freepbx + weepee
- fryelectro
- Uitgedeelde bedankjes: 378 keer
- Bedankt: 177 keer
Ter info, dit is hoe bij mij een gesprek binnenkomt, bemerk de DID notatie. Hiervoor bestaat een inbound route naar een interne extensie.
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [323369xxxx@from-trunk:1] Set("SIP/weepee-0000004d", "__FROM_DID=323369xxxx") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [323369xxxx@from-trunk:2] Gosub("SIP/weepee-0000004d", "app-blacklist-check,s,1()") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [s@app-blacklist-check:1] GotoIf("SIP/weepee-0000004d", "0?blacklisted") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [s@app-blacklist-check:2] Set("SIP/weepee-0000004d", "CALLED_BLACKLIST=1") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [s@app-blacklist-check:3] Return("SIP/weepee-0000004d", "") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [323369xxxx@from-trunk:3] Set("SIP/weepee-0000004d", "CDR(did)=323369xxxx") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [323369xxxx@from-trunk:4] ExecIf("SIP/weepee-0000004d", "0 ?Set(CALLERID(name)=049xxxxxxx)") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [323369xxxx@from-trunk:5] Set("SIP/weepee-0000004d", "__CALLINGPRES_SV=allowed_not_screened") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [323369xxxx@from-trunk:6] Set("SIP/weepee-0000004d", "CALLERPRES()=allowed_not_screened") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Executing [323369xxxx@from-trunk:7] Goto("SIP/weepee-0000004d", "from-did-direct,xxxx,1") in new stack
[2012-11-25 11:56:27] VERBOSE[29540] pbx.c: -- Goto (from-did-direct,xxxx,1)Edpnet VDSL XL - 100/35 Fritz!Box 7530
Orange Go Extreme
Orange Go Extreme
- fryelectro
- Bedankt: 177 keer
BTW feedback voor Krisken;
Die backup sip trunk doet zijn ding hoor
Heb de primary switch effe in iptables geblokkeerd en wat later zie je in de logs dat asterisk de connectie naar die switch verliest. Inkomende gesprekken en uitgaande gesprekken gaan vlotjes verder over de backup sip trunk
Orange Go Extreme
Orange Go Extreme
- krisken
- Bedankt: 1035 keer
Aha toch maar eens verder ermee spelen dan
En hoe weet freepbx welke trunk je main is, en welke je backup?
VOiD
- Bedankt: 224 keer
Door de volgorde van je trunks in je uitgaande routes uiteraard. Voor de PBX maakt het geen verschil of het een 'backup' trunk is of niet, jij moet beslissen wanneer je deze trunk wenst te gebruiken. En inkomend heeft het al helemaal geen belang.
Internet: Fastfiber
GSM: Proximus
GSM: Proximus
- jphermans
- Bedankt: 109 keer
Hieronder hoe ik het heb naar een softphone. Voip telefoon is onderweg.fryelectro schreef:Ter info, dit is hoe bij mij een gesprek binnenkomt, bemerk de DID notatie. Hiervoor bestaat een inbound route naar een interne extensie.
Internet via Mobile Vikings
- jphermans
- Bedankt: 109 keer
[2012-11-27 15:50:33] VERBOSE[2718] netsock2.c: == Using SIP RTP TOS bits 184
[2012-11-27 15:50:33] VERBOSE[2718] netsock2.c: == Using SIP RTP CoS mark 5
[2012-11-27 15:50:33] VERBOSE[30743] pbx.c: -- Executing [32472xxxxxx@from-internal:1] ResetCDR("SIP/100-0000001a", "") in new stack
[2012-11-27 15:50:33] VERBOSE[30743] pbx.c: -- Executing [32472xxxxxx@from-internal:2] NoCDR("SIP/100-0000001a", "") in new stack
[2012-11-27 15:50:33] VERBOSE[30743] pbx.c: -- Executing [32472xxxxxx@from-internal:3] Progress("SIP/100-0000001a", "") in new stack
[2012-11-27 15:50:33] VERBOSE[30743] pbx.c: -- Executing [32472xxxxxx@from-internal:4] Wait("SIP/100-0000001a", "1") in new stack
[2012-11-27 15:50:34] VERBOSE[30743] pbx.c: -- Executing [32472xxxxxx@from-internal:5] Progress("SIP/100-0000001a", "") in new stack
[2012-11-27 15:50:34] VERBOSE[30743] pbx.c: -- Executing [32472xxxxxx@from-internal:6] Playback("SIP/100-0000001a", "silence/1&cannot-complete-as-dialed&check-number-dial-again,noanswer") in new stack
[2012-11-27 15:50:34] VERBOSE[30743] file.c: -- <SIP/100-0000001a> Playing 'silence/1.ulaw' (language 'en')
[2012-11-27 15:50:35] VERBOSE[30743] file.c: -- <SIP/100-0000001a> Playing 'cannot-complete-as-dialed.ulaw' (language 'en')
[2012-11-27 15:50:37] VERBOSE[30743] pbx.c: == Spawn extension (from-internal, 32472xxxxxxx, 6) exited non-zero on 'SIP/100-0000001a'
[2012-11-27 15:50:37] VERBOSE[30743] pbx.c: -- Executing [h@from-internal:1] Hangup("SIP/100-0000001a", "") in new stack
[2012-11-27 15:50:37] VERBOSE[30743] pbx.c: == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/100-0000001a'Hierboven alvast een stukje logfile.
Iemand een idee hoe dit op te lossen ?
Probeer voorlopig te bellen met x-lite. Voip fone is onderweg.
devastator
- Bedankt: 70 keer
Sorry om deze oude thread opnieuw lezen in te blazen, maar dat leek me beter dan een nieuwe thread te starten ...
Ik heb 3 accounts bij weepee: 1 forward account, en 2 'gewone' accounts.
Incomende calls op de forward account worden doorgestuurd naar de 2 accounts, zodat ik tegelijkertijd de call binnenkrijg op mijn smartphone en C610IP.
Nu wil ik echter die van mijn smartphone overhevelen naar FreePBX. Moet ik dan de forward account of de normale account configureren in FreePBX ?
Volgens deze pdf zou ik een iax adres moeten invullen, maar dat heb ik niet ...
Kan iemand mij verder helpen ?
weepeechris
- Bedankt: 80 keer
Voor FreePBX zal je een Sip Trunk account nodig hebben, een gewone SIP account of FWD account zal niet werken.
Maar in principe kan je met een PBX en een sip trunk alles doen wat je nu met FWD en SIP doet
devastator
- Bedankt: 70 keer
Hoi Chris,
bedankt voor je reactie. Kan ik een nieuwe account aan te maken voor deze SIP Trunk ?
devastator
- Bedankt: 70 keer
Heb een trunk aangemaakt.
Moet ik dan in de forward account het nr van deze account ook vermelden ?
VOiD
- Bedankt: 224 keer
Pardon ? Waarom zou een gewone SIP account niet werken met FreePBX ?weepeechris schreef:Voor FreePBX zal je een Sip Trunk account nodig hebben, een gewone SIP account of FWD account zal niet werken.
Internet: Fastfiber
GSM: Proximus
GSM: Proximus
weepeechris
- Bedankt: 80 keer
@VoID PBX = trunk nodig
@devastator die hele forwarding kan je in principe zelfs volledig in je pbx regelen
- krisken
Zorg er eerst voor dat alle nummers en accounts die je op heden bij WeePee hebt toekomen op je trunk account. Dan kan je beginnen spelen met je PBX en gaat een wondere wereld open voor jedevastator schreef:Heb een trunk aangemaakt.
devastator
- Bedankt: 70 keer
Momenteel is mijn nr gekoppeld aan mijn forward account...
Voorlopig zou ik dat nog even zo willen houden, zodat mijn C610IP gewoon blijft werken.
Kan ik de PBX openemen in de forward account, zodat een oproep geforward wordt vanuit WeePee naar mijn SIP account en SIP trunk ?
VOiD
- Bedankt: 224 keer
Chris, helemaal niet. Ik heb hier mischien wel 10 accounts op een FreePBX gekoppeld dewelke géén trunk accounts zijn. Trunk is enkel nodig indien je meerdere nummers via 1 registratie wil. Als je slechts 1 nummer hebt kan je beter een gewone account nemen.weepeechris schreef:@VoID PBX = trunk nodig
Internet: Fastfiber
GSM: Proximus
GSM: Proximus
devastator
- Bedankt: 70 keer
@VoID
Hoe stel je dat dan concreet in ?
weepeechris
- Bedankt: 80 keer
@VoID we leren bij
, normaalgezien is iets wat Asterisk-based is, best met 1 registratie. Met wat code en een goede netwerkconfiguratie kan het idd werken. Toch blijf ik bij mijn advies.
VOiD
- Bedankt: 224 keer
@weepeechris: Helemaal niets van speciale code nodig hier
@devastator:
Gewoon een SIP trunk aanmaken en de volgende config
- In de PEER details:
- In de register string:
Vervolgens *telefoonnummer* configureren in de inbound routes.
@devastator:
username=32990900xxxx
type=friend
trustrpid=yes
sendrpid=yes
secret=*password*
qualify=yes
insecure=port,invite
host=sswX.brussels.weepee.org
fromuser=32990900xxxx
fromdomain=sswX.brussels.weepee.org
disallow=all
canreinvite=yes
allow=alaw
32990900xxxx:*password*@sswX.brussels.weepee.org/*telefoonnummer*Internet: Fastfiber
GSM: Proximus
GSM: Proximus
devastator
- Bedankt: 70 keer
Dat tel. nr in de register string was ik vergeten.
Vanavond eens proberen, alvast bedankt !
- krisken
Succes
devastator
- Bedankt: 70 keer
Moet het telefoonnr in een bepaald formaat staan ?
EDIT: heb nu :
In het klantentool van weepee zie ik wel dat FreePBX connectie heeft gelegd
EDIT: heb nu :
32990900XXXX:[email protected]/011abcdef
devastator
- Bedankt: 70 keer
En, ik zie ook dat de call 'binnenkomt'
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [dstring@macro-dial-one:12] Set("SIP/WeePee-00000000", "DSTRING=SIP/0") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [dstring@macro-dial-one:13] Return("SIP/WeePee-00000000", "") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:27] GotoIf("SIP/WeePee-00000000", "0?nodial") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:28] GotoIf("SIP/WeePee-00000000", "0?skiptrace") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:29] GosubIf("SIP/WeePee-00000000", "1?ctset,1():ctclear,1()") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [ctset@macro-dial-one:1] Set("SIP/WeePee-00000000", "DB(CALLTRACE/0)=0497<SNIP>") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [ctset@macro-dial-one:2] Return("SIP/WeePee-00000000", "") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:30] Set("SIP/WeePee-00000000", "D_OPTIONS=tr") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:31] ExecIf("SIP/WeePee-00000000", "0?SIPAddHeader(Alert-Info: )") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:32] ExecIf("SIP/WeePee-00000000", "0?SIPAddHeader()") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:33] ExecIf("SIP/WeePee-00000000", "0?Set(CHANNEL(musicclass)=)") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:34] GosubIf("SIP/WeePee-00000000", "0?qwait,1()") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:35] Set("SIP/WeePee-00000000", "__CWIGNORE=") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:36] Set("SIP/WeePee-00000000", "__KEEPCID=TRUE") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:37] GotoIf("SIP/WeePee-00000000", "0?usegoto,1") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:38] GotoIf("SIP/WeePee-00000000", "1?godial") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Goto (macro-dial-one,s,42)
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:42] Dial("SIP/WeePee-00000000", "SIP/0,,tr") in new stack
[2013-04-03 18:39:48] WARNING[2408] app_dial.c: Unable to create channel of type 'SIP' (cause 20 - Subscriber absent)
[2013-04-03 18:39:48] VERBOSE[2408] app_dial.c: == Everyone is busy/congested at this time (1:0/0/1)
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:43] ExecIf("SIP/WeePee-00000000", "0?Set(DIALSTATUS=)") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:44] GosubIf("SIP/WeePee-00000000", "0?s-CHANUNAVAIL,1()") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-dial-one:45] MacroExit("SIP/WeePee-00000000", "") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-exten-vm:15] Set("SIP/WeePee-00000000", "SV_DIALSTATUS=CHANUNAVAIL") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-exten-vm:16] GosubIf("SIP/WeePee-00000000", "0?docfu,1()") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-exten-vm:17] GosubIf("SIP/WeePee-00000000", "0?docfb,1()") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-exten-vm:18] Set("SIP/WeePee-00000000", "DIALSTATUS=CHANUNAVAIL") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-exten-vm:19] ExecIf("SIP/WeePee-00000000", "0?MacroExit()") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-exten-vm:20] GotoIf("SIP/WeePee-00000000", "1?s-CHANUNAVAIL,1") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Goto (macro-exten-vm,s-CHANUNAVAIL,1)
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s-CHANUNAVAIL@macro-exten-vm:1] GotoIf("SIP/WeePee-00000000", "0?exit,1") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s-CHANUNAVAIL@macro-exten-vm:2] PlayTones("SIP/WeePee-00000000", "congestion") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s-CHANUNAVAIL@macro-exten-vm:3] Congestion("SIP/WeePee-00000000", "10") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] app_macro.c: == Spawn extension (macro-exten-vm, s-CHANUNAVAIL, 3) exited non-zero on 'SIP/WeePee-00000000' in macro 'exten-vm'
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: == Spawn extension (from-did-direct, 0, 2) exited non-zero on 'SIP/WeePee-00000000'
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [h@from-did-direct:1] Macro("SIP/WeePee-00000000", "hangupcall,") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-hangupcall:1] GotoIf("SIP/WeePee-00000000", "1?theend") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Goto (macro-hangupcall,s,3)
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-hangupcall:3] ExecIf("SIP/WeePee-00000000", "0?Set(CDR(recordingfile)=)") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: -- Executing [s@macro-hangupcall:4] Hangup("SIP/WeePee-00000000", "") in new stack
[2013-04-03 18:39:48] VERBOSE[2408] app_macro.c: == Spawn extension (macro-hangupcall, s, 4) exited non-zero on 'SIP/WeePee-00000000' in macro 'hangupcall'
[2013-04-03 18:39:48] VERBOSE[2408] pbx.c: == Spawn extension (from-did-direct, h, 1) exited non-zero on 'SIP/WeePee-00000000'
- krisken
Ik gok dat dit 3211xxxxxx moet zijn...
devastator
- Bedankt: 70 keer
thx, werkt nu !
Zit wel een behoorlijke delay in tov mijn Gigaset C610IP die rechtstreeks naar WeePee gaat.
Duurt een seconde of 3-4 vooraleer mijn smartphone (met csipsimple) over gaat nadat de gigaset begonnen is
weepeechris
- Bedankt: 80 keer
@VoID Bedankt! Ook voor ons interessant. Misschien moeten we eens een documentje "configureer freepbx met Weepee, volgens Userbase" maken.
(en gezien de topics hier zou dat zelfs een serie kunnen worden)
- krisken
Zou ik wel zien zitten...eens over denken VoID?
VOiD
- Bedankt: 224 keer
Ja, kunnen we mischien doen maar dan niet enkel voor Weepee maar ook voor 'andere' SIP providers.
PS: Trouwens het formaat van het telnummer heeft geen belang, kan zelfs een totaal anders nummer zijn bv. 1234. Zolang dit maar overeenkomt met de DID in de incoming route.
Internet: Fastfiber
GSM: Proximus
GSM: Proximus
devastator
- Bedankt: 70 keer
Merken jullie ook een grote delay tussen het rechtstreeks 'overgaan' op de weepee trunk op een gigaset, en middels freepbx en csipsimple ?
devastator
- Bedankt: 70 keer
Wel,
Ik heb een forward account, deze forward de calls naar 2 andere weepee accounts.
1 account is rechtstreeks geconfigureerd om gigaset, de gaat naar FreePBX.
Ik connect momenteel met FreeBPX middels CSipSimple op mijn Galaxy S2.
Wanneer ik met mijn vrouw haar GSM naar onze vaste lijn bel, dan gaat de gigaset vrijwel direct over.
Het duurt een seconde of 3-4 vooraleer mn S2 overgaat.
[EDIT]Om de een of andere reden opgelost
devastator
- Bedankt: 70 keer
Bij uitgaande calls krijg ik wel dit:
[2013-04-03 21:38:33] NOTICE[1528] chan_sip.c: Call from '0' (192.168.0.16:40100) to extension '+32497<SNIP>' rejected because extension not found in context 'from-internal'.
- krisken
Hmz hij denkt dat je probeert te bellen naar een extensie. Staan je outbound routes goed?
devastator
- Bedankt: 70 keer
Denk dat ik idd in de knoop lig met mn routes :-/
ik heb bv:
voor oproepen naar GSM.
Dat lijkt dus niet te werken
ik heb bv:
047.
VOiD
- Bedankt: 224 keer
Probeer eens met 00324[01456789]XXXXXXX als pattern om te kijken of het beter gaat.
Hoeveel routes heb je ? Volgorde is ook van belang indien je er meerdere hebt.
Internet: Fastfiber
GSM: Proximus
GSM: Proximus
- krisken
Mocht het je helpen, ik heb 4 outbound rules : free, cell, landline en international.
Van de eerste 3 heb je hier mijn screenshots...
- krisken
Blijkbaar maximaal 2 bijlages...en waarom hij de ene volledig toont en de andere niet is mij ook een raadsel. Soit, hier is nummer 3
devastator
- Bedankt: 70 keer
Thanks, vanavond even proberen
devastator
- Bedankt: 70 keer
Ga straks eerst eens proberen bij pbxes.com, lijkt me momenteel ook genoeg functionaliteit te bieden.
Gr
Gr
- krisken
pbxes is goed om te testen maar niet als functionele omgeving. Veel latency op die lijnen en service die plots uitvalt...tis gratis voor iets hé
