Home-server raakt niet meer op internet
meon
Twitter: meon
Bedankt: 780 keer
M'n homeserver (Win 2k3) raakt niet meer op internet. Ik krijg m'n modem niet eens gepinged (= router, gateway). Andere pc's in het netwerk lukt wél.
Wat is er mis? :(
Modem = 192.168.1.1, DHCP 192.168.1.20-200
Server = Handmatig ingesteld op 192.168.1.11
Y:\>ping -n 1 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data:
Request timed out.
Ping statistics for 192.168.1.1:
    Packets: Sent = 1, Received = 0, Lost = 1 (100% loss),
Y:\>ping -n 1 192.168.1.10
Pinging 192.168.1.10 with 32 bytes of data:
Reply from 192.168.1.10: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.1.10:
    Packets: Sent = 1, Received = 1, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
Y:\>ping -n 1 192.168.1.21
Pinging 192.168.1.21 with 32 bytes of data:
Reply from 192.168.1.21: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.1.21:
Y:\>route print
IPv4 Route Table
Interface List
0x1 ........................... MS TCP Loopback interface
0x2 ...00 ff 75 13 a8 3b ...... TeamViewer VPN Adapter
0x10004 ...00 11 0a 97 f3 f6 ...... Broadcom NetXtreme Gigabit Ethernet for hp
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0      192.168.1.1     192.168.1.11     10
        127.0.0.0        255.0.0.0        127.0.0.1        127.0.0.1      1
      169.254.0.0      255.255.0.0   169.254.47.220   169.254.47.220     30
   169.254.47.220  255.255.255.255        127.0.0.1        127.0.0.1     30
  169.254.255.255  255.255.255.255   169.254.47.220   169.254.47.220     30
      192.168.1.0    255.255.255.0     192.168.1.11     192.168.1.11     10
     192.168.1.11  255.255.255.255        127.0.0.1        127.0.0.1     10
    192.168.1.255  255.255.255.255     192.168.1.11     192.168.1.11     10
        224.0.0.0        240.0.0.0   169.254.47.220   169.254.47.220     30
        224.0.0.0        240.0.0.0     192.168.1.11     192.168.1.11     10
  255.255.255.255  255.255.255.255   169.254.47.220   169.254.47.220      1
  255.255.255.255  255.255.255.255     192.168.1.11     192.168.1.11      1
Default Gateway:       192.168.1.1
Persistent Routes:
  None
Heeft die Teamviewer VPN iets om zeep geholpen?
D3bian
Bedankt: 26 keer
Zou kunnen, schakel de interface van de teamviewer VPN eens uit en kijk of je dan online geraakt.
meon
Twitter: meon
Bedankt: 780 keer
Nu krijg ik
Y:\>route print
IPv4 Route Table
Interface List
Active Routes:
Persistent Routes:
  None
De dingen met metric 30 zijn dus weg, maar nog steeds kan ik 192.168.1.1 niet pingen :(
Bedankt: 247 keer
netsh int ip reset
proberen ?
http://support.microsoft.com/kb/299357
Geen op hol geslagen firewall, antivirus, ... ?
Krijgt de pc nog een adres via dhcp ?
Andere netwerkkabel al geprobeerd of is er wel nog lan toegang ?
meon
Twitter: meon
Bedankt: 780 keer
Serverke heeft vast IP, dus geen dhcp.
Ja, LAN-access is er nog (en is zelfs enige manier om er mee te werken, hangt enkel stroom en netwerkkabel aan).
fryelectro
Bedankt: 177 keer
Heb je layer 2 al eens gechecked?
klopt het mac adres voor je modem ip (def gw) op de NAS?
en omgekeerd het mac adres voor je NAS op de modem?
Misschien eens handmatig clearen?
Orange Go Extreme
elkristo
zijn gateway en subnetmask correct ingevuld ? + server eens herstarten.
Bedankt: 247 keer
Wat zie je als mac adres in je arp tabel voor je gateway ?
meon
Twitter: meon
Bedankt: 780 keer
Ethernet adapter Local Area Connection:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Broadcom NetXtreme Gigabit Ethernet for hp
   Physical Address. . . . . . . . . : 00-11-0A-97-F3-F6
   DHCP Enabled. . . . . . . . . . . : No
   IP Address. . . . . . . . . . . . : 192.168.1.11
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . : 192.168.1.1
   DNS Servers . . . . . . . . . . . : 192.168.1.11
Mac-adres in ARP-tabel lijkt te kloppen
en dit:
Ik heb Teamviewer al eens verwijderd en gereboot, helpt niks :(. Enkel LAN-access, excl. gateway/modem :(
Dima_2005
Bedankt: 264 keer
Waarom staat DNS server op de IP van de server zelf? Klopt dit?
Probeer deze eens toch te wijzigen naar 192.168.1.1. Of zelfs 8.8.8.8
Tim.Bracquez
Bedankt: 450 keer
@Dima_2005: Dan zou hij zijn gateway nog moeten kunnen pingen
Ik zou volgende testen:
- dhcp adres, krijg je er één
- netwerk driver verwijderen en opnieuw installeren vanaf de standaard driver cd. (windows update kan soms lastig zijn met driver updates)
- bios controleren dat deze niet uit staat
- wireshark even erbij nemen
- controleren of het mac adres stiekem niet 00-00.. geworden is ofzo.
Dima_2005
Bedankt: 264 keer
Tim, dat klopt, ik vind het ook raar...
Maar er zijn een paar rare bugs in Windows servers, waardoor 1 instelling alles verpest.
Nog een andere test:
Heb je toevallig geen andere gateway? (en heb je je gateway eigenlijk al gereset, :roll: )
Tim.Bracquez schreef:Ik zou volgende testen:
Met uitzondering van de laatste twee lijkt me dat weinig nuttig aangezien hij perfect vanop z'n LAN aan z'n homeserver kan.
Tim.Bracquez
Bedankt: 450 keer
Mijn excuses r2504, had dit niet goed gelezen.
Zoizo zou ik het toch testen:
Tim.Bracquez schreef: - dhcp adres, krijg je er één
Heb je gelijk een ander adres dat volledig goed geconfigureerd zou moeten zijn, mogelijk zelf je router dat raar doet en je 1.11 niet meer routeerd naar buiten toe.
Tim.Bracquez schreef: - netwerk driver verwijderen en opnieuw installeren vanaf de standaard driver cd. (windows update kan soms lastig zijn met driver updates)
Kan nooit geen kwaad bij rare netwerk problemen, maakt ook volledig nieuwe registery items aan
Tim.Bracquez schreef:Heb je gelijk een ander adres dat volledig goed geconfigureerd zou moeten zijn, mogelijk zelf je router dat raar doet en je 1.11 niet meer routeerd naar buiten toe.
Ik zou eerst met wireshark gaan kijken of de homeserver z'n gateway wel aanspreekt.
Tim.Bracquez schreef:Kan nooit geen kwaad bij rare netwerk problemen, maakt ook volledig nieuwe registery items aan
Iemand anders stelde al voor een "netsh int ip reset" te doen... geen idee of Meon dit al gedaan heeft.
Ofloo
Bedankt: 92 keer
hoe groot is de range van het subnet van de router ? zijn er geen 2 clients met hetzelfde ip ?
meon
Twitter: meon
Bedankt: 780 keer
DHCP is van 192.168.1.20 - 192.168.1.200
Y:\>netsh int ip reset c:\resetlog.txt
Y:\>arp -a
Interface: 192.168.1.11 --- 0x10003
  Internet Address      Physical Address      Type
  192.168.1.1           00-12-bf-33-75-46     dynamic
  192.168.1.10          00-1f-33-ea-cf-55     dynamic
  192.168.1.20          40-61-86-2b-7a-dd     dynamic
  192.168.1.21          68-b5-99-f5-67-52     dynamic
Request timed out.
Y:\>ping -n 1 192.168.1.11
Pinging 192.168.1.11 with 32 bytes of data:
Reply from 192.168.1.11: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.1.11:
192.168.1.1 = Philips modem/router/accesspoint (ADSL2+)
192.168.1.10 = ReadyNAS
192.168.1.11 = W2K3 Domeincontroller (=probleem-pc)
192.168.1.20 = desktop 1
192.168.1.21 = laptop 1
Wat zou ik met wireshark moeten zien? Ik kan dat opzetten, maar om dan nog te interpreteren waar ik naar kijk is wat anders :-)
Mac-adressen kloppen voor zover ik kan zien.
En nog even opnieuw benadrukken: al deze dingen doe ik over een RDP-connectie over het lan, er hang geek KVM aan de pc zélf :) (dus LAN-connectiviteit lijkt in zijn geheel te werken, behalve richting gateway).
Ik heb het idee dat ik het eerder op de modem ga moeten zoeken (ja; al meermaals gereboot). Wilde firewall-rule?
Ofloo
Bedankt: 92 keer
ik heb ook het vermoeden dat het op je router/modem zit, dat daar een route niet juist is ingesteld of iets dergelijks.
als het probleem zich op jouw router/modem situeert zou je kunnen stellen aangezien je een 255.255.255.0 broadcast gebruikt dat je clients onderling kunnen pingen test dat eens en ping daarna eens de router of van de router de server, ..
meon
Twitter: meon
Bedankt: 780 keer
Euh, ik heb geen CCNA eh :D
Maar vanaf elke andere pc kan ik alles pingen.
Ik heb wireshark eens laten lopen en ik zie daar niks verschijnen als ik bvb 192.168.1.1 ping. Ik zie ook geen enkel extern IP verschijnen.
De homeserver draait ook DNS-server, vandaar dat die als primaire DNS ingesteld staat. (En da's momenteel best vervelend, aangezien hij non-authorative requests nu niet geforward krijgt :-))
Heronic
Bedankt: 208 keer
Ik heb ooit iets gelijkaardig gehad. (Staat hier ook ergens een topic over, rare fenomenen waarbij ik bv geen dns kon pingen maar wel de ip's enzo).
Als ik mij niet vergis lag het toen aan de kabel.
Al eens een andere kabel geprobeerd?
fryelectro
Bedankt: 177 keer
Lijkt me vreemd hoor, TS zegt dat hij kan connecteren naar zaken in de LAN maar niet naar andere netwerken die via de default gateway bereikbaar zijn? Maw layer 1 en 2 zijn in principe in orde.
Orange Go Extreme
meon schreef:Ik heb wireshark eens laten lopen en ik zie daar niks verschijnen als ik bvb 192.168.1.1 ping. Ik zie ook geen enkel extern IP verschijnen.
Waar laat je die wireshark lopen... want als je dat op je eigen PC doet ga je natuurlijk niets zien (je hebt een switch hé). Om zoiets te zien gaan je port mirroring moeten kunnen doen, of anders de wireshark op de Home Server draaien... maar iets draaien op een systeem dat raar doet is natuurlijk slechte bewijslast.
Heb je die reset van je IP stack al eens gedaan... meestal is dat een wondermiddel bij dergelijke rariteiten.
fryelectro
Bedankt: 177 keer
Ik volg r2504 volledig. Zet die wireshark gewoon even op die server. Kijk in je capture of hij effectief de gateway gebruikt. Indien ja, probleem op router, indien nee, probleem op server.
BTW: indien router probleem, kan je niets terugvinden in je logs op je router? Zet eens alle security uit om te kijken of die geblocked wordt door één of andere security feature?
Wat je ook kan proberen is om het mac adres van je server te wijzigen (spoofen) en kijken of het dan wel lukt om naar je gateway of daarbuiten te pingen.
Orange Go Extreme
Ofloo
Bedankt: 92 keer
meon schreef:Euh, ik heb geen CCNA eh :D
maar kan je
192.168.1.1 pingen? een client vanaf de server ? kunnen uw klients de server pingen, .. ik neem aan van niet anders konden ze ook wel dns requests doen, .. wat vreemd zou zijn want normaal zou je zeggen dat wanneer er een probleem is met route dat de server de clients wel zouden moeten kunnen pingen, ..
is uw netwerk card wel geactiveerd ik weet niet hoe je dat in windows doet maar ifconfig eth0 up, iets dergelijks bestaat ook in windows als ik me niet vergis. Is er wel ether verkeer, .. hoe connecteer je met je home server via kvm dit gebruikt een eigen lijn? Herstart de interface eens, ..
Ofloo ik denk dat je de thread eens goed moet lezen... alles wat je vraagt is reeds duidelijk beantwoord.
Ofloo
Bedankt: 92 keer
juist, ..
meon
Twitter: meon
Bedankt: 780 keer
Ik had wireshark/winpcap op de server gezet; ik zie alles voorbijkomen vanaf alle IP's.. maar "IP == 192.168.1.1" blijft leeg.
Ik heb de netwerkkabel eens in de modem gestoken ipv m'n dom Netgear-Gbit-switchke...
En surprise, 192.168.1.1 is bereikbaar.
Terug naar switch, op andere poort: ook alles werkt.
Ik kan me moeilijk voorstellen dat een switch van 45 euro slim genoeg is om onderscheid te maken in het soort trafiek, en de poort an sich lijk me ook niet defect...
Switch zonder stroom zetten hielp niet overigens.
How weird.
Bedankt: 247 keer
Dat is toch geen managed gbit switch ?
Dima_2005
Bedankt: 264 keer
Netgear heeft wel semi-managed switches. Dusja, best mogelijk dat die een VLAN ingesteld had op een poort. (onbewust ingesteld?)
Dacht dat de ProSafe serie hiertoe in staat was.
fryelectro
Bedankt: 177 keer
toch zeker dat het ip van dat switchke niet 192.168.1.1 was?
Orange Go Extreme
meon
Twitter: meon
Bedankt: 780 keer
Dit is toch echt geen managed switch eh :) http://www.netgear.com/home/products/sw ... GS608.aspx
fryelectro
Bedankt: 177 keer
affirmatief:) Ik heb echter ook 2 netgear switchkes en daar kan je effectief dingen op configureren, ook type GSxxx.
Orange Go Extreme
Dima_2005
Bedankt: 264 keer
Nee, deze kun je denk ik niet configureren.
De GS10xE (ProSafe serie), kun je wel configureren.
rtl
Bedankt: 39 keer
uw mac-address table op de switch had wsl een verkeerde entry voor uw server opgeslagen
de table clearen op de switch (of switch rebooten :)) had wsl ook gewerkt
die moet daarvoor niet managed zijn
grts
meon schreef:Switch zonder stroom zetten hielp niet overigens.
Da's wel bizar... is er één of andere reset mogelijkheid aan dat ding (anders gewoon eens enkele uren laten afstaan) ?
meon
Twitter: meon
Bedankt: 780 keer
Mja, kabeltje versteken heeft blijkbaar ook geholpen.
Ik had powercycle wel voldoende geacht (heb echt het pinnetje van de adaptor uitgetrokken wegens geen schakelaar).
rtl
Bedankt: 39 keer
weird stuff
brol van denaldi!
meon
Twitter: meon
Bedankt: 780 keer
Tja, performance-gewijs was ik meer content van m'n ter ziele gegane D-Link gbit-switch. Maar Netgear-spullen zijn toch niet zo slecht normaal? (is eerste ghost in the machine da'k merk hoor).
//edit: en lap, 't is weer zo ver en omsteken naar rechtstreeks op de modem helpt niet. Ik denk dat de switch niet de schuldige is, maar wel Bittorrent... Al snap ik niet hoe dat dat, zelfs na reboots en powercycles nog problemen kan geven :-/
Ahhhh... P2P.... tja, teveel connecties voor de modem... maar je zou inderdaad verwachten dat dit opgelost is na een powercycle.
Dima_2005
Bedankt: 264 keer
Mogelijk is de modem de schuldige en niet de switch?
