3Com Switch & Juniper Firewall
shiseido
Uitgedeelde bedankjes: 4 keer
Bedankt: 19 keer
For sale :
*** 3com OfficeConnect Unmanaged Gigabit 8p Switch (type 3C1670800B) ***
Specs :
Standards :
IEEE 802.1p Priority Tags
IEEE 802.3 Ethernet
IEEE 802.3ab Gigabit Ethernet
IEEE 802.3u Fast Ethernet
Ports : 8 x RJ45
Speed : 10/100/1000Mbps
Switching Method : Store and Forward
VLAN Support : No
Power Input voltage: 100-240 VAC, 50/60 Hz
Dimensions : 8.1" x 5.3" x 1.4"
Weight : 2.2 lbs.
Temperature : 0ºC to 40ºC (32ºF to 104ºF)
Humidity : 10% - 90%, Non-condensing
Wordt geleverd met adapter.
Bieden vanaf 5 euro exclusief verzending.
Afsluiting 48u na het hoogste bod.
*** Juniper SSG-5 Firewall (type SSG-5-SB) ***
Toestel is geflashed naar ScreenOS v 6.3.0r14.0 en bevat buiten de standaard -- geen extra licenties.
(Printed manual included)
Specs :
Networking
Compliant Standards : IEEE 802.1Q , IEEE 802.1x , X.509
Connectivity Technology : Wired
Data Link Protocol : Ethernet , Fast Ethernet , PPP
Data Transfer Rate : 10/100
Features : 168-bit encryption , 56-bit encryption , Antivirus analysis , DDos attack prevention , Deep Packet Inspection (DPI) , DHCP support , DiffServ support , DoS attack prevention , Firewall protection , High Availability , LDAP support , Manageable , Modular design , NAT support , Packet filtering , PAT support , Routing , Syslog support , Transparency , URL filtering , VLAN support , VPN support
Form Factor : External
Network Transport Protocol : IPSec , L2TP , NetBEUI/NetBIOS , PPPoE
Ports Qty : 7
Remote Management Protocol : HTTP , HTTPS , SNMP , SNMP 2 , Telnet
Routing Protocol : BGP , ECMP , OSPF , RIP-1 , RIP-2 , Static IP routing
Status Indicators : Alarm , Link activity , Port status , Power , Status
Type : Security appliance
Miscellaneous
Authentication Method : LDAP , RADIUS , Secure Shell (SSH) , Secure Shell v.2 (SSH2) , X.509 certificates
Compliant Standards : BSMI , C-Tick , CB , CSA , cUL , FCC Class B certified , UL , VCCI Class A ITE
Encryption Algorithm : AES , DES , IKE , MD5 , PKI , RSA , SHA-1 , Triple DES
License Qty : 10 users
Rack Mounting Kit : Optional
OS Provided
Type : ScreenOS
Power Device
Nominal Voltage : AC 120/230 V
Type : Internal power supply
Capacity
Type : Concurrent sessions
Value : 8000
Type : Security policies
Value : 200
Type : Connection / user qty
Value : Unlimited
Type : Authenticated users (internal database)
Value : 100
Type : Concurrent VPN tunnels
Value : 25
Type : Security zones
Value : 8
Type : Static routes
Value : 1024
Performance
Type : VPN throughput (3DES IPSec)
Value : 40 Mbps
Type : Firewall throughput
Value : 160 Mbps
RAM
Installed Size : 128 MB
Verzending via Kiala, B-post of ophaling te Lier.
Cheers,
Shiseido
Bedankt: 782 keer
5 euro voor de switch, 5 euro voor de juniper
D3bian
Bedankt: 26 keer
15 Euro voor de Juniper
Bedankt: 782 keer
20 voor de juniper
shiseido
Bedankt: 19 keer
laatste up voor de 3Com switch welke vanavond vervalt om 22:17
Misschien nog even toevoegen dat er een anti-sniperegel van 30 minuten wordt gehanteerd
shiseido schreef:Misschien nog even toevoegen dat er een anti-sniperegel van 30 minuten wordt gehanteerd
Geen idee wat een "anti-sniperegel" is... maar de regels op het forum zijn volgens mij gewoon "Afsluiting x-uur na het hoogste bod." (zonder verdere fantasietjes)
shiseido
Bedankt: 19 keer
Ooops -- my wrong! was even vergeten dat het niet met een vastgesteld uur, maar met xx uur na hoogste bod.
Ik zal het nooit meer doen :-D
shiseido
Bedankt: 19 keer
ITnetadmin it's yours! :)
PM komt eraan.
shiseido
Bedankt: 19 keer
(3Com switch that is..)
exop
Bedankt: 27 keer
25 voor de juniper
Bedankt: 782 keer
Ik wil nu ni de moeilijke mens uithangen, maar eigenlijk is dat bod enkele minuten te laat ;-)
Ik zie niet in wat daar moeilijk aan is... correct is correct... het is dus 3 minuten te laat.
Uitgedeelde bedankjes: 1695 keer
Bedankt: 1504 keer
Recent bedankt: 13 keer
Klopt. Het voorlaatste bod was dus winnend.
shiseido
Bedankt: 19 keer
Right on!
PM komt eraan -- sold out.
exop
Bedankt: 27 keer
Jammer! :D
