTL 3D
@ IN SOA ns1.pih.local. bguy.pih.local. (
2005111527 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
86400 ) ; Negative Cache TTL
NS ns1.pih.local.
NS ns2.pih.local.
1 PTR ns1.pih.local.
2 PTR ns2.pih.local.
; Reverse lookup zone
$TTL 3D
@ IN SOA ns1.pih.local. bguy.pih.local.(
2005111527 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
NS ns1.pih.local.
NS ns2.pih.local.
ns1 IN A 192.168.6.1
ns2 IN A 192.168.6.2
localhost IN A 127.0.0.1Vermeldenswaardig is dat eth0 onder virtual pc op een fysieke netwerkkaart loopt, terwijl eth1 & 2 beiden op dezelfde windows loopback adapter lopen. (Ingesteld in de Virtual PC settings)Nov 8 20:03:20 localhost named[2187]: shutting down: flushing changes
Nov 8 20:03:20 localhost named[2187]: stopping command channel on 127.0.0.1#953
Nov 8 20:03:20 localhost named[2187]: stopping command channel on ::1#953
Nov 8 20:03:20 localhost named[2187]: no longer listening on 127.0.0.1#53
Nov 8 20:03:20 localhost named[2187]: no longer listening on 192.168.1.50#53
Nov 8 20:03:20 localhost named[2187]: no longer listening on 192.168.6.1#53
Nov 8 20:03:20 localhost named[2187]: no longer listening on 192.168.6.2#53
Nov 8 20:03:20 localhost named[2187]: exiting
Nov 8 20:03:22 localhost named[2221]: starting BIND 9.2.4 -u bind
Nov 8 20:03:22 localhost named[2221]: using 1 CPU
Nov 8 20:03:22 localhost named[2221]: loading configuration from '/etc/bind/named.conf'
Nov 8 20:03:22 localhost named[2221]: listening on IPv4 interface lo, 127.0.0.1#53
Nov 8 20:03:22 localhost named[2221]: listening on IPv4 interface eth0, 192.168.1.50#53
Nov 8 20:03:22 localhost named[2221]: listening on IPv4 interface eth1, 192.168.6.1#53
Nov 8 20:03:22 localhost named[2221]: listening on IPv4 interface eth2, 192.168.6.2#53
Nov 8 20:03:22 localhost named[2221]: command channel listening on 127.0.0.1#953
Nov 8 20:03:22 localhost named[2221]: command channel listening on ::1#953
Nov 8 20:03:22 localhost named[2221]: zone 0.in-addr.arpa/IN: loaded serial 1
Nov 8 20:03:22 localhost named[2221]: zone 127.in-addr.arpa/IN: loaded serial 1
Nov 8 20:03:22 localhost named[2221]: zone 6.168.192.in-addr.arpa/IN: loaded serial 2005111527
Nov 8 20:03:22 localhost named[2221]: zone 255.in-addr.arpa/IN: loaded serial 1
Nov 8 20:03:22 localhost named[2221]: zone pih.local/IN: loaded serial 2005111527
Nov 8 20:03:22 localhost named[2221]: zone localhost/IN: loaded serial 1
Nov 8 20:03:22 localhost named[2221]: running
Nov 8 20:03:22 localhost named[2221]: zone 6.168.192.in-addr.arpa/IN: sending notifies (serial 2005111527)
Nov 8 20:03:22 localhost named[2221]: zone pih.local/IN: sending notifies (serial 2005111527)
Nov 8 20:03:22 localhost named[2221]: received notify for zone '6.168.192.in-addr.arpa'
Nov 8 20:03:22 localhost named[2221]: received notify for zone 'pih.local'
Het concrete probleem: zowel forward als reverse lookup queries werken niet (door middel van "nslookup").
Als total noob heb ik even naar tooltjes voor zelfdiagnose gezocht, en vond "nslint". Diagnose van de dns-files gaf geen enkele fout.> ns1.pih.local.
Server: 192.168.1.1
Address: 192.168.1.1#53
** server can't find ns1.pih.local: NXDOMAIN
Na een volle dag zoeken ben ik het beu, ziet iemand een fout? Ik ben noob tot het hele handmatig dns instellen + linux dus ik waardeer alle hulp. Alvast bedankt.
