Tellen met afbeeldingen
- Bedankt: 6 keer
- lacer
- Bedankt: 198 keer
Is deze rare break versie een beetje herkenbaar
- lacer
- Bedankt: 198 keer
- Bedankt: 1206 keer
Clock Oscillator Provides High Frequency Audio Control
Crystek has launched the CCHD-957, a new Ultra-Low Phase Noise HCMOS Clock Oscillator with Standby Mode, featuring an extremely low close-in phase noise of -100 dBc/Hz at 10Hz offset and a typical noise floor of -170 dBc/Hz at 100kHz offset. The Crystek CCHD-957 HCMOS Clock Oscillator also features a “Standby Function”—when placed in disable mode, the internal oscillator is completely shut down and its output buffer is placed in Tri-State. This family is housed in a 9x14 mm SMT package and operates with a +3.3V power supply consuming 15 mA of current. Stability is rated at 20-50 ppm (0° to +70°C) and ±25-50 ppm (-40° to +85°C). The CCHD-957 generates frequencies between 10 MHz and 50 MHz. Its output driver is capable of driving ±24 mA, translating to a rise/fall time of approximately 3 nsec max at 20% to 80% Vcc with a 15 pF load.
- Uitgedeelde bedankjes: 375 keer
- Bedankt: 121 keer
Samsung Galaxy S25 Ultra
Ubiquiti UDM Pro
Synology DS1821+
Nvidia Shield TV console
Microsoft Surface Pro 8
Garmin Venu3
Ubiquiti UDM Pro
Synology DS1821+
Garmin Venu3
- lacer
- Bedankt: 198 keer
Geen Porsches en straaljagers deze keer maar dit: Een personenwagen ZAZ 966 uit 1965
- Bedankt: 16 keer
Afbeelding van http://upload.wikimedia.org/wikipedia/e ... it-979.jpg.
Verzonden vanaf mijn iPad met behulp van Tapatalk
-> speedtest was done with wireless-connection<-
Proximus/ Tuttimus
PC: Macbook Air i7/8Gb/256GB SSD, 13" , Apple iPad Pro 256 GB-3G/ GSM : iPhone6S-128GB + Mobilus M
profiel : 100/40
