Mijn Sagem router heeft last van zware speeddrops op regelmatige basis. Verder kan ik wel nog verbinding maken met Xbox live, maar online gamen is niet meer te doen van de lag (wat tot enkele dagen geleden wel nog perfect ging)
Time Event Event-Type Details
Apr 9 02:02:25 2011 Outbound Traffic Blocked - NAT out failed ICMP type 3 code 1 192.168.1.2->174.36.30.9 on ppp0 [repeated 2 times, last time on Apr 9 02:02:41 2011]
Apr 9 02:02:23 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1024->174.36.30.9:80 on ppp0
Apr 9 02:01:18 2011 Outbound Traffic Blocked - NAT out failed ICMP type 3 code 1 192.168.1.2->174.36.30.9 on ppp0 [repeated 2 times, last time on Apr 9 02:01:40 2011]
Apr 9 02:01:16 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:3248->66.161.11.29:80 on ppp0 [repeated 8 times, last time on Apr 9 02:01:16 2011]
Apr 9 02:00:56 2011 Outbound Traffic Blocked - NAT out failed ICMP type 3 code 1 192.168.1.2->174.36.30.9 on ppp0 [repeated 5 times, last time on Apr 9 02:01:07 2011]
Apr 9 01:43:23 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:2343->74.209.160.12:80 on ppp0 [repeated 8 times, last time on Apr 9 01:43:23 2011]
Apr 9 01:21:14 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1925->74.125.230.136:80 on ppp0
Apr 9 01:20:29 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:2129->64.34.199.74:80 on ppp0 [repeated 6 times, last time on Apr 9 01:20:29 2011]
Apr 9 01:18:54 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:2022->95.101.248.124:443 on ppp0
Apr 9 01:18:54 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:2020->95.101.248.124:443 on ppp0
Apr 9 01:18:54 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:2021->95.101.248.124:443 on ppp0
Apr 9 01:18:51 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1053->174.36.30.9:80 on ppp0
Apr 9 01:18:42 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1825->209.85.143.96:80 on ppp0
Apr 9 01:18:40 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1815->8.12.226.219:80 on ppp0
Apr 9 01:18:39 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1787->74.125.230.153:80 on ppp0
Apr 9 01:18:39 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1805->74.125.230.142:80 on ppp0
Apr 9 01:18:39 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1786->74.125.230.153:80 on ppp0
Apr 9 01:18:39 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1784->74.125.230.153:80 on ppp0
Apr 9 01:18:39 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1785->74.125.230.153:80 on ppp0
Apr 9 01:18:35 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:2083->68.67.185.215:80 on ppp0
Apr 9 01:18:35 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1820->92.123.154.26:80 on ppp0
Apr 9 01:18:35 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1822->92.123.154.26:80 on ppp0
Apr 9 01:18:35 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1823->92.123.154.26:80 on ppp0
Apr 9 01:18:34 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1820->92.123.154.26:80 on ppp0
Apr 9 01:18:34 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1822->92.123.154.26:80 on ppp0
Apr 9 01:18:34 2011 Outbound Traffic Blocked - NAT out failed First packet in connection is not a SYN packet: TCP 192.168.1.2:1823->92.123.154.26:80 on ppp0
Apr 9 01:18:33 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1825->209.85.143.96:80 on ppp0
Apr 9 01:18:31 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1815->8.12.226.219:80 on ppp0
Apr 9 01:18:30 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1787->74.125.230.153:80 on ppp0
Apr 9 01:18:30 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1805->74.125.230.142:80 on ppp0
Apr 9 01:18:30 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1786->74.125.230.153:80 on ppp0
Apr 9 01:18:30 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1784->74.125.230.153:80 on ppp0
Apr 9 01:18:30 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1785->74.125.230.153:80 on ppp0
Apr 9 01:18:27 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1825->209.85.143.96:80 on ppp0
Apr 9 01:18:26 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1815->8.12.226.219:80 on ppp0
Apr 9 01:18:26 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1825->209.85.143.96:80 on ppp0
Apr 9 01:18:26 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1787->74.125.230.153:80 on ppp0
Apr 9 01:18:26 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1805->74.125.230.142:80 on ppp0
Apr 9 01:18:26 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1786->74.125.230.153:80 on ppp0
Apr 9 01:18:26 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1784->74.125.230.153:80 on ppp0
Apr 9 01:18:26 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1785->74.125.230.153:80 on ppp0
Apr 9 01:18:24 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1825->209.85.143.96:80 on ppp0
Apr 9 01:18:24 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1815->8.12.226.219:80 on ppp0
Apr 9 01:18:23 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1825->209.85.143.96:80 on ppp0
Apr 9 01:18:23 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1787->74.125.230.153:80 on ppp0
Apr 9 01:18:23 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1805->74.125.230.142:80 on ppp0
Apr 9 01:18:23 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1786->74.125.230.153:80 on ppp0
Apr 9 01:18:23 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1784->74.125.230.153:80 on ppp0
Apr 9 01:18:23 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1785->74.125.230.153:80 on ppp0
Apr 9 01:18:22 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1815->8.12.226.219:80 on ppp0
Apr 9 01:18:22 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1825->209.85.143.96:80 on ppp0
Apr 9 01:18:22 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1787->74.125.230.153:80 on ppp0
Apr 9 01:18:22 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1805->74.125.230.142:80 on ppp0
Apr 9 01:18:22 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1786->74.125.230.153:80 on ppp0
Apr 9 01:18:22 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1784->74.125.230.153:80 on ppp0
Apr 9 01:18:22 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1785->74.125.230.153:80 on ppp0
Apr 9 01:18:21 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1825->209.85.143.96:80 on ppp0
Apr 9 01:18:21 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1815->8.12.226.219:80 on ppp0
Apr 9 01:18:21 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1787->74.125.230.153:80 on ppp0
Apr 9 01:18:21 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1805->74.125.230.142:80 on ppp0
Apr 9 01:18:21 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1786->74.125.230.153:80 on ppp0
Apr 9 01:18:21 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1784->74.125.230.153:80 on ppp0
Apr 9 01:18:21 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1785->74.125.230.153:80 on ppp0
Apr 9 01:18:19 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1815->8.12.226.219:80 on ppp0 [repeated 2 times, last time on Apr 9 01:18:20 2011]
Apr 9 01:18:19 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1787->74.125.230.153:80 on ppp0
Apr 9 01:18:19 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1805->74.125.230.142:80 on ppp0
Apr 9 01:18:19 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1786->74.125.230.153:80 on ppp0
Apr 9 01:18:19 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1784->74.125.230.153:80 on ppp0
Apr 9 01:18:19 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1785->74.125.230.153:80 on ppp0
Apr 9 01:18:18 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1805->74.125.230.142:80 on ppp0
Apr 9 01:18:18 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1787->74.125.230.153:80 on ppp0
Apr 9 01:18:18 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1784->74.125.230.153:80 on ppp0
Apr 9 01:18:18 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1786->74.125.230.153:80 on ppp0
Apr 9 01:18:18 2011 Outbound Traffic Blocked - NAT out failed Packet not in tcp window: TCP 192.168.1.2:1785->74.125.230.153:80 on ppp0
Apr 9 01:17:22 2011 Firewall Setup Firewall internal Firewall configuration succeeded
Apr 9 01:17:22 2011 Firewall Setup Firewall internal No IP for NAT - connections may fail [repeated 2 times, last time on Apr 9 01:17:22 2011]
Apr 9 01:17:21 2011 Firewall Setup Firewall internal Starting firewall configuration
Wat ik reeds probeerde:
een factory reset, daarna alle instellingen terug aan gezet zoals ze stonden (wifi beveiligen, telefoon). Dit hielp niet.
DHCP uitgeschakeld op de Sagem (op aanraden van Scarlet, ik had nochtans nergens last van tot voor kort)
DNS 1 en 2 van de Sagem vervangen door 8.8.8.8 en 8.8.4.4 (google dns) omdat deze een pak beter werken
Mijn netwerk ziet er als volgt uit:
Sagem VDSL2 router: 192.168.1.1
Dhcp aan, range: 192.168.1.2 - 192.168.1.50
Firewall: Typical Security
Aan deze Sagem zijn 2 toestellen verbonden met de kabel
een Minecraft server (192.168.1.5) en een Linksys WRT320N router (192.168.1.2).
En 2 toestellen draadloos: laptop (192.168.1.3) + gsm (192.168.1.4)
Linksys WRT320N: 192.168.0.1
Dhcp aan, rande: 192.168.0.2 - 192.168.0.50
Firewall: aan
Filtering anonieme internet verzoeken: uit
Filter Multicast: uit
Filter doorsturen NAT: uit
Aan deze linksys zijn wat meer toestellen verbonden.
draadloos: een laptop (192.168.0.3), een Belkin Homebase (192.168.0.4), een PS3 (192.168.0.5)
met kabel: Xbox 360 (192.168.0.50), een tv (192.168.0.6) en een oude desktop waar ik wat op pruts
De Xbox 360 heeft een vast IP vanwege poorten die open moeten staan (heeft nooit problemen gehad)
De Minecraft server heeft omwille van dezelfde reden een vast IP. Al de rest is door DHCP toegekend.
De Linksys router had een vast IP omdat ik hem eens in een DMZ heb gestoken (met de hoop dat het zou helpen, niet dus)
(ik zal eens een grafische voorstelling tekenen als ik wat meer tijd heb, want het is nogal onduidelijk zo. Heeft iemand een idee wat het probleem kan zijn? En vooral hoe ik het oplos.
Iets gelijkaardig/hetzelfde probleem, echter zonder echte oplossing: http://www.walterdevos.be/bbox2-sagem-b ... syn-packet
