Bij deze dus "for sale"!
Scanners verkeren in nieuwstaat, zijn voorzien van USB-connectie & hebben allemaal een bijhorende stand.
Supersnelle toestellen met groene dot projectie bij positieve scan.
Toestellen zijn gereset naar de factory settings ahv van de Datalogic Alladin software.
2 hebben een krulkabel, 2 een rechte -- waarvan 1 met optionele voeding.
Pics :
1x QuickScan I QD2110 met Datalogic STD-QD20-BK stand & Cable, USB, Type A, Straight, 6 Feet, CAB-426E (type n° 90A052044)
2x QuickScan I QD2110 met Datalogic STD-QD20-BK stand & Cable, USB, Type A, Coiled, 9 Feet, CAB-424E (type n° 90A052043)
1x QuickScan I QD2110 met Datalogic STD-QD20-BK stand & Cable, USB, Type A, Coiled, 9 Feet, CAB-412 Optional Power (type n° 90A051922)
"The QuickScan reader series is Datalogic Scanning’s value line of general purpose handheld data collection products. The QuickScan I QD2100 linear imaging reader is an entry level product that is perfect for use in retail and office environments plus activities associated with couriers and postal services.
The QD2100 is small, lightweight and its ergonomic design is comfortable to use during daily operations. It offers snappy reading performance especially on hard to read bar codes and is capable of reading a wide range of symbologies including the majority of 1D codes plus GS1 DataBar™ linear codes. The QD2100 reader features Datalogic’s exclusive patented ‘Green Spot’ for good read feedback directly on the code. When in Stand Mode, the Green Spot remains on to show the operator where to position the code for quick and intuitive reading.
Like the QuickScan L reader, the QD2100 has been designed with durability in mind. One of the most vulnerable features of any scanner is damage to the scan window. When such incidents happen, the scanner may have to be replaced. The QD2100 was specifically designed so that a replacement window pack can be ordered to replace damaged or scratched windows without having to send the scanner away for repairs. This helps to reduce the total cost of ownership during the life of the scanner and helps to ensure that it is always available for use.
The QD2100 is available with two multi-interface options: RS-232 / IBM 46XX / USB and RS-232 / USB / Keyboard Wedge / Wand and includes various packaging options so that it can be ordered as the scanner only or as a kit equipped with a scanner, cable and stand to facilitate hand-free reading options. The Datalogic Aladdin™ configuration program provides user-friendly features that simplify the start-up procedure, even for inexperienced users."
Alle info/specs/drivers ivm scanner : http://www.datalogic.com/eng/products/a ... d-164.html
Bieden vanaf 15 euro excl verzending met opbod van 5 euro.
Verzending via Kiala, B-post of ophaling te Lier.
Afsluiting 48u na het hoogste bod.
Happy bidding!
Cheers,
S.
