Hoe kom je in het dyndns menu terecht bij de bbox2 (en 1) ?
silencer
Uitgedeelde bedankjes: 175 keer
Bedankt: 103 keer
Kun je er nog aan met de huidige firmware versies ? (verborgen menu)
Ken
Bedankt: 113 keer
    javascript:mimic_button('navigator: XXXX..')
    - 40: About OpenRG
    - 50: Network Map
    - 60: Network List View
    - 70: Configuration file
    - 80: Host Information
    - 100: Users
    - 101: User Settings
    - 110: Date and Time
    - 111: Clock set
    - 120: System Settings
    - 140: Restart
    - 150: Restore Defaults
    - 730: Advanced
    - 750: System
    - 752: Connections
    - 753: Traffic
    - 800: -
    - 810: Routing
    - 811: Route Settings
    - 840: Logout
    - 860: Status
    - 900: Universal Plug and Play
    - 1210: MAC Cloning
    - 1220: Diagnostics
    - 1400: Quick Setup
    - 1410: Scheduler Rules
    - 1411: Edit Scheduler Rule
    - 1412: Edit Time Segment
    - 1413: Edit Hour Range
    - 1430: Network Objects
    - 1431: Edit Network Object
    - 1432: Edit Item
    - 1450: IPv6
    - 1460: Subscriber Information
    - 9000: General
    - 9001: Access Control
    - 9002: Add Access Control Rule
    - 9003: Edit Access Control Rule
    - 9004: Website Restrictions
    - 9005: -
    - 9006: Security Log
    - 9007: Security Log Settings
    - 9008: Remote Administration
    - 9009: Remote Administration
    - 9010: Port Forwarding
    - 9011: Port Forwarding
    - 9012: Add Port Forwarding Rule
    - 9013: Edit Port Forwarding Rule
    - 9014: DMZ Host
    - 9015: DMZ Host
    - 9016: Port Triggering
    - 9017: Edit Port Triggering Rule
    - 9018: Edit Port Triggering Rule
    - 9019: Advanced Filtering
    - 9020: Add Advanced Filter
    - 9021: Edit Advanced Filter
    - 9022: MAC Filtering
    - 9023: MAC Filtering Settings
    - 9024: Protocols
    - 9025: Edit Server Ports
    - 9026: Edit Service Opened Ports
    - 9027: DNS Server
    - 9028: DNS Entry
    - 9029: DNS ENtry
    - 9030: IP Address Distribution
    - 9031: DHCP Settings
    - 9032: DHCP Connections
    - 9033: DHCP Connection Settings
    - 9034: DHCP Relay Server Address
    - 9035: Dynamic DNS
    - 9036: Time Server Settings
    - 9037: Welcome
    - 9038: Quick Start
    - 9039: User access rights
    - 9040: Change Password
    - 9041: Home network
    - 9042: LAN servers
    - 9043: LAN Server Configuration
    - 9044: Wireless
    - 9045: WEP configuration
    - 9046: WPA configuration
    - 9047: MAC Filter List Editing
    - 9048: WEP configuration
    - 9049: WPA configuration
    - 9050: MAC Filter List Editing
    - 9051: Maintenance
    - 9052: Internet access
    - 9053: Phone by ADSL Service
    - 9054: ADSL connection
    - 9055: Status
    - 9056: Wireless network 802.11g information
    - 9057: LAN information
    - 9058: Software Information
    - 9059: USB Information
    - 9060: Connection Status
    - 9061: Phone Number Selection
    - 9062: Phone Number Selection
    - 9063: Versions of Software Componants (sic)
    - 9064: Phone Number Selection
    - 9065: DHCP relay configuration
    - 9066: DNS & default gateway configuration
    - 9067: Remote help desk
    - 9068: Ping (ICMP Echo)
    - 9069: PVC Scan
    - 9070: OAM Ping
    - 9071: Interfaces
    - 9072: Traffic
    - 9073: ADSL statistics
    - 9074: DHCP statistics
    - 9075: Calls statistics
    - 9076: Memory Sharing
    - 9077: Backup & Update
    - 9078: Backup & Update - Update Firmware
    - 9079: Restore configuration from your PC
    - 9080: Save configuration to your PC
    - 9081: xDSL Mode
    - 9082: VDSL statistics
    - 9083: Telephone
    - 9084: Evaluation License Agreement
    - 9085: Welcome to F@st3464
    - 9086: Login Setup
ubremoved_15739
Bedankt: 532 keer
1450: IPv6 ??
In de "Runtime Code Version" 60R109-60A022 zit dit niet in.
Is dit enkel in de 60A040?
Edit:
er zijn precies wel meer verschillen met mijn "runtime code version" 60R109-60A022.
Voor dewelke is bovenstaande lijst bedoelt?
Trojan
Bedankt: 243 keer
Het grootste deel werkt mijn weten niet meer op de laatste firmware versies.
Dit is nog van voor 60A022.
edit: ik ben zo eens wat aan het testen en veel van die nummer komen niet meer overeen. De nummer van dyndns verwijst nu naar "DHCP groups edit".
Voor dyndns moet je 9037 gebruiken.
silencer
Bedankt: 103 keer
Is de dyndns updater van de bbox2 betrouwbaar genoeg ?
Electribe
Ik heb die lange tijd gebruikt en nooit problemen mee gehad. Nu gebruik ik mijn eigen router omdat die wifi N heeft (voor gebruik met laptop/tablet/smartphone).
silencer
Bedankt: 103 keer
Thuis heb ik ook een eigen router (Pfsense, een alix embedded boardje).
Bedankt !
silencer
Bedankt: 103 keer
Electribe
Ik denk dat dit niet meer mogelijk is. Toen ik mijn Bbox2 net had (een goed jaar geleden) was het nog mogelijk om in dat menu te geraken, maar na een firmware update lukte het niet meer.
