Proximus BBox v3+ (bridged) -------------> OpenWrt-router met PPPoE-sessie ---------------> LAN
\_____ Set-topbox Proximus TVDe foutmelding die eruitsprong is de volgende, maar ik vind niks online dat een oplossing biedt:
daemon.debug pppd[19221]: sent [IPV6CP TermReq id=0x2 "Interface configuration failed"]Code: Selecteer alles
logread -e pppd -f
Tue Sep 8 18:57:36 2020 daemon.info pppd[19221]: Plugin rp-pppoe.so loaded.
Tue Sep 8 18:57:36 2020 daemon.info pppd[19221]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.7
Tue Sep 8 18:57:36 2020 daemon.notice pppd[19221]: pppd 2.4.7 started by root, uid 0
Tue Sep 8 18:57:36 2020 daemon.debug pppd[19221]: Send PPPOE Discovery V1T1 PADI session 0x0 length 12
Tue Sep 8 18:57:36 2020 daemon.debug pppd[19221]: dst ff:ff:ff:ff:ff:ff src 00:0d:b9:xx:xx:xx
Tue Sep 8 18:57:36 2020 daemon.debug pppd[19221]: [service-name] [host-uniq 15 4b 00 00]
Tue Sep 8 18:57:41 2020 daemon.debug pppd[19221]: Send PPPOE Discovery V1T1 PADI session 0x0 length 12
Tue Sep 8 18:57:41 2020 daemon.debug pppd[19221]: dst ff:ff:ff:ff:ff:ff src 00:0d:b9:xx:xx:xx
Tue Sep 8 18:57:41 2020 daemon.debug pppd[19221]: [service-name] [host-uniq 15 4b 00 00]
Tue Sep 8 18:57:41 2020 daemon.debug pppd[19221]: Recv PPPOE Discovery V1T1 PADO session 0x0 length 48
Tue Sep 8 18:57:41 2020 daemon.debug pppd[19221]: dst 00:0d:b9:xx:xx:xx src 24:21:xx:xx:xx:xx
Tue Sep 8 18:57:41 2020 daemon.debug pppd[19221]: [service-name] [AC-name ttnle52lon01] [host-uniq 15 4b 00 00] [AC-cookie 0a 47 32 c6 af a0 98 80 be c4 21 97 69 5a c1 a8]
Tue Sep 8 18:57:41 2020 daemon.debug pppd[19221]: Send PPPOE Discovery V1T1 PADR session 0x0 length 32
Tue Sep 8 18:57:41 2020 daemon.debug pppd[19221]: dst 24:21:xx:xx:xx:xx src 00:0d:b9:xx:xx:xx
Tue Sep 8 18:57:41 2020 daemon.debug pppd[19221]: [service-name] [host-uniq 15 4b 00 00] [AC-cookie 0a 47 32 c6 af a0 98 80 be c4 21 97 69 5a c1 a8]
Tue Sep 8 18:57:41 2020 daemon.debug pppd[19221]: Recv PPPOE Discovery V1T1 PADS session 0x1 length 12
Tue Sep 8 18:57:41 2020 daemon.debug pppd[19221]: PADS: Service-Name: ''
Tue Sep 8 18:57:41 2020 daemon.info pppd[19221]: PPP session is 1
Tue Sep 8 18:57:41 2020 daemon.warn pppd[19221]: Connected to 24:21:xx:xx:xx:xx via interface eth0
Tue Sep 8 18:57:41 2020 daemon.debug pppd[19221]: using channel 83
Tue Sep 8 18:57:41 2020 daemon.info pppd[19221]: Renamed interface ppp0 to pppoe-wan
Tue Sep 8 18:57:41 2020 daemon.info pppd[19221]: Using interface pppoe-wan
Tue Sep 8 18:57:41 2020 daemon.notice pppd[19221]: Connect: pppoe-wan <--> eth0
Tue Sep 8 18:57:41 2020 daemon.debug pppd[19221]: sent [LCP ConfReq id=0x1 <mru 1492> <magic 0xc4737bb0>]
Tue Sep 8 18:57:41 2020 daemon.debug pppd[19221]: rcvd [LCP ConfAck id=0x1 <mru 1492> <magic 0xc4737bb0>]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: sent [LCP ConfReq id=0x1 <mru 1492> <magic 0xc4737bb0>]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: rcvd [LCP ConfAck id=0x1 <mru 1492> <magic 0xc4737bb0>]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: rcvd [LCP ConfReq id=0x34 <mru 1492> <auth chap MD5> <magic 0x1171d6d>]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: sent [LCP ConfAck id=0x34 <mru 1492> <auth chap MD5> <magic 0x1171d6d>]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: sent [LCP EchoReq id=0x0 magic=0xc4737bb0]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: rcvd [CHAP Challenge id=0x1 <21d6dd7297643f11dcd4d39572901105fdda3e1a172b01c9dd3c3b2a011d96227474940c58531db428f14a1b025b200037dd9acd091b9767585211d86fa77a>, name = "ttnle52lon01"]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: sent [CHAP Response id=0x1 <1f8962cac359ce763993338bf31ac0a4>, name = "$login"]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: rcvd [LCP EchoRep id=0x0 magic=0x1171d6d]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: rcvd [CHAP Success id=0x1 "QOS"]
Tue Sep 8 18:57:44 2020 daemon.info pppd[19221]: CHAP authentication succeeded: QOS
Tue Sep 8 18:57:44 2020 daemon.notice pppd[19221]: CHAP authentication succeeded
Tue Sep 8 18:57:44 2020 daemon.notice pppd[19221]: peer from calling number 24:21:xx:xx:xx:xx authorized
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: sent [IPV6CP ConfReq id=0x1 <addr fe80::1536:6f51:2376:6aa2>]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: rcvd [IPV6CP ConfReq id=0x1c <addr fe80::2621:24ff:fe91:b63f>]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: sent [IPV6CP ConfAck id=0x1c <addr fe80::2621:24ff:fe91:b63f>]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: rcvd [IPCP ConfReq id=0xd2 <addr 10.24.193.42>]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: sent [IPCP ConfAck id=0xd2 <addr 10.24.193.42>]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: rcvd [IPV6CP ConfAck id=0x1 <addr fe80::1536:6f51:2376:6aa2>]
Tue Sep 8 18:57:44 2020 daemon.err pppd[19221]: sif6addr: ioctl(SIOCSIFADDR): Permission denied (line 2642)
Tue Sep 8 18:57:44 2020 daemon.warn pppd[19221]: sif6addr failed
Tue Sep 8 18:57:44 2020 daemon.warn pppd[19221]: cif6addr: ioctl(SIOCDIFADDR): No such address
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: sent [IPV6CP TermReq id=0x2 "Interface configuration failed"]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: rcvd [IPCP ConfNak id=0x1 <addr 81.245.219.175> <ms-dns1 195.238.2.21> <ms-dns2 195.238.2.22>]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: sent [IPCP ConfReq id=0x2 <addr 81.245.219.175> <ms-dns1 195.238.2.21> <ms-dns2 195.238.2.22>]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: rcvd [LCP TermReq id=0x35]
Tue Sep 8 18:57:44 2020 daemon.info pppd[19221]: LCP terminated by peer
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: sent [LCP TermAck id=0x35]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: rcvd [IPV6CP TermAck id=0x2]
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: Discarded non-LCP packet when LCP not open
Tue Sep 8 18:57:44 2020 daemon.notice pppd[19221]: Modem hangup
Tue Sep 8 18:57:44 2020 daemon.notice pppd[19221]: Connection terminated.
Tue Sep 8 18:57:44 2020 daemon.info pppd[19221]: Connect time 0.2 minutes.
Tue Sep 8 18:57:44 2020 daemon.info pppd[19221]: Sent 60 bytes, received 60 bytes.
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: Send PPPOE Discovery V1T1 PADT session 0x1 length 28
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: dst 24:21:xx:xx:xx:xx src 00:0d:b9:xx:xx:xx
Tue Sep 8 18:57:44 2020 daemon.debug pppd[19221]: [host-uniq 15 4b 00 00] [AC-cookie 0a 47 32 c6 af a0 98 80 be c4 21 97 69 5a c1 a8]
Tue Sep 8 18:57:44 2020 daemon.info pppd[19221]: Sent PADT
Tue Sep 8 18:57:44 2020 daemon.info pppd[19221]: Exit.
