Is het niet mogelijk om een overzicht te maken van alle mogelijke Telnet en Telnet shell commando's in verband met de BBOX2 ?
mvg,
Telnet (Shell) commando's voor de BBOX2
- TiTanium
- Bedankt: 472 keer
Zoiets als dit?
En Help All
login: admin
Password: ********
[admin @ home]$ help
Error: help should be called with 1 argument
help Commands Help
Usage:
help <"all" | category | command>
where:
help all - show all available commands
help <category> - show commands in a certain category
help <command> - show detailed help for a specific command
Availble help Categories
help terminal - show help about Commands to contorol OpenRG execution
help dns_route - show help about Dyncamic Routing according to DNS replies
help igmp - show help about IGMP Proxy related commands
help pvc - show help about PVC scan related commands
help rg_conf - show help about Read and write OpenRG configuration data
help ffs - show help about Flash file system
help mii - show help about MII Low level control
help FT commands - show help about FT commands
help FT atm commands - show help about FT atm commands
help FT sndcp commands - show help about FT sndcp commands
help rmt_mng - show help about Remote Management Commands
help firewall - show help about Control and display Firewall and NAT data
help resetstat - show help about RESET stats
help guistat - show help about GUI stats
help adslstat - show help about ADSL stats
help mirror - show help about mirror
help cmd - show help about Commands related to the Command module
help tasks - show help about API for OpenRG tasks
help debug - show help about Debug OpenRG
help log - show help about Contorols OpenRG logging behaviour
help main_task - show help about main_task commands
help flash - show help about Flash and loader related commandsCode: Selecteer alles
[admin @ home]$ help all
Command Category terminal - Commands to contorol OpenRG execution
exit Exit sub menu
ls List sub menue contents
die Exit from OpenRG and return ret
ps Print OpenRG's tasks
entity_close Close an entity
Command Category dns_route - Dyncamic Routing according to DNS replies
dyn_route_print Print Dynamic Routes
dyn_route_del Delete Dynamic Routes
Command Category igmp - IGMP Proxy related commands
igmp_status Print IGMP subscription of device
igmp_reset Clear all IGMP subscriptions
Command Category pvc - PVC scan related commands
pvc_scan Scan predefined vpi.vci to determine PPP protocol
pvc_scan_restart Restart PVC scan
pvc_scan_status Display PVC scan status
Command Category rg_conf - Read and write OpenRG configuration data
rg_conf_print Print OpenRG configuration
rg_conf_set Set OpenRG configuration path to value
rg_conf_set_obscure Set OpenRG configuration path to an obscured value
rg_conf_del Delete subtree from OpenRG configuration
rg_conf_ram_set Set OpenRG dynamic configuration
rg_conf_ram_print Print OpenRG dynamic configuration
rg_conf_ram_del Delete subtree from OpenRG dynamic configuration
reconf Reconfigure the system according to the current OpenRG
configuration
Command Category ffs - Flash file system
ffs_mount Mount FFS device
ffs_umount Unmount FFS device
ffs_format Format FFS device
Command Category mii - MII Low level control
mii_dev_link_status_get Get Link Status for all device ports using MII
mii_phy_reg_get Get PHY MII register value
mii_phy_reg_set Set PHY MII register value
mii_eth_reg_get Get Ethernet MII register value
mii_eth_reg_set Set Ethernet MII register value
Command Category FT commands - FT commands
save Save configurating to flash
flash_chksum Display all flash sections checksums
Command Category FT atm commands - FT atm commands
atm atm
Command Category FT sndcp commands - FT sndcp commands
sndcp sndcp
Command Category rmt_mng - Remote Management Commands
rmt_mng_enable
rmt_mng_login
rmt_mng_add_user
Command Category firewall - Control and display Firewall and NAT data
fw_restart Stop and start Firewall & NAT
fw_start Start Firewall & NAT
fw_stop Stop Firewall & NAT
fw_filter Turn Firewall packet inspection on/off
mac_cache_dump Dump MAC cache data
fw_dump Dispaly Firewall data
fw_variable Display variables of the firewall rules
fw_trace Trace packet traversal via the Firewall ruleset
Command Category resetstat - RESET stats
resetstat RESET stats.
Command Category guistat - GUI stats
guistat GUI stats.
Command Category adslstat - ADSL stats
adslstat ADSL stats.
Command Category mirror - mirror
mirror_add_dev mirror_add_dev
mirror_start mirror_start
mirror_stop mirror_stop
mirror_deconf mirror_deconf
mirror_show mirror_show
mirror_trace_on mirror_trace_on
mirror_trace_off mirror_trace_off
mirror_set_out_dev mirror_set_out_dev
mirror_set_out_addr mirror_set_out_addr
Command Category cmd - Commands related to the Command module
help Commands Help
Command Category tasks - API for OpenRG tasks
host Resolve host by name
bridge_info Print bridge information
vlan_add Add VLAN interface
Command Category debug - Debug OpenRG
sys_ioctl issue openrg ioctl
etask_list_dump Dump back trace of all etasks
meminfo Print memory information
wbm_debug_set Stop and start WBM debug mode
Command Category log - Contorols OpenRG logging behaviour
cat_log Prints or deletes contents of log to console
log_lev_on Redirect rg_error output equal to or higher than level to the
current console.
log_lev_off Stop rg_error redirection to the current console
exit Exit sub menu
Command Category main_task - main_task commands
reboot Reboot the system
rg_ifconfig List OpenRG Network Devices
restore_default Restore default configuration
exec Execute program
print_main_wan Print the name of the current main wan device
cat Print file contents to console
shell Spawn busybox shell in foreground
cgi_session_check Check if session id is valid or not
cgi_set_randomize For a session_id given, it set a random number for web pages
cgi_check_random For a session_id given, it checks the random number in
order to access web pages
route Print route table
ver Display version information
date Print the current UTC and local time
Command Category flash - Flash and loader related commands
flash_commit Save OpenRG configuration to flash
flash_erase Erase a given section in the flash
load Load and burn image
boot Boot the system
flash_layout Print the flash layout and content
flash_dump Dump the flash content
lock Lock mtd region
unlock Unlock mtd region
bset Configure bootloader
ifconfig Configure network interface
ping Test network connectivity
Returned 0
