dat als je de volgende keer dat bestand opent er een kadertje komt
met een tekst dat je zelf kunt schrijven. Hoe moet ik dat dan doen??
Ps: Ik heb het vroeger nog gekund maar ik weet niet meer hoe.
Private Sub Workbook_Open()
MsgBox "Sup Biach?", vbQuestion + vbOKOnly, "Bling-bling"
End Sub
Lol, funny popupSquirtle schreef:Code: Selecteer alles
Private Sub Workbook_Open() MsgBox "Sup Biach?", vbQuestion + vbOKOnly, "Bling-bling" End Sub
Sub autoopen()
'remove possible gui modifs remaining from previous session
CleanUpIncidentInterface
'create the incident management button
createNewIncidentToolBar
'add an item in the EDIT menu bar
AddIncidentManagementMenuItem
'make a short-key for the button
createCustomShortCutKey
'prepare jet
Initialize
frmIncidentManagment.ClearFields
'fill in comboboxes
getRequestors
'getInitialRequestors
getBuxes
getBuxNumbers
getFunctions
getProjects
getPriorities
blnHasBeenFilled = False
blnHasBeenClosed = False
End Sub
Sub createNewIncidentToolBar()
Dim cbrCommandBar As CommandBar
Dim cbcCommandBarButton As CommandBarButton
' If the command bar exits, remove it.
On Error Resume Next
Application.CommandBars("IncidentManagement").Delete
' Add the command bar to the application's CommandBars collection.
Set cbrCommandBar = Application.CommandBars.Add
cbrCommandBar.Name = "IncidentManagement"
' Add command button control to the control's
' collection of CommandBar objects.
With cbrCommandBar.Controls
Set cbcCommandBarButton = .Add(msoControlButton)
' Set properties of the command button.
With cbcCommandBarButton
.Style = msoButtonIconAndCaption
.Caption = "Capture Incident"
.FaceId = 231
.TooltipText = "Capture the selected text as a new Incident."
.OnAction = "DisplayIncidentForm"
.Tag = "Capture Incident"
End With
End With
cbrCommandBar.Visible = True
End Sub
Sub AddIncidentManagementMenuItem()
Dim cbmMenuBar As CommandBarPopup
Dim cbcMenuItem As CommandBarButton
Dim strMenuBarName As String
' Remove menu item if it exists.
Application.CommandBars("Menu Bar").Controls("Edit").Controls("Capture Incident").Delete False
' Identify menu bar that will receive new item.
strMenuBarName = "Menu Bar"
Set cbmMenuBar = Application.CommandBars(strMenuBarName).Controls("Edit")
' Add menu item.
Set cbcMenuItem = cbmMenuBar.Controls.Add(Type:=msoControlButton, Before:=8)
' Set property values of menu item.
With cbcMenuItem
.ShortcutText = "Ctrl+I"
.FaceId = 231
End With
End Sub
Sub createCustomShortCutKey()
'link CTRL-I to Incident Management button
CustomizationContext = ActiveDocument
KeyBindings.Add KeyCode:=BuildKeyCode(wdKeyI, wdKeyControl), KeyCategory:=wdKeyCategoryMacro, Command:="DisplayIncidentForm"
End Sub
Sub DisplayIncidentForm()
If Not blnHasBeenFilled Then
'after clear or first time
blnHasBeenFilled = True
fillIncidentForm
frmIncidentManagment.Show
Else
If blnHasBeenClosed Then
If Selection.Characters.Count >= 1 Then
frmIncidentManagment.txtIncidentDesc = Selection.Text
frmIncidentManagment.txtSolutionPropo = Empty
End If
Else
'after hide
End If
End If
End Sub
Sub CleanUpIncidentInterface()
Dim varItem As Variant
'remove EDIT menu item
For Each varItem In Application.CommandBars("Menu Bar").Controls("Edit").Controls
If varItem.Caption = "Capture Incident" Then
varItem.Delete False
End If
Next varItem
'remove Incident Management Cmd Bar
For Each varItem In Application.CommandBars()
If varItem.Name = "IncidentManagement" Then
varItem.Delete
End If
Next varItem
'remove Ctrl-I from form
FindKey(BuildKeyCode(wdKeyI, wdKeyControl)).Disable
End Sub
Private Sub worksheet_activate()
MsgBox "Yo!"
End Sub
