Ik ben de eigenaar van zo'n Thomson Speedtouch 530 modem met Belgacom
profiellekens. Maar eigenlijk ga ik klant worden bij Surfadsl. Kan iemand de volgende profile aanpassen naar surfadsl maar dan met Dhcp Spoofing
Zo kan ik de modem gebruiken met de linksys wrt54 router.
Dus speedtouch gurus, maak van dees belgacom profile een surfadfsl + dhcp spoofing profile...
Bedankt op voorhand...
Begin profile:
[ env.ini ]
set var=CONF_REGION value="tr(1,Belgium)"
set var=CONF_PROVIDER value="tr(2,Belgacom)"
set var=CONF_DESCRIPTION value="tr(3,Belgacom ADSL (recommended))"
set var=CONF_SERVICE value="tr(4,Belgacom ADSL (recommended))"
set var=CONF_DATE value=""
set var=CONF_TPVERSION value=1.2.0
set var=HOST_SETUP value=auto
[ wizard.ini ]
' PPP=Settings
def var=PPP type=grp desc="tr(9,Specify the details of the Routed PPP Account. All information should be provided by your ISP.)" alias="tr(10,PPP Account Settings)"
def var=PPP_user type=string grp=PPP alias="tr(11,User Name)" req=yes desc="tr(12,Enter your Internet connection user name.)"
def var=%PPP_pwd type=passw grp=PPP alias="tr(13,Password)" req=yes desc="tr(14,Enter your Internet connection password.)" max=32
[ hostwizard.ini ]
[ phone.ini ]
add name=UsB addr=usb.0.35 type=any logging=off
add name=pppoe addr=8*35 type=any
[ pfirewall.ini ]
chain create chain=sink
chain create chain=forward
chain create chain=source
rule create chain=sink index=0 srcintfgrp=!wan action=accept
rule create chain=sink index=1 prot=udp dstport=dns action=accept
rule create chain=sink index=2 prot=udp dstport=bootpc action=accept
rule create chain=sink index=3 prot=icmp icmptype=echo-reply action=accept
rule create chain=sink index=4 prot=udp dstport=snmp log=yes action=count
rule create chain=sink index=5 action=drop
rule create chain=forward index=0 srcintfgrp=wan dstintfgrp=wan action=drop
rule create chain=forward index=1 src=10.0.0.138 action=accept
rule create chain=forward index=2 src=10.0.0.50 action=accept
rule create chain=forward index=6 dst=10.0.0.138 action=accept
rule create chain=forward index=7 dst=10.0.0.50 action=accept
rule create chain=forward index=11 action=drop
rule create chain=source index=0 dstintfgrp=!wan action=accept
rule create chain=source index=1 prot=udp dstport=dns action=accept
rule create chain=source index=2 prot=udp dstport=bootps action=accept
rule create chain=source index=3 prot=icmp icmptype=echo-request action=accept
rule create chain=source index=4 prot=udp srcport=snmp log=yes action=count
rule create chain=source index=5 action=drop
assign hook=sink chain=sink
assign hook=forward chain=forward
assign hook=source chain=source
[ bridge.ini ]
ifadd intf=USB dest=UsB logging=off
ifattach intf=USB logging=off
config age=300 filter=no_WAN_broadcast
[ pptp.ini ]
[ ethoa.ini ]
ifadd intf=ethoa_pppoe dest=pppoe
ifconfig intf=ethoa_pppoe
ifattach intf=ethoa_pppoe
[ dhcp.ini ]
config autodhcp=off scantime=20 state=enabled trace=off
policy verifyfirst=off trustclient=on
pool add name=LAN
pool config name=LAN intf=eth0 poolstart=10.0.0.50 poolend=10.0.0.50 netmask=24 gateway=10.0.0.138 leasetime=120
[ ipoa.ini ]
[ pppoa.ini ]
[ pppoe.ini ]
ifadd intf=pppoe_pppoe
rtadd intf=pppoe_pppoe dst=0.0.0.0/0 metric=1
ifconfig intf=pppoe_pppoe dest=RELAY user=$PPP_user password=$%PPP_pwd acname=$PPP_ac servicename=$PPP_service accomp=on addrtrans=pat restart=on
ifattach intf=pppoe_pppoe
[ pppoerelay.ini ]
add port=ethoa_pppoe
add port=eth0
[ ip.ini ]
config forwarding=on firewalling=on redirects=on sourcerouting=off netbroadcasts=off ttl=64 fraglimit=64 defragmode=always addrcheck=dynamic mssclamping=on
apadd addr=10.0.0.138/24 intf=eth0 addroute=yes type=1
ifconfig intf=loop mtu=1500 group=local linksensing=off
ifconfig intf=eth0 mtu=1500 group=lan linksensing=off
ifconfig intf=ethoa_pppoe mtu=1500 group=wan linksensing=off
ifconfig intf=pppoe_pppoe mtu=1492 status=down group=wan linksensing=off
rtadd dst=255.255.255.255/32 gateway=10.0.0.138
rtadd dst=224.0.0.0/4 intf=eth0
[ autoip.ini ]
ifadd intf=eth0
ifconfig intf=eth0 addr=169.254.175.218 poolstart=169.254.1.1 poolend=169.254.254.254 netmask=16
ifattach intf=eth0
[ autopvc.ini ]
#if $ATM_auto=active
config mode=active type=pppoerelay overwrite=enabled peakrate=0
#else
config mode=passive type=bridge
#endif
[ system.ini ]
config upnp=enabled mdap=enabled dcache=enabled drst=enabled
#if $%ST_SYS_PASSWORD=""
setpassword password="" userid=$%ST_SYS_USERNAME
#else
setpassword password=$%ST_SYS_PASSWORD userid=$%ST_SYS_USERNAME
#endif
[ upnp.ini ]
config defcservice=pppoe_pppoe
[ language.ini ]
langdef lang=nl charset=ISO-8859-1
t r="1, België"
t r="2, Belgacom"
t r="3, Belgacom ADSL (aanbevolen)"
t r="4, Belgacom ADSL (aanbevolen)"
t r="5, Geef de details van de routed-PPPoE Packet-service op. Alle informatie wordt door uw Internet-provider verstrekt."
t r="6, Routed-PPPoE Packet-service"
t r="7, Selecteer een VPI/VCI uit de lijst"
t r="8, Automatische configuratie"
t r="9, Geef de details van de routed-PPP-account op. Alle informatie wordt door uw Internet-provider verstrekt."
t r="10, Instellingen van PPP-account"
t r="11, Gebruikersnaam"
t r="12, Geef de gebruikersnaam voor uw Internet-verbinding in."
t r="13, Wachtwoord"
t r="14, Geef het wachtwoord voor uw Internet-verbinding in."
t r="15, Access Concentrator"
t r="16, Geef de naam van de PPPoE Access Concentrator in."
t r="17, Naam van service"
t r="18, Geef de naam van de PPPoE-service in."
t r="19, Geef de gebruikersnaam en het wachtwoord op waarmee u het beheer van de Belgacom Router wilt beveiligen."
t r="20, Belgam Router-beveiliging"
t r="21, Gebruikersnaam"
t r="22, Geef uw gebruikersnaam in."
t r="23, Wachtwoord"
t r="24, Geef uw wachtwoord in."
t r="25, Wachtwoord bevestigen"
t r="26, Geef uw wachtwoord nogmaals in."
langdef lang=fr charset=ISO-8859-1
t r="1, Belgique"
t r="2, Belgacom"
t r="3, Belgacom ADSL (recommandé)"
t r="4, Belgacom ADSL (recommandé)"
t r="5, Spécifiez les détails relatifs au service de transmission par paquets PPPoE routée. Toutes ces informations doivent être fournies par votre FAI."
t r="6, Service de transmission par paquets PPPoE routé"
t r="7, Sélectionnez un VPI/VCI dans la liste"
t r="8, Auto-configuré"
t r="9, Spécifiez les détails relatifs au compte de la connexion PPP routée. Toutes ces informations doivent être fournies par votre FAI."
t r="10, Paramètres du compte PPP"
t r="11, Nom d'utilisateur"
t r="12, Entrez le nom d'utilisateur employé pour votre connexion à Internet."
t r="13, Mot de passe"
t r="14, Entrez le mot de passe employé pour votre connexion à Internet."
t r="15, Concentrateur d?accès"
t r="16, Entrez le nom du concentrateur d'accès PPPoE."
t r="17, Nom du service"
t r="18, Entrez le nom du service PPPoE."
t r="19, Indiquez un nom d'utilisateur et un mot de passe pour protéger l'accès administratif du Router Belgacom."
t r="20, Sécurité Belgacom Router"
t r="21, Nom d'utilisateur"
t r="22, Entrez un nom d'utilisateur."
t r="23, Mot de passe"
t r="24, Entrez votre mot de passe."
t r="25, Confirmer le mot de passe"
t r="26, Entrez à nouveau le mot de passe"
langdef lang=de charset=ISO-8859-1
t r="1, Belgien"
t r="2, Belgacom"
t r="3, Belgacom ADSL (empfohlen)"
t r="4, Belgacom ADSL (empfohlen)"
t r="5, Geben Sie die Einzelheiten zum Routed PPPoE-Paketdienst an. Ihr Internetdienstanbieter kann Ihnen alle Informationen bereitstellen."
t r="6, Routed PPPoE-Paketdienst"
t r="7, Wählen Sie einen VPI/VCI-Eintrag aus der Liste au"
t r="8, Automatisch konfiguriert"
t r="9, Geben Sie die Einzelheiten zum Routed PPP-Konto an. Ihr Internetdienstanbieter kann Ihnen alle Informationen bereitstellen."
t r="10, Einstellungen für das PPP-Konto"
t r="11, Benutzername"
t r="12, Geben Sie den Benutzernamen für die Internetverbindung ein."
t r="13, Kennwort"
t r="14, Geben Sie das Kennwort für die Internetverbindung ein."
t r="15, Zugangskonzentrator"
t r="16, Geben Sie den Namen des PPPoE-Zugangskonzentrators ein."
t r="17, Dienstname"
t r="18, Geben Sie den Namen des PPPoE-Dienstes ein."
t r="19, Geben Sie den Benutzernamen und das Kennwort an, um den Administratorzugriff auf den Belgacom Router zu schützen."
t r="20, Belgacom Router Sicherheit"
t r="21, Benutzername"
t r="22, Geben Sie den Benutzernamen ein."
t r="23, Kennwort"
t r="24, Geben Sie das Kennwort ein."
t r="25, Kennwort bestätigen"
t r="26, Geben Sie das Kennwort erneut ein."
[ endofarch ]
