Message
A potentially dangerous Request.QueryString value was detected from the client ((b="...bs(b),0);b<c;b++)if(b in d").
Source
System.Web
Target site
Void ValidateString(System.String, System.String, System.String)
Stack trace
at System.Web.HttpRequest.ValidateString(String s, String valueName, String collectionName)
at System.Web.HttpRequest.ValidateNameValueCollection(NameValueCollection nvc, String collectionName)
at System.Web.HttpRequest.get_QueryString()
at System.Web.UI.Page.GetCollectionBasedOnMethod(Boolean dontReturnNull)
at System.Web.UI.Page.DeterminePostBackMode()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest()
at System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context)
at System.Web.UI.Page.ProcessRequest(HttpContext context)
at ASP.index_aspx.ProcessRequest(HttpContext context)
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
GET /index.aspx app=MPSS&indexof=function(a){if(this===void%200||this===null)throw%20new%20TypeError;var%20d=Object(this),c=d.length>>>0;if(c===0)return-1;var%20b=0;arguments.length>0&&(b=Number(arguments[1]),b!==b?b=0:b!==0&&b!==1/0&&b!==-(1/0)&&(b=(b>0||-1)*Math.floor(Math.abs(b))));if(b>=c)return-1;for(b=b>=0?b:Math.max(c-Math.abs(b),0);b<c;b%2B%2B)if(b%20in%20d&&d[b]===a)return%20b;return-1}&dat=09/06/2011 80 - 84.193.37.101 HTTP/1.1 Mozilla/4.0+(compatible;+MSIE+8.0;+Windows+NT+5.1;+Trident/4.0;+GTB6.6;+Mozilla/4.0+(compatible;+MSIE+7.0;+MyBee+Browser);+.NET+CLR+2.0.50727;+OfficeLiveConnector.1.3;+OfficeLivePatch.0.0;+InfoPath.1;+.NET+CLR+3.0.4506.2152;+.NET+CLR+3.5.30729) Iemand enig idee wat dit zou kunnen zijn? In onze source code komt in elk geval niets van deze javascript code voor....
