Bbox3 Sagem Tool
brampiec
Bedankt: 4 keer
Is er iets wat ik zou kunnen doen om te zien waarom bij mij die waarde 0dB uitleest?
Dit is komt uit de source van mijn wan.html pagina, maar dat is volgens mij dus overal hetzelfde omdat dit software afhankelijk is:
<li data-role="fieldcontain" >
              <h3><span xmsg="WAN_NOISE_MARGIN">Noise Margin (Down/Up)</span><a href="#" class="gui-noise-btn" >(+)</a></h3>
              <p>
                <span class="gui-downstream" data-xmo-role="statistic" data-xpath="Device/DSL/Lines/Line[@uid='1']/DownstreamNoiseMargin" > </span>
                <span>/</span>
                <span class="gui-upstream" data-xmo-role="statistic" data-xpath="Device/DSL/Lines/Line[@uid='1']/UpstreamNoiseMargin" > </span>
                <span> dB</span>
dejean
Bedankt: 12 keer
Bbox 3 Sagem Tool v0.3
Downstream current bit rate:   69.999 kbps
Upstream current bit rate:     6.063 kbps
Downstream max bit rate:       136.746 kbps
Upstream max bit rate:         31.978 kbps
Downstream attenuation:        12,0 dB
Upstream attenuation:          0,0 dB
Downstream noise margin:       23,9 dB
Upstream noise margin:         27,8 dB
Proximus profile:              LP810
VDSL2 profile:                 17a
DLM:                           False
Repair:                        True
Vectoring:                     True
Repair TRUE :-(
marc_1956
Kan iemand nog is die attenuation (downstream en upstream) uitleggen of linkje naar uitleg?
Resultaat:
Downstream current bit rate:   30.063 kbps
Upstream current bit rate:     2.063 kbps
Downstream max bit rate:       59.769 kbps
Upstream max bit rate:         8.216 kbps
Downstream attenuation:        13,4 dB
Downstream noise margin:       20,5 dB
Upstream noise margin:         23,8 dB
Proximus profile:              unknown
VDSL2 profile:                 unknown
DLM:                           False
Repair:                        False
Vectoring:                     False
jackho
Bedankt: 279 keer
@DeJean
dit is een vectoring 70/10 profiel die je hebt
thomasv
Bedankt: 52 keer
Downstream current bit rate:   60,198 kbps
Upstream current bit rate:     10,004 kbps
Downstream max bit rate:       70,171 kbps
Upstream max bit rate:         10,004 kbps
Downstream attenuation:        13.3 dB
Upstream attenuation:          0.0 dB
Downstream noise margin:       0.0 dB
Upstream noise margin:         9.2 dB
Proximus profile:              LP059
VDSL2 profile:                 17a
DLM:                           True
Repair:                        False
Vectoring:                     False
:beerchug:
jantje81
Uitgedeelde bedankjes: 161 keer
Bedankt: 79 keer
Ook een meting gedaan, lijkt goed te werken! Complimenten voor pyro85. :-)
Downstream current bit rate:   60.198 kbps
Upstream current bit rate:     10.049 kbps
Downstream max bit rate:       74.348 kbps
Upstream max bit rate:         10.049 kbps
Downstream attenuation:        12,5 dB
Downstream noise margin:       0,0 dB
Upstream noise margin:         10,5 dB
VDSL2 profile:                 17a
DLM:                           True
Repair:                        False
Vectoring:                     False
EDPnet FIBER XL (500/100)
NL Ziet / VTM Go+ / GoPlay
Digi Mobile
OVH VOIP + EDPnet VOIP
cyberbug
Bedankt: 188 keer
Bij deze het resultaat van tool 0.3 :-)
Downstream current bit rate:   50.199 kbps
Upstream current bit rate:     10.004 kbps
Downstream max bit rate:       56.266 kbps
Upstream max bit rate:         -1 kbps
Downstream attenuation:        13,3 dB
Downstream noise margin:       8,0 dB
Upstream noise margin:         8,7 dB
Proximus profile:              LP058
VDSL2 profile:                 17a
DLM:                           True
Repair:                        False
Vectoring:                     False
@ Marc
wat ik van attenuation en snr vond was dat attenuation de verzwaking op het signiaal is (hier kan een ruwe afstand op berekend worden, 13.81db verzwakking per km) hoe lager deze is hoe beter
noise margin (of snr margin: signaal ruis verhoudings-reserve) is de reserve die er op de lijn zit om de huidige sync te behouden. hoe hoger deze waarde hoe beter.
Als ik mijn waarde bekijk denk ik niet dat ik hoger kom zonder verctoring.
Greetz cyberbug
leeman
Bedankt: 3 keer
hierbij mijn data met de nieuwe tool:
Upstream current bit rate:     10.054 kbps
Downstream max bit rate:       82.320 kbps
Upstream max bit rate:         19.120 kbps
Downstream attenuation:        13,6 dB
Downstream noise margin:       11,4 dB
Upstream noise margin:         13,6 dB
VDSL2 profile:                 17a
DLM:                           True
Repair:                        False
Vectoring:                     False
D3bian
Bedankt: 26 keer
Great job! Tooltje werkt al goed :)
Downstream max bit rate:       89.533 kbps
Upstream max bit rate:         10.054 kbps
Downstream attenuation:        6.8 dB
Upstream noise margin:         13.3 dB
Proximus profile:              LP145
VDSL2 profile:                 17a
DLM:                           False
Repair:                        False
Vectoring:                     True
diederik
Bedankt: 10 keer
Downstream current bit rate:   69 999 kbps
Upstream current bit rate:     10 064 kbps
Downstream max bit rate:       132 215 kbps
Upstream max bit rate:         30 357 kbps
Downstream attenuation:        4,0 dB
Downstream noise margin:       18,8 dB
Upstream noise margin:         26,1 dB
VDSL2 profile:                 17a
DLM:                           False
Repair:                        False
Vectoring:                     True
sirWard
Twitter: sirWard
Bedankt: 87 keer
Prachtige tool! Dan maar snel ook even een testje laten draaien:
Upstream current bit rate:     10.064 kbps
Downstream max bit rate:       131.703 kbps
Upstream max bit rate:         26.748 kbps
Downstream attenuation:        6,6 dB
Downstream noise margin:       16,2 dB
Upstream noise margin:         24,1 dB
VDSL2 profile:                 17a
DLM:                           False
Repair:                        False
Vectoring:                     True
:banana:
chamastam
Downstream max bit rate:       70.728 kbps
Upstream max bit rate:         14.440 kbps
Downstream attenuation:        14,3 dB
Downstream noise margin:       9,4 dB
Upstream noise margin:         19,8 dB
Proximus profile:              LP056
VDSL2 profile:                 17a
DLM:                           False
Repair:                        False
Vectoring:                     False
Ik heb eens vlug het tooltje laten lopen. :-D
Hebben jullie een idee of hier nog DLM mogelijk is?
jackho
Bedankt: 279 keer
Als de waarden kloppen die het Tool aangeeft (Downstream noise margin: 9,4 dB) , dan zit er niet veel meer in, het zal afwachten zijn op vectoring!
Laatst gewijzigd door jackho 04 feb 2015, 18:09, in totaal 1 gewijzigd.
Bedankt: 1993 keer
Recent bedankt: 13 keer
De tool geeft telkens 1 kbps of 2 kbps verschil in bitrate met de officiële profielen. Wellicht een foutje in een programma-lus?
jantje81
Bedankt: 79 keer
VDSL2 profile:                 17a
DLM:                           False
Repair:                        False
Vectoring:                     False
Uw downstream noise margin lijkt me heel laag in combinatie met je hoge Downstream max bit rate. Tenzij de specialisten hier dat kunnen verklaren lijkt me daar iets niet te kloppen.
Digi Mobile
crazydavid
Bedankt: 6 keer
Downstream current bit rate:   16.550 kbps
Upstream current bit rate:     2.054 kbps
Downstream max bit rate:       31.917 kbps
Upstream max bit rate:         2.054 kbps
Downstream attenuation:        17,4 dB
Upstream noise margin:         16,3 dB
Proximus profile:              LP702
VDSL2 profile:                 8d
DLM:                           False
Repair:                        False
Vectoring:                     False
chamastam
jantje81 schreef: Uw downstream noise margin lijkt me heel laag in combinatie met je hoge Downstream max bit rate. Tenzij de specialisten hier dat kunnen verklaren lijkt me daar iets niet te kloppen.
Ik vond dit ook al raar daarmee dat ik het hier eens vroeg.
Hopelijk zijn er specialisten aanwezig. :-)
Bedankt: 202 keer
Niemand die een Sagem wil ruilen tegen een Technicolor :twisted:
pyro85
Bedankt: 126 keer
brampiec schreef:Is er iets wat ik zou kunnen doen om te zien waarom bij mij die waarde 0dB uitleest?
              <p>
                <span>/</span>
                <span> dB</span>
K'heb eerder het vermoeden dat de Bbox effectief 0 teruggeeft als waarde.
De html-code die je hebt gepost wordt uiteindelijk verder ingevuld door de javascript na een ajax-call naar de bbox. Deze call geeft niets meer weer sinds de laatste firmware update.
Weet niet hoe technisch sterk je bent, maar als je een willekeurige ajax-call onderschept en de xpath-waarde als volgt aanpast kan je checken of het effectief 0 is: Device/DSL/Lines/Line[DownstreamNoiseMargin='0']/Status
Als je 'applied' als antwoord krijgt, is de waarde effectief 0, als je 'unknown path' weerkrijgt, is het een andere waarde.
Met Firefox heb je bepaalde developer tools die dit kunnen doen :)
Iets wat me al opvalt is dat als de current upload speed gelijk is aan de max upload speed, de downstream noise margin 0 is, Thomasv heeft dit ook voor.
dejean schreef:...
Repair TRUE :-(
Sinds kort wordt een 70/6 vectoring profiel als een repair profiel aanzien, toch volgens deze lijst: http://userbase.be/forum/viewtopic.php? ... 40#p589405
Je 70/6 profiel zal nog niet omgezet zijn naar een 70/10 profiel. T'zal gewoon een kwestie van tijd zijn, aangezien je lijn het zeker aankan.
raf1 schreef:De tool geeft telkens 1 kbps of 2 kbps verschil in bitrate met de officiële profielen. Wellicht een foutje in een programma-lus?
Dacht dat ook eerst, maar dit is niet het geval, de sync waarde verschilt (soms) een paar kb met het officieel profiel.
lacer schreef:Niemand die een Sagem wil ruilen tegen een Technicolor :twisted:
Misschien eens bellen naar de helpdesk dat je problemen hebt met uw PS4 die niet op internet kan. Als je effectief een PS4 hebt, des te beter :angel:
jackho
Bedankt: 279 keer
Inderdaad als je problemen aangeeft met NAT type met je PS4, laten ze u de technicolor omruilen met een sagemcom
MrBlueSky
Bedankt: 58 keer
Downstream current bit rate:   20 061 kbps
Upstream current bit rate:     2 063 kbps
Downstream max bit rate:       29 013 kbps
Upstream max bit rate:         5 907 kbps
Downstream attenuation:        15,2 dB
Downstream noise margin:       14,6 dB
Upstream noise margin:         11,1 dB
Proximus profile:              LP701
VDSL2 profile:                 8d
DLM:                           False
Repair:                        False
Vectoring:                     False
Leuk tooltje :D
Iemand die weet of dit een verhoging zou krijgen? De site geeft 30/2, maar ik vermoed dat dat er niet inzit.
Ik sta ook al maanden op 20/2 (op een week na, toen er een lijnprobleem was)
Bedankt: 3835 keer
@pyro85
Ik heb wat promotie gemaakt voor jouw tooltje op het Franstalig Forum, waar ze ook zeer enthousiast reageren. De vroegere B-box2 modem tool van Arno was hier ook zeer geliefd.
https://forum.adsl-bc.org/viewtopic.php ... 2#p1446932
Hieronder - voor jouw statistieken - een aantal resultaten voor het Franstalig gedeelte:
solitaire2511 » 04 Fév 2015 16:43
Downstream current bit rate:   12.063 kbps
Upstream current bit rate:     1.044 kbps
Downstream max bit rate:       22.717 kbps
Downstream attenuation:        25,8 dB
Downstream noise margin:       12,7 dB
Upstream noise margin:         18,4 dB
Proximus profile:              LP711
VDSL2 profile:                 8d
DLM:                           False
Repair:                        False
Vectoring:                     False
mike888 » 04 Fév 2015 16:45
Downstream current bit rate:   25.063 kbps
Upstream current bit rate:     2.045 kbps
Downstream max bit rate:       32.412 kbps
Upstream max bit rate:         2.045 kbps
Downstream attenuation:        14,1 dB
Upstream noise margin:         10,3 dB
DLM:                           False
Repair:                        False
Vectoring:                     False
Arowan » 04 Fév 2015 17:12
Downstream current bit rate:   4.448 kbps
Upstream current bit rate:     512 kbps
Downstream max bit rate:       4.864 kbps
Downstream attenuation:        48,5 dB
Upstream attenuation:          -0,1 dB
Downstream noise margin:       15,0 dB
Upstream noise margin:         6,1 dB
DLM:                           False
Repair:                        False
Vectoring:                     False
servperso » 04 Fév 2015 20:52
Downstream current bit rate:   50.200 kbps
Downstream max bit rate:       72.455 kbps
Downstream attenuation:        12,6 dB
Upstream noise margin:         13,1 dB
VDSL2 profile:                 17a
DLM:                           True
Repair:                        False
Vectoring:                     False
ubremoved_15739
Bedankt: 532 keer
Hoe zit het met de verdeling van de toebedeelde DSL profielen ten zuiden van het land?
Een overgrote meerderheid op de tragere snelheidsprofielen allicht?
Bedankt: 3835 keer
In afwachting van antwoord van de specialisten, waag ik hier een poging tot verklaring:
Ik denk dat we hier te maken hebben met het verschil tussen SNR (signal-to-noise ratio) en Noise Margin!
What is the Difference between noise margin and signal to noise ratio?
SNR = Signal Power / Noise Power, which is an indication of how well a receiver can distinquish a signal from random noise (non signal).
The Noise margin is the measure in Db of how much better the SNR is than the SNR required for proper operation of a receiver. To a user this may be more valuable information, since the user may not know what an acceptable SNR is for his equipment.
In het kort uitgelegd: Noise margin is het verschil in dB dat je hebt, in vegelijking met wat je minimaal nodig hebt voor een goede (stabiele) verbinding. Met andere woorden "hoeveel beter" je SNR is dan wat je nodig hebt.
Het probleem is natuurlijk dat wij niet weten welke waarde de Sagem modem als "minimum aannvaardbaar" gebruikt.
Algemeen wordt aangenomen dat 9dB deze limiet is.
Indien de "Downstream current bit rate" gelijk is aan de "Downstream max bit rate", dan heb je géén marge, dus:
  • - Noise margin = 0dB
    - SNR = 9dB (?)
Volgens mij moet je dus 9dB bijtellen, bij de waarde die de Bbox3 Sagem tool uitleest om de SNR te kennen.
PS
Eigenlijk is de noise margin een betere informatie dan de SNR: je weet precies hoeveel marge je hebt voor een mogelijke verhoging ...
qless
Bedankt: 160 keer
Mooi werk, ik zou dit wel willen integreren in de nieuwe VDSL2Tool 4.0
Uitgedeelde bedankjes: 647 keer
Bedankt: 753 keer
Downstream current bit rate:   30 063 kbps
Upstream current bit rate:     2 045 kbps
Downstream max bit rate:       55 497 kbps
Upstream max bit rate:         4 976 kbps
Downstream attenuation:        8,3 dB
Downstream noise margin:       16,0 dB
Upstream noise margin:         21,0 dB
DLM:                           False
Repair:                        False
Vectoring:                     False
Leuke tool!
Uit deze gegevens kan ik als leek afleiden dat er toch nog wat rek op mijn lijn zit, of niet?
Ik had problemen om 2 HD stromen te bekijken op TV maar sinds het bezoek van een technieker was dat plots vanzelf opgelost. Waarschijnlijk hebben ze iets in de verdeelkast aangepast want hier is niets gewijzigd.
jackho
Bedankt: 279 keer
Philippe,
"Downstream max bit rate" wordt die dan niet gegeven waarbij DTM 6dB wordt.
pyro85
Bedankt: 126 keer
philippe_d schreef:@pyro85
Dat is leuk, wist niet dat er franstalige tegenhanger bestond van Userbase :) Hoe meer feedback, hoe beter!
Bedankt voor het verzamelen van de statistieken, zal deze bijvoegen in mijn excel file.
Nicopara schreef:Leuk tooltje :D
25/2 moet er nog wel inzitten denk ik, als DLM u gunstig gezind is :)
qless schreef:Mooi werk, ik zou dit wel willen integreren in de nieuwe VDSL2Tool 4.0
Ah, dat is goed nieuws! Mijn tool is wel in .net geschreven, het is ondertussen al 10 jaar geleden dat ik nog een letter java geschreven heb :P
De tool maakt veel gebruik van dynamics en linq, dus ik denk niet dat je de code 'gewoon' zal kunnen overnemen, je zal wel wat aanpassingen moeten doen.
Dizzy schreef:Leuke tool!
Je lijn zou gerust een hogere snelheid aankunnen, maar je zit al op het maximum van wat DLM je kan geven. T'zal wachten worden op vectoring >400m voor een hogere snelheid.
mrombouts
Mijn lijnwaarden:
Downstream max bit rate:       81.218 kbps
Downstream attenuation:        14,5 dB
Upstream noise margin:         9,8 dB
VDSL2 profile:                 17a
DLM:                           False
Repair:                        False
Vectoring:                     True
Denk enkel dat dit een DLM profiel is, en geen vectoring, zie de proximus speedtest:
Max.: 63,5 Mbps download - 4,7 Mbps upload
Min.: 27,9 Mbps download - 4,7 Mbps upload.
Ik heb ook geen Proximus bericht gehad dat vectoring geactiveerd ging worden / werken gingen gebeuren in de ROP
jackho
Bedankt: 279 keer
Het is een vectoring profiel, met die snelheidstest moet je opletten want die database is soms niet op tijd aangepast!
qless
Bedankt: 160 keer
pyro85 schreef:[
Geen probleem, de laatste versie was ook al .net ;)
Alleen voor de android / iOS versie is dat een hindernis, maar dat lukt ook wel.
mrombouts
jackho schreef:Het is een vectoring profiel, met die snelheidstest moet je opletten want die database is soms niet op tijd aangepast!
Zou me toch sterk lijken (maar ik ben natuurlijk geen specialist)
Ik heb sinds december 15 dec VDSL2, op 30 dec heeft DLM mij op een 50Mbit profiel gezet en rond 11 jan op 70 Mbit.
Rond 20 januari de laatste sagem FW op de modem gepushed en sindsdien kan ik geen lijnwaarden meer zien
Ik zie ook geen verbetering in de lijnwaarden, daarom dat ik vanuit ging dat dit een DLM profiel is en geen vectoring.
De output van de Proximus speedtest had ik enkel toegevoegd als extra bewijs
jackho
Bedankt: 279 keer
't hangt ervan af wat je onder specialist verstaat, zelfs specialisten hebben ook al eens een verkeerd been afgezet :wink:
Die snelheidstest van proximus klopt meestal wel, al zijn er al die, mij gemeld hebben dat ze op verctoring staan en de test dit nog niet aangeeft.
Ik ga ook af op wat hier ook al gepost geweest is, namelijk:
Er is een klein verschil tussen het
vectoring profiel en het DLM profiel.
Vectoring: 69999/10064
DLM: 70200/10048
Bedankt: 3835 keer
- De officiële profielen geven een "Max. DSLAM troughput" (voorbeeld vectoring = 70.000/6064)
- De tool leest de effectieve snelheid uit (voorbeeld: 69.999/6063)
De profielsnelheid geeft aan de modem informatie over de maximale troughput die op de lijn toegelaten is.
De modem zal proberen zo dicht mogelijk die max. snelheid te benaderen, maar dat kan dus enkele kbps lager zijn.
In geval de SNR te laag komt, zal de effectieve sync snelheid (current troughput) nog lager zijn ...
@pyro85
* Zou jouw tool de "Max. DSLAM troughput" kunnen uitlezen? Want dan zou je nog een veel nauwkeurigere bepaling kunnen doen van het profiel, denk ik?
* Zou jouw tool de waarde van de "Impulse noise protection" kunnen uitlezen? Want dan zou je correcte info hebben over vectoring (true/false). Er zullen in de toekomst nog nieuwe vectoring profielen komen (400m-700m), en dan wordt het weer lastiger ...
pyro85
Bedankt: 126 keer
Max DSLAM troughput denk ik niet. Ik kan momenteel enkel maar de waarden ophalen die vroeger op de WAN pagina te zien waren. Aan iedere waarde op die pagina zit in de achtergrond een xpath gekoppeld, die xpaths heb ik nodig en pas ik aan om de waarden terug te kunnen ophalen. Het kan zijn dat die waarde wel ergens beschikbaar is in de bbox, maar zonder xpath is het blind zoeken...
Impulse noise protection zou wel mogelijk moeten zijn.
jackho schreef:'t hangt ervan af wat je onder specialist verstaat, zelfs specialisten hebben ook al eens een verkeerd been afgezet :wink:
DLM: 70200/10048
Die 69999 download speed kan misschien ook een aanduiding zijn voor een Broadcom kaart in de ROP in plaats van Ikanos.
Het is een gok, maar het zou een verklaring kunnen zijn voor mrrombouts.
qless schreef:Geen probleem, de laatste versie was ook al .net ;)
Ideaal, eens de code afgewerkt is, stuur ik je het visual studio project door :)
mrombouts
DLM: 70200/10048
@pyro85: De foutjes die erin zitten laten alleen maar zien hoe complex de profielen allemaal zijn. Het gaat alleen maar complexer worden met vectoring op langere lijnen en DLM op vectoring profielen. Ik vind het in ieder geval een prachtig tooltje, nu heb je tenminste terug een idee wat de mogelijkheden van je lijn zijn en waaraan gesynct wordt.
jackho
Bedankt: 279 keer
Op hoeveel je modem synchroniseert kan je voorlopig ook min of meer te weten komen met een speedtest, bv. voor iemand met een bb3/T thuis zit.
mrombouts
@jackho, inderdaad, min of meer, behalve als er, zoals soms gemeld wordt, een cap op de downloadsnelheid zit.
jackho
Bedankt: 279 keer
Ik spreek inderdaad voor Proximus waar er nog geen cap op de download geldt.
Bedankt: 202 keer
Ja, maar mij interesseert het vooral om te weten hoe het zit met de kwaliteit van je lijn en of er nog een beetje marge inzit om later 100 Mb/s download te krijgen en misschien zelfs meer :-D . Met een technicolor kunnen wij dat (nog) niet weten.
