pfsense edpnet native ipv6
Ofloo
Bedankt: 92 keer
Voor de één of andere reden werkt de ipv6 range vanaf de lan interface niet. Iemand een idee, 'k heb al default gateway in gesteld naar het pppoe ip maar dat helpt blijkbaar niet. Ping is wat hoog omdat de lijn volledig in gebruik is.
#ping6 -c 3 -S 2a02:578:x::1 ipv6.google.com
PING6(56=40+8+8 bytes) 2a02:578:x::1 --> 2a00:1450:4013:c00::6a
--- ipv6.l.google.com ping6 statistics ---
3 packets transmitted, 0 packets received, 100.0% packet loss
# ping6 -c 3 -S 2a02:578:8401:1500:20d:b9ff:x:x ipv6.google.com
PING6(56=40+8+8 bytes) 2a02:578:8401:1500:20d:b9ff:x:x --> 2a00:1450:4013:c00::6a
16 bytes from 2a00:1450:4013:c00::6a, icmp_seq=0 hlim=57 time=372.608 ms
16 bytes from 2a00:1450:4013:c00::6a, icmp_seq=1 hlim=57 time=443.699 ms
16 bytes from 2a00:1450:4013:c00::6a, icmp_seq=2 hlim=57 time=376.829 ms
3 packets transmitted, 3 packets received, 0.0% packet loss
round-trip min/avg/max/std-dev = 372.608/397.712/443.699/32.563 ms
# ping6 -c 3 -S 2a02:578:x::1 2a02:578:8401:1500:20d:b9ff:x:x
PING6(56=40+8+8 bytes) 2a02:578:x::1 --> 2a02:578:8401:1500:20d:b9ff:x:x
16 bytes from 2a02:578:8401:1500:20d:b9ff:x:x, icmp_seq=0 hlim=64 time=1.042 ms
16 bytes from 2a02:578:8401:1500:20d:b9ff:x:x, icmp_seq=1 hlim=64 time=0.226 ms
16 bytes from 2a02:578:8401:1500:20d:b9ff:x:x, icmp_seq=2 hlim=64 time=0.239 ms
--- 2a02:578:8401:1500:20d:b9ff:fe2b:7f74 ping6 statistics ---
round-trip min/avg/max/std-dev = 0.226/0.502/1.042/0.382 ms
IPv6 heb ik nooit werkende gekregen met pfsense helaas...
Ofloo
Bedankt: 92 keer
het werkt wel enkel niet voor de lan, .. 'k denk dat het is omdat ik 6to4 en native ipv6 meng.
Ofloo
Bedankt: 92 keer
Eindelijk vandaag werkt het.
ping6 -c 1 -S 2a02:578:x:1::1 google.be
PING6(56=40+8+8 bytes) 2a02:578:x:1::1 --> 2a00:1450:4013:c00::5e
16 bytes from 2a00:1450:4013:c00::5e, icmp_seq=0 hlim=56 time=15.793 ms
--- google.be ping6 statistics ---
1 packets transmitted, 1 packets received, 0.0% packet loss
round-trip min/avg/max/std-dev = 15.793/15.793/15.793/0.000 ms
heb openbgpd geïnstalleerd, .. en vervolgens de volgende config pppoe dhcp6 en gewoon statisch mijn interfaces toegewezen.
openbgpd config heb het as gebruikt van edpnet
AS 9031
fib-update yes
listen on 213.219.170.x
router-id 213.219.170.x
network 2a02:578:x::/48
network 212.71.19.x/28
#deny from any
#deny to any
Ofloo
Bedankt: 92 keer
IPv4 EDPnet
ping -c 4 google.be
PING google.be (85.234.204.223): 56 data bytes
64 bytes from 85.234.204.223: icmp_seq=0 ttl=60 time=9.862 ms
64 bytes from 85.234.204.223: icmp_seq=1 ttl=60 time=9.385 ms
64 bytes from 85.234.204.223: icmp_seq=2 ttl=60 time=9.481 ms
64 bytes from 85.234.204.223: icmp_seq=3 ttl=60 time=9.277 ms
--- google.be ping statistics ---
4 packets transmitted, 4 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 9.277/9.501/9.862/0.220 ms
Native IPv6 EDPnet
ping6 -c 4 -S 2a02:578:x1:1::f google.be
PING6(56=40+8+8 bytes) 2a02:578:x:1::f --> 2a00:1450:400c:c05::5e
16 bytes from 2a00:1450:400c:c05::5e, icmp_seq=0 hlim=54 time=21.960 ms
16 bytes from 2a00:1450:400c:c05::5e, icmp_seq=1 hlim=54 time=21.519 ms
16 bytes from 2a00:1450:400c:c05::5e, icmp_seq=2 hlim=54 time=21.625 ms
16 bytes from 2a00:1450:400c:c05::5e, icmp_seq=3 hlim=54 time=23.025 ms
round-trip min/avg/max/std-dev = 21.519/22.032/23.025/0.596 ms
6to4
ping6 -c 4 -S 2002:d447:x::f google.be
PING6(56=40+8+8 bytes) 2002:d447:x::f --> 2a00:1450:400c:c05::5e
16 bytes from 2a00:1450:400c:c05::5e, icmp_seq=0 hlim=57 time=32.060 ms
16 bytes from 2a00:1450:400c:c05::5e, icmp_seq=1 hlim=57 time=30.553 ms
16 bytes from 2a00:1450:400c:c05::5e, icmp_seq=2 hlim=57 time=31.444 ms
16 bytes from 2a00:1450:400c:c05::5e, icmp_seq=3 hlim=57 time=31.538 ms
round-trip min/avg/max/std-dev = 30.553/31.399/32.060/0.542 ms
