3x Allied Telesis 24x gigabit + 4 combo SFP switch
shiseido
Uitgedeelde bedankjes: 4 keer
Bedankt: 19 keer
(mea culpa voor de late-night pics)
3x Allied Telesis Layer 2 Stackable Gigabit Ethernet Switch
Model : AT-8000GS/24
Specs @ http://www.alliedtelesis.com/userfiles/ ... S_RevN.pdf
In perfect werkende staat, en vooral zeer "fanless"!
Factory reset + getest.
Alle toestellen vertonen krassen boven & onder aan het toestel.
Factory date -- 2009
Product Information :
The AT-8000GS/24-10 provides high performance Layer 2 switching in an affordable fixed configuration platform.
This switch offers 24 10/100/1000 ports, with four fixed 1Gbps SFP slots plus two integrated stacking connectors that deliver a total of 20Gbps stacking bandwidth.
The stacking capability integrated into this platform is configured as a resilient ring topology designed to provide high reliability and simplified management for higher port density applications.
Support for jumbo Ethernet frames enables higher throughput of time sensitive data.
Features :
Other Features Flow control, layer 2 switching, DHCP support, BOOTP support, trunking, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, MAC address filtering, Broadcast Storm Control, SNTP support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), SSH support
Networking :
Remote Management Protocol : HTTP, HTTPS, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 1, SNMP 2c, SNMP 3, SSH-2, Telnet
Routing Protocol : IGMP, IGMPv2, IGMPv3
Stackable : Stackable
MAC Address Table Size : 8K entries
Memory :
Flash Memory : 16 MB flash
RAM Memory : 128 MB
Bieden vanaf 25 euro per stuk (excl. verzending) op switch A, B of C.
Verzending via Kiala, B-post of ophaling te Lier.
Afsluiting 48u na het hoogste bod.
Cheers,
Shiseido
tijs.vandenvester
Bedankt: 10 keer
A: 25 euro
Provider: Proximus Internet Maxi - 100M/20M
Network: Pfsense firewall - Allied Telesis 8000GS/24 - Unifi AP-AC Lite
Sinna
Twitter: KrSi78
Bedankt: 234 keer
Zijn die nog met een moderne browser benaderbaar? Ik heb nl. een HP waarvan de web interface java-based is maar niets ondertekend waardoor ik het toestel enkel nog met een verouderde browser kan configureren.
shiseido
Bedankt: 19 keer
Heb ze na het fysiek resetten, inloggen via console & wijzigen IP-adres -- perfect kunnen benaderen via IE11. (even compatibiliteitsmodus aangezet)
Switchen hebben dacht ik momenteel FW V2.0.0.19, maar er zijn nog een pak recentere beschikbaar (laatste ergens 2012).
Zie ook -- http://www.alliedtelesis.com/p-1883.html
Je zal ze wel enkel kunnen downen indien je een login hebt voor de site..
Cheerio!
shiseido
Bedankt: 19 keer
...en zo te zien werden ze nog recentelijk ingezet bij nieuwe projecten in Oriental Melaka Straits Medical Centre & Port Taranaki :-D
(zie previous link)
Bedankt: 775 keer
Sinna schreef:Zijn die nog met een moderne browser benaderbaar? Ik heb nl. een HP waarvan de web interface java-based is maar niets ondertekend waardoor ik het toestel enkel nog met een verouderde browser kan configureren.
Ik dacht dat firefox exceptions toeliet?
shiseido
Bedankt: 19 keer
Exception toevoegen aan de lijst in het Java control panel (tab security)..
Kitt
Twitter: kitt1977
Bedankt: 45 keer
B : 25 euro dan :-)
Kitt
Twitter: kitt1977
Bedankt: 45 keer
ik zie geen oortjes op de foto's ? zijn die er bij ?
shiseido
Bedankt: 19 keer
Neen -- helaas, nergens meer te vinden..
zorka
Uitgedeelde bedankjes: 9 keer
Bedankt: 13 keer
c: 25€
Doktor Avalanche
Bedankt: 70 keer
A:30€
tijs.vandenvester
Bedankt: 10 keer
B: 30 euro
jaker
Uitgedeelde bedankjes: 275 keer
Bedankt: 90 keer
C: 30
Kabelmodem: Arris CM3500B
zorka
Bedankt: 13 keer
c 35€
Sinna
Twitter: KrSi78
Bedankt: 234 keer
shiseido schreef:Exception toevoegen aan de lijst in het Java control panel (tab security)..
Dat lukt me dus niet meer met Java 8. Ik kan het beveiligingsniveau niet laag genoeg meer instellen.
shiseido schreef:Neen -- helaas, nergens meer te vinden..
http://www.ebay.com/itm/Allied-Telesis- ... xy63FSpbG2
Ander model maar zullen wel passen... al zijn ze precies wel van goud aan de prijs te zien :-)
shiseido
Bedankt: 19 keer
Even zijaanzicht van de switchen genomen (en lijkt verdacht veel op de brackets van HP, al dan niet -- meer of minder naar achter verzonken bij installatie van de switch in het rack).
Check het morgen!
Worden al verkocht aan de prijs van een kilo koffie :-D :
http://www.ebay.com/itm/HP-5064-2085-U1 ... SwEeFVBDd-
shiseido
Bedankt: 19 keer
Sinna,
Mss volgende nog even checken :
https://www.java.com/en/download/help/java_blocked.xml
http://h20564.www2.hpe.com/hpsc/doc/pub ... kc-0126277
Sinna
Twitter: KrSi78
Bedankt: 234 keer
Bedankt! Ik ga er woensdag mee aan de slag (heb nu niet meteen toegang tot het toestel).
Bedankt: 775 keer
C 35
Bedankt: 775 keer
correctie: c was al 35, dus dan wordt dat vorige bod 35 voor B
tijs.vandenvester
Bedankt: 10 keer
A: 35 EUR
Doktor Avalanche
Bedankt: 70 keer
A : 40€
tijs.vandenvester
Bedankt: 10 keer
B: 40 EUR
Bedankt: 775 keer
C 40
zorka
Bedankt: 13 keer
C : 45€
shiseido
Bedankt: 19 keer
Zonet even de Procurve brackets geprobeerd, maar helaas een no-go..
Zal een DIY bending&drilling projectje worden voor de winnaars :-D
shiseido
Bedankt: 19 keer
Countdown :
Switch A. Morgenochtend @ 09:27
Switch B. Morgenmiddag @ 13:51
Switch C. Morgenavond @ 21:18
Upsah!
jaker
Bedankt: 90 keer
A: 45€
Doktor Avalanche
Bedankt: 70 keer
B 45€
tijs.vandenvester
Bedankt: 10 keer
A 50 EUR
shiseido
Bedankt: 19 keer
Switch C is gisterenavond verlopen -- winnaar Zorka (PM sent)
Switch A & B vervallen beide morgenochtend (za 12/12/2015)
shiseido
Bedankt: 19 keer
Alle switchen zijn -en route-. Mag slotje op.
