Ik heb gezien dat er een nieuwe firmware is voor de Fritz!Box 7270 internationale versie:
New with version 54.04.90:
- WLAN: Setting up a WLAN guest access
- WLAN: Night service can now be set per day of the week
- WLAN: Improved auto channel function. Advanced identification and indication of potential sources of interference in the WLAN Monitor (spectrum analysis)
- WLAN: Improved interoperability with certain INTEL-Chipsets
- Internet: full, unrestriced IPv6 support
- Internet: DNS proxy of the FRITZ!Box is compatible with DNSSEC
- Internet: Improved termination of surfing time in the parental control
- Internet: Simplified configuration of Internet access data
- System: New Welcome/Home page.
- System: Display of the FRITZ!Box in Windows 7 in: "Devices and Printers" via PnP-X
- System: Improved Network Overview with online status and links to network shares in MSIE
- System: DHCP server extends the support of subnets smaller / 24
- System: assigning MAC addresses to fixed IP addresses
- System: LAN green mode
- System: manually configure time-server
- System: Extended TR-064 interface for the support of FRITZ!App
- Telephony: HD voice transmission among ISDN fixed-line parties
- Telephony: simplified configuration of phone numbers and telephony devices
- Telephony: Extended Provider List
- Telephony: Set call routing for up to 20 Internet phone numbers
- Telephony: Information on the quality of faxes via VoIP (Enhanced T.38 details in X-RTP)
- Telephony: Advanced Interoperability Fax (T.38)
- Telephony: Support for FRITZ!App Fon for Android and iPhone
- NAS / Storage: Internet share of a dedicated public area
- USB: Updated USB pages
- USB: support for secure FTP (SSL)
- USB: GZIP compression in WebDAV compatible with remote resources for a more rational use of bandwidth
- USB: FRITZ!Box audio and USB remote connection: print on demand
- Media Server: files larger than 2 GB are supported
- Media Server: improved interoperability with various media clients / formats
- DECT: MT-D/MT-F: display of images on the MT-F
- DECT: MT-D/MT-F: read and write Mails via the handset
- DECT: MT-D/MT-F: optimizations and improvements in the operation
- DECT: DECT: DECT Eco Mode (no emission) (FRITZ! Fon MT-D/MT-F, some new CAT-iq-enabled phones)
- DSL: improved compatibility with different DSL lines
Fritz!Box 7270 internati. versie: nieuwe firmware 54.04.90
- Bedankt: 3912 keer
- Recent bedankt: 15 keer
@ jochla: deze versie is alleen voor de 7270 v2 !
Voor de 7270 v3 is er de laatste internationale FW: 74.04.90
Een overzicht:
54.04.76 is de laatste versie voor de FB 7270 v1 (serienummer voor xxxx.304.00.000.001)
54.04.81-17599 is een "betaversie" (Labor Firmware) voor de FB 7270 v1 (met IPv6)
54.04.90 is de laatste versie voor de FB 7270 v2 (serienummer na xxxx.304.00.000.001)
74.04.90 is de laatste versie voor de FB 7270 v3
Een overzicht:
johcla
- Uitgedeelde bedankjes: 690 keer
- Bedankt: 158 keer
Philippe,
bedankt voor de info. Ik wist zelfs niet dat er verschillende versies zijn met eigen firmwares.
Ik zag dat er een nieuwe firmware was door eens in te loggen op de fritzbox, en heb op die manier ook de nieuwe versie gedownload, dus ben zeker dat het de juiste is voor mijn FB.
Alles lijkt goed te werken, ik zit nu enkel met het luxe-probleem of ik nu de FB of de BBox2 ga gebruiken voor mijn guest WLAN.
Je hebt nu inderdaad 3 WLAN's
Het voordeel van de FritzBox "guest acess" is t.o.v. BBox2
- je hebt geen aparte PPPoE sessie meer nodig op de bbox2 ...
- je kan de FritzBox guest access gemakkelijk aan/uitschakelen (via de Fritz DECT telefoon) ...
- je kan de FritzBox guest access een bepaalde tijd instellen (vb 30 minuten) ...
- de guest access kan automatisch uitgeschakeld worden als je laatste "gast" vertrokken is ...
De Guest WLAN heeft een volledig aparte LAN (192.168.179.xx), de gasten kunnen niet op je eigen privaat netwerk.
Ze hebben wel dezelfde externe IP (de PPPoE sessie wordt gedeeld).
Eén voordeel van de Bbox WLAN is t.o.v. FritzBox guest access is dat je minder snelheid zal verliezen op de FritzBox terwijl een gast bandbreedte gebruikt op de BBox2 (iedere PPoE sessie krijgt de volle snelheid, je kan dus de totale bandbreedte van de BBox sync gebruiken, vb 30/6)
johcla
- Bedankt: 158 keer
De upgrade is toch niet zo vlekkeloos verlopen.
Surfen en het netwerk benaderen was enorm traag. Oorzaak was zeker de fritzbox omdat surfen via BBox2 wel normaal was.
Een paar keer de FB gereboot, maar dat hielp niet. Uiteindelijk de FB een paar minuten zonder stroom gezet, en sindsdien lijkt het opgelost.
Wat de guest WLAN betreft, hou ik het voorlopig op de BBox. Via de FB heeft inderdaad de voordelen die Philippe opsomde, maar via BBox2 kan ik het gebruiken als de FB eens tegenwerkt, zoals gisteren. Belangrijkste reden is gewoon praktisch: ik heb ook een BBox2-FB7170 combinatie en ik probeer beide configuraties zo identiek mogelijk te houden. Het is nu soms al te ingewikkeld voor mezelf
