Bash script bomen en bos
Heronic
Bedankt: 208 keer
Heb mij deze nacht eens laten gaan en zit nu met een laatste probleem.
Dit stuk code :
echo "   <Scrapers>" >> config.xml
echo "     <Site descFilePerGame="True" name="local nfo" searchGameByCRC="False">" >> config.xml
echo "       <Scraper parseInstruction="00 - local nfo.xml" source="nfo" />" >> config.xml
echo "     </Site>" >> config.xml
echo "     <Site descFilePerGame="True" name="thegamesdb.net" searchGameByCRC="False">" >> config.xml
echo "       <Scraper parseInstruction="02 - thegamesdb.xml" source="http://thegamesdb.net/api/GetGame.php?name=%GAME%&platform=%PLATFORM%" />" >> config.xml
echo "     <Site descFilePerGame="True" name="giantbomb.com" searchGameByCRC="False">" >> config.xml
echo "       <Scraper parseInstruction="03.01 - giantbomb - search.xml" returnUrl="true" source="http://api.giantbomb.com/search/?api_key=%GIANTB$" >> config.xml
echo "       <Scraper parseInstruction="03.02 - giantbomb - detail.xml" source="1" />" >> config.xml
echo "     <Site descFilePerGame="True" name="mobygames.com" searchGameByCRC="False">" >> config.xml
echo "       <Scraper parseInstruction="04.01 - mobygames - gamesearch.xml" returnUrl="true" source="http://www.mobygames.com/search/quick?game=%$" >> config.xml
echo "       <Scraper parseInstruction="04.02 - mobygames - details.xml" source="1" />" >> config.xml
echo "       <Scraper parseInstruction="04.03 - mobygames - coverlink front.xml" returnUrl="true" source="1" sourceAppend="cover-art" />" >> config.xml
echo "       <Scraper parseInstruction="04.04 - mobygames - coverdetail front.xml" source="2" />" >> config.xml
echo "       <Scraper parseInstruction="04.05 - mobygames - coverlink back.xml" returnUrl="true" source="1" sourceAppend="cover-art" />" >> config.xml
echo "       <Scraper parseInstruction="04.06 - mobygames - coverdetail back.xml" source="3" />" >> config.xml
echo "       <Scraper parseInstruction="04.07 - mobygames - coverlink media.xml" returnUrl="true" source="1" sourceAppend="cover-art" />" >> config.xml
echo "       <Scraper parseInstruction="04.08 - mobygames - coverdetail media.xml" source="4" />" >> config.xml
echo "       <Scraper parseInstruction="04.09 - mobygames - screenshotlink.xml" returnUrl="true" source="1" sourceAppend="screenshots" />" >> config.xml
echo "       <Scraper parseInstruction="04.10 - mobygames - screenshot detail.xml" source="5" />" >> config.xml
echo "     <Site descFilePerGame="True" name="archive.vg" searchGameByCRC="False">" >> config.xml
echo "       <Scraper encoding="iso-8859-1" parseInstruction="05.01 - archive - search.xml" returnUrl="true" source="http://api.archive.vg/2.0/Ar$" >> config.xml
echo "       <Scraper encoding="iso-8859-1" parseInstruction="05.02 - archive - detail.xml" source="1" />" >> config.xml
echo "     <Site descFilePerGame="True" name="maws.mameworld.info" searchGameByCRC="False">" >> config.xml
echo "       <Scraper encoding="iso-8859-1" parseInstruction="06 - maws.xml" source="http://maws.mameworld.info/maws/romset/%GAME%" />" >> config.xml
echo "   </Scrapers>" >> config.xml
echo " </config>" >> config.xml
Graag wat hulp hierbij.
blijkbaar helpt \ niet echt om de & van &amp te neutraliseren. En zo nog van kleine probleempjes.
Heb mooi wat uren in het script gestopt en mevrouw vind dat het genoeg geweest is, ik weet niet echt hoe ik mijn probleem moet verwoorden om via google een oplossing te vinden.
Laatst gewijzigd door Heronic 05 jan 2014, 21:28, in totaal 1 gewijzigd.
elmariachi2920
Bedankt: 8 keer
probeer eens het volgende:
echo "       <Scraper parseInstruction='02 - thegamesdb.xml' source='http://thegamesdb.net/api/GetGame.php?name=%GAME%&platform=%PLATFORM%' />" >> config.xml
ik denk dat het vervangen van " door ' tussen de eerste en laatste " je probleem zal oplossen
ik zal proberen te visualiseren wat cmd als tekst ziet en wat als commando
tekst is vet commando is niet vet
echo " <Scraper parseInstruction="02 - thegamesdb.xml" source="http://thegamesdb.net/api/GetGame.php?n ... ATFORM%"[b] />[/b]" >> config.xml
na de aanpassing zou het het volgende moeten zijn
echo " <Scraper parseInstruction='02 - thegamesdb.xml' source='http://thegamesdb.net/api/GetGame.php?n ... =%PLATFORM%' />" >> config.xml
edit: visualiseren tekst/commando
Laatst gewijzigd door elmariachi2920 05 jan 2014, 21:28, in totaal 1 gewijzigd.
brubbel
Bedankt: 180 keer
Die "\" heet een "escape character". Misschien helpt dit je al op weg.
Heronic
Bedankt: 208 keer
Bedankt voor de info.
Met die ' ipv " werkt het wel op zich maar gaat die uiteindelijke "xml" dan ook nog goed gelezen worden?
Het heeft weinig zin te focussen op foutmeldingen wegwerken als het resultaat niet meer zou kloppen.
Ik probeer gewoon de inhoud van een xml hersamen te stellen, vandaar deze echo "" >> config.xml.
Wat die escape betreft heb ik hier niet veel geniet van (heb hem wel al nodig gehad.)
Terug naar “Software en apps”
