pstatex vergelijkingske
Wil je gewoon eens testen of je klaar bent om te posten? Doe dit dan hier.
cptKangaroo
Bedankt: 276 keer
Vergelijkingstopicske voor mezelf van pstatex output bij verschillende syncprofielen (http://userbase.be/forum/viewtopic.php? ... 78#p553378)
20140628 -- 30Mbit profiel
Extended Port Status
Bme: 1 Port: 1
Downstream line rate: 34528 kbps
Upstream line rate: 7392 kbps
Bearer0 Downstream payload rate: 0 kbps
Bearer1 Downstream payload rate: 30040 kbps
Bearer0 Upstream payload rate: 0 kbps
Bearer1 Upstream payload rate: 6048 kbps
Downstream attainable payload rate: 88864 kbps
Downstream attainable line rate: 107276 kbps
Downstream Training Margin: 26.1 dB
Downstream Line Protection (Bearer1 Path): 1.0 DMT Symbols
Upstream Line Protection (Bearer1 Path): 1.0 DMT Symbols
Near-end ITU Vendor Id: 0xb500494b4e530200
Far-end ITU Vendor Id: 0xb500494b4e530000
Downstream delay: 7.5 ms
Upstream delay: 5.4 ms
Tx total power -13.8 dbm
FE Tx total power 12.2 dbm
VDSL Estimated Loop Length : 751 ft
G.Hs Estimated Near End Loop Length : 2058 ft
G.Hs Estimated Far End Loop Length :793 ft
Current framing mode: 0x10
Bandplan Type...........: 0
No. of Upstream Bands...: 2
No. of Downstream Bands.: 3
Line Type: 0x04000000#
20140726 -- 50Mbit profiel (DLM start reconnect was op 20140711)
Bme: 1 Port: 1
Downstream line rate: 57664 kbps
Bearer1 Downstream payload rate: 50200 kbps
Downstream attainable payload rate: 88612 kbps
Downstream attainable line rate: 106972 kbps
Downstream Training Margin: 19.3 dB
Downstream delay: 7.7 ms
Tx total power -13.2 dbm
VDSL Estimated Loop Length : 762 ft
G.Hs Estimated Near End Loop Length : 2068 ft
G.Hs Estimated Far End Loop Length :799 ft
*EDIT*
20140806 -- 70 Mbit profiel (snelheid is nog 50Mbit tijdens eerste sessie)
Bme: 1 Port: 1
Downstream line rate: 80384 kbps
Bearer1 Downstream payload rate: 69992 kbps
Downstream attainable payload rate: 87660 kbps
Downstream attainable line rate: 105824 kbps
Downstream Training Margin: 12.6 dB
Tx total power -13.3 dbm
VDSL Estimated Loop Length : 761 ft
G.Hs Estimated Near End Loop Length : 2041 ft
G.Hs Estimated Far End Loop Length :805 ft
*/EDIT*
DLM upgrade komt 15 dagen na helpdesk "ik zal aan Belgacom vragen om te kijken of uw lijn sneller kan", en 94 dagen na vdsl poortwissel (het uitblijven van DLM was de reden om de helpdesk in te schakelen). Volgens de uitleg van DLM: http://userbase.be/forum/viewtopic.php?t=37511 vermoed ik dat de helpdesk een TBF startte die na 10 dagen evalueren DLM actief zette, en dan na 2 DLM evaluatiecycles (0.5 + 2 dagen) de beslissing tot verhoging nam die dan ongeveer 3 dagen later inging.
Conclusie: misschien is het dus best om na een vdsl poortwissel zelf een automatische lijntest (TBF) te starten?
cptKangaroo
Bedankt: 276 keer
Gewoon postje om bij te houden wanneer DLM het profiel updatet naar 70/10, omdat ik vermoed dat deze forced reboot mogelijk DLM-related is:
Sun, 14 Dec 2014 01:06:14 GMT PPPOE: session established
Voorlopig nog steeds op 70/6 profiel met 65.5/3.8 snelheden.
EDIT: forced reconnect (12.5 dag na reboot):
Fri, 26 Dec 2014 13:57:14 GMT PPPOE: session established
cptKangaroo
Bedankt: 276 keer
:banana:
20150116 -- DLM upgrade to 70/10Mbit (65.5/7.7Mbit real speeds) ScarletOne/BBOX2/no vectoring yet.
33 dagen na 14 december (start van DLM, denk ik) en ik denk dat er eerder deze week nog een forced reboot was (maar vergeten te registreren voor eigen stroomonderbreking gisteren).
# vdsl pstatex
Bme: 1 Port: 1
Upstream line rate: 12256 kbps
Bearer1 Upstream payload rate: 10048 kbps
Downstream attainable payload rate: 88948 kbps
Downstream attainable line rate: 107380 kbps
Downstream Training Margin: 13.0 dB
Upstream delay: 5.5 ms
Tx total power -14.5 dbm
VDSL Estimated Loop Length : 712 ft
G.Hs Estimated Near End Loop Length : 2040 ft
G.Hs Estimated Far End Loop Length :769 ft
EDIT: ik meen me te herinneren me dat de forced reboot tijd van de vermoedelijke DLM evaluatie eerder deze week, overeen kwam met die in december (01:06).
cptKangaroo
Bedankt: 276 keer
Blijkbaar is onze ROP nu toch vectored maar vectoring zal waarschijnlijk nog niet opstaan want 14.4dB training margin is geen al te grote verandering: die hing meestal rond de 13.2dB en sprong occasioneel naar 15.3dB voor korte periodes. Proximus snelheidstest toont nog altijd 63/8 max (70Mbit). Niks gemerkt van de omschakeling naar een Broadcom kaart.
# vdsl pstatex
Bme: 1 Port: 1
Downstream line rate: 69120 kbps
Upstream line rate: 13312 kbps
Bearer1 Downstream payload rate: 60176 kbps
Bearer1 Upstream payload rate: 10064 kbps
Downstream attainable payload rate: 82564 kbps
Downstream attainable line rate: 99676 kbps
Downstream Training Margin: 14.4 dB
Upstream Line Protection (Bearer1 Path): 3.0 DMT Symbols
Far-end ITU Vendor Id: 0xb5004244434da45f
Upstream delay: 8.2 ms
Tx total power -14.8 dbm
FE Tx total power 12.8 dbm
VDSL Estimated Loop Length : 759 ft
G.Hs Estimated Near End Loop Length : 0 ft
G.Hs Estimated Far End Loop Length :0 ft
silencer
Bedankt: 103 keer
0xb5004244434da45f zegt genoeg he.
cptKangaroo
Bedankt: 276 keer
Inderdeed -- de kleine verbetering van de training margin door de kaartswitch was blijkbaar voldoende om me nu weer op 70Mbit te zetten:
# vdsl pstatex
Bme: 1 Port: 1
Downstream line rate: 80608 kbps
Upstream line rate: 13408 kbps
Bearer1 Downstream payload rate: 70184 kbps
Downstream attainable payload rate: 82508 kbps
Downstream attainable line rate: 99608 kbps
Downstream Training Margin: 11.1 dB
Upstream delay: 8.1 ms
VDSL Estimated Loop Length : 764 ft
qless
Bedankt: 161 keer
cptKangaroo schreef:Blijkbaar is onze ROP nu toch vectored maar vectoring zal waarschijnlijk nog niet opstaan want 14.4dB training margin is geen al te grote verandering: die hing meestal rond de 13.2dB en sprong occasioneel naar 15.3dB voor korte periodes. Proximus snelheidstest toont nog altijd 63/8 max (70Mbit). Niks gemerkt van de omschakeling naar een Broadcom kaart.
Met deze modem ga je niks merken van vectoring verder, hoger dan deze DLM kom je niet.
MV 1000/500 on Fiberklaar
Unifi cloud gateway max
Mac Mini M1 16GB/512GB
https://arnoraps.be
cptKangaroo
Bedankt: 276 keer
Deze zomer ga ik een ruil vragen van de verouderde/slow-as-hell V3b tv decoder, en dan meteen ook van de router. Hopelijk zijn ze bij Scarlet toch een beetje redelijk, anders zou het deze keer wel eens Orange kunnen worden.
Terug naar “Test”
