TELE2 Blockt websites ?
Alle discussies over BASE kunnen hier terecht
B166IR
Als ik naar deze website ga <knip> en http://binsearch.net krijg ik een timeout, wat raar is, als ik inlog via een Amerikaanse VPN kan ik wel op die sites zonder probleem.
nog iemand anders die dit heeft ?
Mod edit: knipje
Niet toegelaten acties :
* links naar illegale software (zaken), porno, warez, crack-sites, ...
cptKangaroo
Uitgedeelde bedankjes: 777 keer
Bedankt: 258 keer
Tracing route to <knip>
over a maximum of 30 hops:
1 13 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 * * * Request timed out.
3 11 ms 11 ms 12 ms 94.104.0.54
4 12 ms 12 ms 11 ms 94.104.0.54
5 14 ms 14 ms 14 ms zvtm-s1-rou-1041.BE.eurorings.net [134.222.148.230]
6 18 ms 18 ms 18 ms asd2-rou-1021.NL.eurorings.net [134.222.231.185]
7 21 ms 20 ms 20 ms obl-rou-1021.NL.eurorings.net [134.222.231.130]
8 21 ms 21 ms 20 ms 195.190.227.222
9 209 ms 154 ms 147 ms rc2ec.il.shawcable.net [195.69.144.148]
10 142 ms 143 ms 142 ms rc1ec-tge0-0-2-0.il.shawcable.net [66.163.65.45]
11 155 ms 155 ms 155 ms rc2sh-pos3-0.mt.shawcable.net [66.163.76.146]
12 154 ms 154 ms 154 ms 66.163.66.90
13 155 ms 155 ms 154 ms rx0sh-q9-networks.mt.bigpipeinc.com [66.244.223.202]
14 156 ms 156 ms 156 ms dist1-1.tor1-f2.q9.net [69.46.123.43]
15 156 ms 156 ms 156 ms dist1-1-g-access2-2.tor1.q9.net [69.46.121.78]
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
Tracing route to binsearch.net [83.149.75.183]
1 45 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 13 ms 12 ms 12 ms cust-1-0-110-94.dyn.versateladsl.be [94.110.0.1]
3 cust-1-0-110-94.dyn.versateladsl.be [94.110.0.1] reports: Destination net unreachable.
Trace complete.
De binsearch.net ligt er waarschijnlijk uit door een gecrashte router bij het evoswitch.com datacenter in Nederland - mijn site is ook nog steeds onbereikbaar voor mij vanwege die routeringsproblemen en geeft dezelfde boodschap. De <knipje> site is waarschijnlijk vanwege een ander probleem ergens op de huidige route.
Mod edit: knipje
Goendi
Twitter: goendi
Destination net unreachable. betekend zoveel als het zegt: destination network not reachable... Dat is geen blokkering, dat is een standaard melding die aangeeft dat het IP wat overeenstemt met die bepaalde website niet bereikbaar is via het publieke internet (blackholed bvb).
Bedankt: 1492 keer
cptKangaroo
Bedankt: 258 keer
Hopelijk wordt de evoswitch link snel gefixt :|
TheGabeMan
Hi
Ik lijk t zelfde probleem te hebben. Een vriendin van mij belde me dat bepaalde websites niet bereikbaar zijn. Zij heeft een versatel abo en kan niet op http://www.relatieplanet.nl en .be Ook hier een timeout. Laptop van haar naar mij thuis en werkt prima. Laptop terug naar haar thuis werkt niet meer.
Zelfs surfen op IP adres lukt niet. Terwijl dat bij mij thuis dus wel werkt. We checken gelijktijdig op MSN en de site is echt wel in de lucht.
Heb nu mijn laptop meegenomen en zit op haar verbinding en inderdaad nu kan ik die sites ook niet meer bereiken. Ligt dus zeker niet aan laptop of internet explorer.
Dns oplossing, (nslookup www.relatieplanet.nl) geeft correcte IP adres terug.
Ben benieuwd of er toch echt geen block is. Probleem treedt trouwens pas sinds enkele dagen op.
Gabrie
MeYeR
Ik zit met eenzelfde probleem.
Samen met een aantal mensen huren we een dataserver. Er staat ook een scriptje zodat je kan inloggen met je browser en enkele zaken kunt bekijken. Sinds maandag is de server helaas niet meer bereikbaar van thuis uit. Op gelijk welke PC thuis is de server niet te vinden. Iemand anders kan er echter wel op. Met een proxy site zoals freeproxyserver.net kan ik inloggen via m'n browser maar data afhalen lukt niet.
Dus het is duidelijk dat Tele2 de server voor mij blokkeert.
Is hier een workaround voor. Of moet ik mss toch eens contact opnemen met Tele2. Over de content die op de server staat moet ik wss geen uitleg geven :wink:
[Intel Core 2 Duo E8400 | Gigabyte GA-P35C-DS3R | ATi Radeon HD 4800 512 MB | Corsair TWIN2X 6400C4 DDR2, 4096MB CL4 | 1.8 TB HD intern / 500 GB HD extern | Windows Vista | Tele2]
TheGabeMan
MeYeR schreef:Ik zit met eenzelfde probleem.
Heb al een support call aangemaakt bij United Telecom. Weet ook niet hoe die er precies mee te maken hebben maar daar betaald mijn vriendin het abo aan. En United ging een techneut laten terug bellen. Maar dat zal wrs zijn als ik er niet ben en die kennis van mij weet verschil tussen MSN en IExplorer niet eens :-)
topaz
Ik heb hetzelfde problem, denk ik.
Ik ben een Tele2/Base (vroeger Versatel) 4Mb Internet klant.
Ik kan mijn web-hoster niet accesseren (http://www.alfanet.be), noch kan ik surfen naar "mijn" web site, of upload via FTP.
Dit is nu zo sinds 2 dagen.
Het helpdesk (!) van Tele2 erkent het problem: "onze techniekers werken er op, maar we weten niet waaneer het zal opgelost worden."
Internet, het netwerk met een redundant architectuur: ongelooflijk.
Heeft iemand meer inzicht over wat is hier aan de gang ?
TheGabeMan
topaz schreef:Ik heb hetzelfde problem, denk ik.
Kun jij de sites die de andere posters hier noemen ook niet bereiken?
MeYeR
Ik heb ook eens de test gedaan.
http://www.alfanet.be en http://www.relatieplanet.nl zijn ook niet bereikbaar voor mij.
Ernaartoe surfen via http://www.freeproxyserver.net/ lukt dan wel weer. Sommige sites zijn dus niet meer toegankelijk :?
topaz
TheGabeMan,
rap een test gedaan:
freeproxyserver - OK
relatieplanet, binsearch - niet OK
Topaz
TheGabeMan
topaz schreef:TheGabeMan,
Topaz
Moet toch wel haast een block zijn. Het IP adres wordt via DNS wel correct resolved en als je naar het IP direct surft, kom je ook niet op de pagina.
B166IR
nfohump.com
werkt ook niet, de lijst begint al te groeien. is dit nu echt een block op warez sites ?
cptKangaroo
Bedankt: 258 keer
Zoals ik al zei: een routercrash bij EvoSwitch datacenter (voornamelijk Leaseweb hosting) heeft dit waarschijnlijk veroorzaakt. DNS staat los van de routes die aan de IPs hangen - waarom er geen nieuwe routes komen, is de vraag, maar men is er blijkbaar mee bezig. Doe maar een tracert evoswitch.com dan kan je zien dat 'normale' sites er ook onder te lijden hebben.
320i
Ik heb het intern ook even doorgegeven om na te kijken en eventueel contact op te nemen waar nodig om dit euvel te verhelpen.
TheGabeMan
320i schreef:Ik heb het intern ook even doorgegeven om na te kijken en eventueel contact op te nemen waar nodig om dit euvel te verhelpen.
Hi
Ik ben nog nieuw hier op forum, maar werk jij voor Tele2 / Versatel? Of wat bedoel je met intern?
Gr
Gabrie
Uzzi
Bedankt: 34 keer
320i werkt inderdaad bij T2
The Conquer
Uzzi schreef:320i werkt inderdaad bij T2
En nog wel op een goede positie!
320i heeft hier al velen geholpen, waarvoor nogmaals dank :banana:
Afbeelding Afbeelding Afbeelding Afbeelding Afbeelding
Bedankt: 152 keer
Lijkt opgelost te ziin hier via tele2.
MeYeR
Hier is het probleem ook opgelost :-D
TheGabeMan
Bij vriendin lijkt t nu ook opgelost
B166IR
Yep, alles is in orde nu. heeft wel lang geduurt om eerlijk te zijn.
topaz
Bij mij ook opgelost (http://www.alfanet.be, etc.).
Veel dank 320i !
Ik ben akkord met B166IR, en een beetje status info van T2 zal ook niet slecht zijn geweest.
Topaz
320i
@Topaz: dacht hier nog te reageren, maar ben er niet meer toe gekomen.
Donderdag avond had ik de informatie gekregen dat het sinds 's morgens opgelost was.
Terug naar “BASE (Tele2, Versatel, Snow)”
