Hello,
First of all sorry for writing in English but my Flemish isn’t sophisticated to write a post on this from but I can read it so please feel free to answer in Flemish.
I have the following problem. I can’t convince my FritzBox 7390 (International) to work with my Scarlet VDSL2. I read a lot of post on this forum and tried almost every setting in my FritzBox – without success ;-(
Could someone tell if it is in general possible? And if it is possible - how to configure my box.
Dank u!
[Mod Edit] crosspost (= same post in 2 or more different topics) is not allowed. double posting deleted
Scarlet met Fritz!Box 7390 International
@squib
I assume you have a PSTN (aka analog) line, like most people in Belgium. One thing to check is that is that the “interference resistance” (under Internet/DSL information) is set to annex B. I overlooked this at the beginning, and the modem would not initiate the PPoE session. Once set to annex B, it went through. The installation wizard also asks this question. I guess most people would answer "annex A" for a PSTN line. That would seem logical. However, Belgacom uses the Annex B frequency range for its VDSL2.
Remember also that, unlike the BBox/Sagem, the Fritz is not configured through TR-069. There is no automotic configuration for your user credentials (username and password). You have to specifically mention them under Internet/Account Information/Connection settings.
- MClaeys
- Bedankt: 347 keer
I consider that one as the correct one. I looked a little closer at it and I will explain it in some steps.
You connected all wires correct? Yes?
If yes, you go to the box (when you are connected to it, you surf to http://fritz.box)
I think you are already able to do this since you already tried some things.
Select "Internet/Account Information"
There you need to put your login settings from Scarlet.
NOT JUST YOUR SCARLET USERNAME (this was the fault I made when I was setting up my old router).
If your username is ab123456 for instance, than the username for your internet connection is ab123456@SCARLET (in capitals)
then your password (this is the same password as your usual Scarlet password).
It's possible that you need other settings too, but I can't see what settings are possible because they aren't in the manual. If you make a screenshot of this page I can maybe explain further or see an error.
- Bedankt: 3755 keer
- Recent bedankt: 9 keer
* Maybe a stupid question: are you sure you have VDSL2 ? In case you are still on ADSL, you need to set the FritzBox to Annex A.squib schreef:I have the following problem. I can’t convince my FritzBox 7390 (International) to work with my Scarlet VDSL2. I read a lot of post on this forum and tried almost every setting in my FritzBox – without success ;-
* What is the Firmware version ? Only recent firmwares have the "Belgacom VDSL" option in the provider dropdown list.
* Have you set the Box to Country= belgium, Annex=B and provider = Belgacom VDSL2 ?
* Are you using the original Fritz "Y-cable" and the 2 RJ45/RJ11 adapters (white = DSL, black = PSTN) ?
* Also important: have you followed all the instruction regarding your VDSL2 installation at your premises ? (cables, NTP2007 entry point, TF2007 central filter/splitter, etc ...)
* What kind of problem are you facing: no synchronisation ? or no PPPoE session ? Please be a bit more specific ....
Hello,
I solved my problem. Unfortunately I used a broken network cable - changed the cable now it works
Thank you very much for your help.
Just in case someone else is look for the right setting:
* Provider "Belgacom VDSL"
* Annex B
* User "1234@ SCARLET" (capital!) + password
* ATM settings:
- VPI 8
- VCI 35
That should do it!
* Annex B
* ATM settings:
- VPI 8
- VCI 35
That should do it!
I would recommend to set ATM settings to "automatic".squib schreef: * ATM settings:
- VPI 8
- VCI 35
- honda4life
- Bedankt: 391 keer
With my Linksys the time to connect is much longer when automatic.
Maybe that's his reason, also this are static parmeters as far as I know.
- honda4life
- Bedankt: 391 keer
No, only port 25
