Hello,
First: Sorry for writing English. I understand a bit Dutch but I am not that good at writing.
I have a Fritzbox 7360. Updates stopped a year ago, thats why I want to change the system to OpenWrt. I found this thread: https://nl.forum.proximus.be/archieven- ... aten-38493
If I understand it correctly, not every router/modem will work with Proximus. My router/modem is currently working - but will it work if I change the system to OpenWrt?
What would I have to configure?
Thanks for help!
EDIT: I do not want to use the B-Box. I have VDSL2 G.Vector.
Use OpenWrt on Fritzbox - is that possible?
- Sinna
- Twitter: KrSi78
- Uitgedeelde bedankjes: 342 keer
- Bedankt: 230 keer
Even if you would succeed to flash OpenWRT on the Fritz!Box, you'll be on a repair profile as Proximus uses whitelisting for the devices allowed on its network. For Fritz!Boxes the number of devices supported is limited and the device must run specific VDSL drivers.
If you don't want to use the BBox, please buy yourself a supported device. You can find the list on the edpnet Help & Support page Which modems can I use.
- Sinna
- Twitter: KrSi78
- Bedankt: 230 keer
Repair profile means that the speed is limited to 9Mbps down, 512Kbps up (source).
About your worries about the Fritz!OS versions: if you're using a device that's end-of-life, you risk to use a device that may have security issues. That's not only a Fritz! thing and Fritz! is in my opinion one of the few that supports their devices very long time. That's why I suggested to buy yourself another Fritz!Box.
- Bedankt: 740 keer
I have a Fritzbox 7490 for sale on this forum. This one can be used with Proximus vdsl. Has very recent firmware (7.12). The FB 7490 is whitelisted by Proximus.
- Uitgedeelde bedankjes: 220 keer
- Bedankt: 17 keer
One can of course use a whitelisted BBox or Fritz!Box as modem and run an OpenWRT router behind it. I am also interested in OpenWRT on Fritz!Box (7490), but for other porposes (extra access point and maybe openhab server).Sinna schreef:Even if you would succeed to flash OpenWRT on the Fritz!Box, you'll be on a repair profile as Proximus uses whitelisting for the devices allowed on its network. For Fritz!Boxes the number of devices supported is limited and the device must run specific VDSL drivers.
OpenWRT on 7490 seems still work in progress (no official build). Some 7360 do have an official OpenWRT build if I am not mistaken. Some functionality may be missing (DSL perhaps?) but using it as router or access point might very well work. See OpenWRT forums and downloads.
https://downloads.openwrt.org/releases/ ... iq/xrx200/
- honda4life
- Bedankt: 391 keer
Even not updated a 7360v1 is not that bad.
I think OpenWrt never supports a modem also.
You can find 7490 for about 50€ if you're not in a hurry.
