Beste,
Te koop een ADSL modem Thomson 536 v6 met aangepaste firmware voor gebruik van DMT ( http://dmt.mhilfe.de/) analyse programma.
Toestel werkt perfect en wordt verkocht omwille van overschakeling naar VDSL2.
Inbegrepen : modem en voeding.
Verkoopprijs +-15 €. Af te halen in Sint-Niklaas of kan opgestuurd worden op kosten/verantwoordelijkheid koper.
prijs via post vanaf 5.7 € gewone verzending tot 11€ aangetekend .
Specs:
Hardware specifications
• Interfaces:
- LAN:
• 10/100Base-T (RJ45)
• MDI/MDI-x autosensing
• 1 Ethernet port and 1 USB port
- WAN:
• ADSL line (RJ11) for ADSL/POTS
• Dimensions: 30 X 147 X 114mm (1.18 x 5.78 x 4.48 in.)
• Temperature: 0°to 40°C (32 to 105 F)
• Humidity: 20% to 80%
• AC voltage: 100 to 120, 220 to 240 V
• Frequency: 50/60 Hz
ADSL modem specifications
• ADSL: ANSI, ETSI, Annex A, B
• ADSL2: Annex A,B,L
• ADSL2+: Annex A, B
Multi-user Router
• ATM-Extensive multi PVC
- ATM Quality of Service (UBR, CBR, VBR-rt, VBR-nrt)
- DSLForum TR-37 autoconfi guration
• Bridging-self learning bridge at wire speed
• IP Routing
- UPnP* certifi ed Internet Gateway Device, enabling major conferencing and gaming technlolgies
- IPsec passthrough from multiple LAN clients, enabling secure homeworking
- Supports PPPoE, PPPoA, IPoA, CIP, ETHoA-DNS server and relay, DHCP server and relay
- Network Address Translation for connection sharing, including support for SIP, H.323,
Realaudio, ftp, irc, IKE, IPsec-ESP, Jabber, ILS,...
- Simultaneous bridging and routing of PPPoE connections, enabling network based VPN's
* UPnPTM is a certifi cation mark of the UPnPTM Implementers Corporation
Management
• OS independent
• Easy set-up wizard
• Advanced Management via telnet, HTTP, SNMP, event log
• Integrated fi rewall
• Easy SW upgrade wizard
USB drivers
• Host software support for:
- Windows 98, 98SE, 2000, ME and XP
- Mac OS9, OSX
• Plug-and-play installation
• Simple software upgrade procedure
• USB integrated as virtual Ethernet on PC
[Te Koop] Thomson 536 v6
crazydavid
- Bedankt: 6 keer
crazydavid
- Bedankt: 6 keer
Niemand ?
10€
10€
